Page 1 of 2 12 LastLast
Results 1 to 40 of 64
Thread: Climb prop C-90
    RaisedByWolves's Avatar
    Feb 2005
    3,857
    Climb prop C-90
    Hey guys, we have a 7EC with a C-90-12 and a sensenich 76AK-2-48. I was wondering what is approved for a climb prop, or could we re pitch the obese have. We are only seeing 2200-2300 on takeoff
    Tom
    Beach Bum's Avatar
    Jul 2010
    Acworth, GA
    325
    Quote Originally Posted by TomFord View Post
    Tom
    I believe approved propellers will be listed on the airplanes type certificate or STC. We installed a C-90-8 and a metal propeller on our J3... All listed on the TC.
    9,127
    I took mine in and had the pitch re done. I think I ended up at a 43 or so.
    A good prop shop will give you a good idea where it should go if you have the existing rpm and tell them where you want it.
    Note: use a reliable tac, not the one in the dash to verify the existing rpm!
    Feb 2005
    3,857
    I found out today, that the tach records the RPM but doesn't record the time, and it looks like a newer tach with only 280HR
    Feb 2005
    3,857
    I have been doing some reading, sounds like 42 pitch is about right, Can a prop shop re pitch a 48 to 42? Where can i find a "localish" prop shop in new england?
    Hot Springs, SD
    362
    Not sure if this will help or not, but in a conversation with Craig Catto, he told me that his 76x36 on a c-90 @2200-2300 was outpulling the whirlwind ground adjustable even when it was set to give a static rpm of 2600. Then there are the guys that run thier o-200s up to and over 3000 rpm and swear that thats the way to go. All experimental of course...
    9,127
    Doesn't Tim have a champ?
    Maybe you could do a long term borrow to test it out....
    Mar 2009
    Fairbanks Alaska
    106
    I used to have a C-90-12 in a J3/PA11 configuration and ran the sensenich 76AK-2 in a 37 pitch and it was under on TO by about 25 rpm and was a real performer when light.
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    I am using a 76AK2-40 on a 0-200 on floats and it is a great performer. Think 42 would be too much pitch. Great Prop.
    9,555
    Try http://www.sensenichpropellers.com/Main.html?Home.html They are in Windham CT at the airport. You might be able to fly in, have it done and fly home.
    Chuck Avon's Avatar
    Apr 2011
    Hohenwald Tn
    366
    On new C85-12 on tcraft i have a McCauley 1B90 cm 74/43 static rpm 2400 t/o 2500 climb 1200 ft per min cruse at 2500 rpm 107 kt the engine has 9 hr on it now so it's still braking it in
    cruiser's Avatar
    South Glens Falls, NY
    1,441
    According to the chart in the Univair catalog 76AK-2-46 is standard and 48 is a cruise prop. Sensenich Propeller Service in in PA has given me good service in the past, they are also in North Windham, CT. Google them. Note that this is NOT Sensenich propeller manufacturing although they would probably give good service also. Similar names, different business as I understand it. Jim
    cruiser's Avatar
    1,441
    Tom, Sounds like it's time for an Aircraft Spruce and Univair catalog for your reading room. The Spruce catalog is a little heavy on the knees though. Good luck, Jim
    Jon B.'s Avatar
    Willmar, MN (KBDH)
    712
    Tom,
    I bought a new 76AK-2-44 from Univair for my 90hp Champ (same engine as you have). I didn't care for the performance, so took it to a prop shop and had it pitched to 42.
    The take-off and cruise both improved considerably! In fact, it went faster with that pitch than at 44.
    I don't think a shop can change it that much, though. It seems to me theycould go 4-5 inches in either direction from original.
    Jon
    9,127
    'NEW' does not mean correctly pitched
    Jul 2008
    175
    I run a Sensenich 76AK-2-46 on my C90-12 experimental cub. I see about 2300 to 2350 on takeoff, cannot get to redline at cruise unless in a descent, thinking 42 or 43 would be better.
    Roger, flying and fishing where it is cool, what a great deal! Too hot down here! We are heading North on Tuesday.
    Stan
    JP's Avatar
    Mar 2003
    The Big Woods of Maine
    3,201
    42 on my C-90. Works really well.
    JP Russell--The Cub Therapist
    1947 PA-11 Cub Special
    www.bloomerrussellbeaupain.com
    nd
    3,345
    925# cub, 7440 mccauly, 2650 climb not quite 80 cruise, sets you back in the seat on takeoff. for just a little more cruise a 41 or 42 would be right in there. These cattos for exp like clint says still look cool.
    Sep 2006
    Maynard,MA
    1,228
    Tom I would use the prop Roger uses.Yours may be able to be pitched down that far.Check with Douten I am pretty sure that's what he runs.You should be able to go to redline in level flight.
    I run the Mac 75-35 0n my 0-200.I cruise at 2550@93mph.I don't believe it is approved on the 90.
    I met a guy at Lockhaven with a J-3/85 who was running a new M/T composite prop.He said it was an approved prop and worked really well.
    nd
    3,345
    Quote Originally Posted by Super11XP View Post
    Clint what are you running on your 90, I like the way you try all this stuff. doug
    JP's Avatar
    Mar 2003
    3,201
    http://www.airplanepropeller.com/
    A very good shop over in CT.
    Hot Springs, SD
    362
    I am currently running a 69x41 on my c-90. I see about 2550 static and a little over 2600 on climbout. I don't think that it is really that great of a prop-not enough diameter. Craig is currently building a 76x38 for me that I am really excited about. we'll see how it works when I get it. He is really busy.
    Upper Peninsula of Michigan
    409
    Did you ever get that prop? I'm interested in the results. I am looking into options for an experimental 11 with C90
    skipster's Avatar
    Oct 2008
    Altamont NY
    201
    Tom, when my buddy owned that plane I put a brand new 76AK-2-42 on it. Don't know why someone would have taken it off unless something happened to it.
    Feb 2005
    3,857
    Climb prop C-90
    Yeah I ended up with a new 76ak-2-42 and it turns up 2500 on takeoff.
    If I was exp I would be looking at a catto. Glenn had one on his o-200 powered cub, and now has a sensenich ground adjustable that he is very happy with
    9,898
    1b90 7440 Mac is hard to beat on a C90
    409
    I'm experimental so I think I'll research the Catto 78-38.... Sounds like SUPER11XP likes his. This experimental realm is fun.....so many options. I always got frustrated when doing restoration that I could not change some things that I wanted to because my other planes are certified.....like I said....this is fun
    9,898
    My C85 stroker has a C90 cam, 85 pistons 8.6-1 and would not turn a catto 7636 above 2250 static. I never flew it on my J4 because it couldn't get me off the pond that my Mac 7440 does.
    373
    I have two 76AK-2-42 props and both Limit the engine to around 2350rpm on C90-8. I'd like to repitch one to 38.
    Dave
    409
    great info Glenn. It's not like you can rep itch one either....so I better do my research. I have a 76AK-2-40 on my 90 TCraft on floats and that works good.i am interested in the weight savings of the Catto
    Hot Springs, SD
    362
    Quote Originally Posted by Dan Gervae View Post
    yep 78x38 is a great prop. I had c85 pistons and Vetterman exhaust on my plane. 38 pitch might be a bit course without those 2 things. The experimental thing certainly is fun!!
    9,898
    ReliableFlyer on here has a Catto 7834 on his C90 cub, maybe he will comment on how its working. I loved the Catto while I was using it on my 0200 cub. Even though static was only 2350 it still pulled great. You can feel the weight difference as soon as your airborne.
    Ken Kennedy's Avatar
    Dec 2008
    Lubbock , Tx
    56
    I heard of a guy that put a 80-30 Catto on his C85 stroker and apparently it is a hell of a performer. I heard to turns about 2350 static, and about 2600 in a 45 mph climb. Guy said it was a night and day difference between the 76AK-2-42 that it replaced; over 100 lbs harder pull on the same day which was supposedly around 5K density altitude.
    409
    Catto recommended the 76-36 for my stock O200A on my PA11EX I hope it is the ticket....I ordered one. If I can't get the static I want maybe I'll go with Lycon high compression Pistons.....was hoping to keep it stock for now. I've got lots of building to do yet but I pick up the big items as I can afford them��
    10,613
    This thread has gone for 34 posts, with some incriminating evidence posted by those who are operating certificated airplanes--maybe.
    Here is what the 7EC type certificate says about propellers and propeller RPM:
    Engine Limits For all operations, 2475 r.p.m. (90 hp.)
    Airspeed Limits Level flight or climb 100 m.p.h. ( 87 knots) True Ind. Glide or dive 135 m.p.h. (117 knots) True Ind.
    Propeller Limits Static rpm at maximum permissible throttle setting: (For fixed pitch Not over 2350, not under 2125. No additional tolerance permitted. wood propeller)
    Diameter: not over 72 in., not under 70 in.
    So, if your current propeller pulls between 2125 and 2350 STATIC (as in full throttle, on the ground, NOT moving) then it is within legal limits. Repitch it to get better climb or cruise, and if it then runs static outside those limits, it is not legal.
    And, for those folks advertising on the world wide web that their C-90s on certified aircraft are running 2600 rpm.....note that the Continental TCDS (and the above 7EC TCDS) says Maximum rpm for the Continental C-90 is 2475 RPM for ALL operations.
    If you're experimental, obviously, you can do whatever you want with your engine.
    But, for the OP, these are the limits for your engine. 2200 to 2300 for takeoff is probably pretty close to that static limits noted above.
    Also, a review of the TC for your airplane will also tell you what propellers are approved for the plane. The TC is the first place you should go for basic information like this....THEN troll the internet.
    Engine Limits
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    406
    What RPM are you getting Roger ?
    Quote Originally Posted by Roger Peterson View Post
    9,898
    Engine Limits
    Do what cub crafters does, placard by throttle " limit take off power to 2350 RPM "
    9,898
    I had that prop on my 0200A and would go to a 7634 if you want to stay stock. YMMV
    10,613
    Different ball game entirely. First, not a "certificates" airplane...LSA. Second, the engines in those airplane's are rated by the engine manufacturer for 2700 continuous rpm. The limitation there has to do with meeting LSA standards.
    In this case, the Continental C 90 is very specifically limited by the manufacturer. You don't get to meet the static rpm limit via a placard, as far as I know.
    Violate these limits at your own peril. Advertise same in a public forum, however, is rather ignorant.
    FWIW.
    Aug 2015
    Farmersville, TX
    327
    I agree. Telling the world you're breaking the regs is only slightly less questionable than the folks who post videos of their flights that clearly show they are violating cloud clearance or other FAA rules, while advertising their names and N-numbers and even showing the pilot's face... Talk about making the FAA regulator's life easy! As a buddy of mine says "Everyone steps on their d*** once in a while. The trick is not to be wearing golf cleats when you do!"
  1. Cruise Prop vs. Climb Prop
    By j3jm in forum Cafe Supercub
    Last Post: 04-24-2019, 01:50 PM
