Results 1 to 22 of 22
Thread: Fuel Line Flarings
    Binty's Avatar
    Jan 2005
    South Island, New Zealand
    382
    Fuel Line Flarings
    Im curious to know if the original fittings to the Fuel valve selector have a special flaring? Im looking at replacing some of my lines and the flaring tool we are using makes a flare which 'Looks' to be a slightly different profile to that of the removed line.
    I realise there will be a certain amount of shape change when the fitting is done up tight and pulls up but just want to check if Piper had an unusual flare angle?
    BTW, the way its a modern Aviation flareing tool- not a cheap auto shop one.
    DW's Avatar
    Dec 2002
    pacific northwest
    2,067
    I used a standard RIGID brand flaring tool and it worked fine.
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,312
    Parker flaring too. AN is 37 degrees. http://www.aircraft-tool.com/shop/de...ODUCT_ID=212FB
    mike mcs repair's Avatar
    11,773
    You want the auto store version flair tool for the original inverted flar used at fuel valve, it's 45 deg... Its a Weather head brand fitting Napa caries the parts......
    j5mike's Avatar
    Aug 2007
    North Alabama
    191
    [QUOTE=Binty;540605]Im curious to know if the original fittings to the Fuel valve selector have a special flaring? Im looking at replacing some of my lines and the flaring tool we are using makes a flare which 'Looks' to be a slightly different profile to that of the removed line.
    I suspect you are flaring a single flare 45dg and it's supposed to be a double flare. Your run of the mill flaring tool will not double flare. The correct tool will roll the tubing inward first and then the second step will flare it. This of course is assuming you are working with inverted flare. As stated above the AN fittings are 37dg flare and inverted is 45dg double flare. If you need any more info then PM me and I will do my best to help. This is what I do for a living.
    11,773
    its a SINGLE 45 deg flare.
    Likes astjp2 liked this post
    7,638
    I am with Mike. Piper was smart enough to use standard automotive and tractor parts in the beginning. Simpler was better back then. Same for brakes. You can now change to expensive and heavy aircraft stuff using AC 23-27. It is a minor mod. Doesn't make it any better.
    21,305
    The aluminum AN fittings are lighter and in most cases less expensive than the brass Weatherhead fittings. The copper brake lines are heavier than aluminum and the special hoses you have to buy from Univair are way expensive.
    Thanks tedwaltman1 thanked for this post
    7,638
    All true, but that piece of Aeroquip adds more than enough to offset the weight savings. Some use a piece of Aeroquip from master all the way to the brake assembly. The theory is fewer couplings to wiggle loose and cause problems.
    I see nothing wrong with the aircraft stuff. Aluminum line doesn't seem to harden with vibration.
    ATP, CFII, A&P sdischer's Avatar
    Dec 2019
    COLLEGE STATION, TX
    144
    Has anyone tried using flare gaskets with 45 degree inverted flares? My fuel lines are leaking at the selector valve. I loosened and jiggled the tube and tightened and for now it is sealed but it will leak again.
    May 2017
    1,167
    I知 wondering if anyone has switched to the plastic brake lines like Vans uses. I壇 like to try it, but not sure what tubing and fittings they use. I think it would be lighter than AN fittings, Aeroquip hoses, and aluminum lines. I知 putting dual brakes in the Clipper, so double the Aeroquip lines. The plastic poly flow (or whatever tubing) and fittings would be a lot easier as well.
    For my fuel system, I知 switching to AN fittings, aluminum is a lot lighter than the brass Weatherhead fittings. I値l have a hybrid system, still keeping the 12 gallon nose tank, but a Dakota Cub 23 gallon left tank with SuperCub wing root gage.
    10,869
    15 years ago when I didn't know any better I did my fuel lines with Alum versatube and AN fittings. All flairs on tubing were 45*. Never leaked all this time
    stewartb's Avatar
    Wolf Lake, AK
    6,584
    A 37ー flaring tool is $125 from Spruce. Simple to use and pretty much fool-proof.
    May 2017
    1,167
    37 degree for AN fittings, 45 degree for Weatherhead fittings.
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    705
    I've used them for brakes in several Experimentals. Use Nylaflow lines with Polyflow brass fittings. 1/4" lines tend to expand under pressure, so you lose a lot of your brake pressure to the lines expanding. Use either 3/16" or 1/8" Nylaflow lines. Most newer kits are now recommending 1/8" lines. The nylaflow lines I installed in the first plane I built are still there and still hold pressure after 25 years. One caution is to not use them inside wheel fairings where they might be exposed to brake heat as they will soften and burst under pressure when hot.
    -Cub Builder
    May 2017
    1,167
    Quote Originally Posted by Cub Builder View Post
    -Cub Builder
    Thanks, just what I needed.
    10,869
    I have one now but still not convinced its needed on a gravity system? Pressure with a pump system, maybe?
    stewartb's Avatar
    Wolf Lake, AK
    6,584
    Sure. Doing **** wrong on an airplane usually works out, right? Have at it. I had the chance to buy the right thing or wrong thing. Easy decision.
    10,869
    Yup, 1100 hrs later I should be ashamed of myself for such poor workmanship
    Thanks irishfield thanked for this post
    Likes supercrow, 40m liked this post
    TVATIVAK71's Avatar
    Jun 2016
    ANC
    119
    Sometimes poor workmanship rears it痴 ugly head early. Huh, why is there fuel leaking from the gear attach point?..why is the inside fabric soaked in gas?. Didn稚 take long for these awesome flares to seep after a supposed rebuild. plane already had 15 hrs. Needless to say everything got redone.
ID:	58387   Click image for larger version.
ID:	58388   Click image for larger version.
ID:	58389   Click image for larger version.
ID:	58390   Click image for larger version.
    Likes RaisedByWolves, BC12D-4-85 liked this post
    21,305
    I’m wondering if anyone has switched to the plastic brake lines like Vans uses. I’d like to try it, but not sure what tubing and fittings they use. I think it would be lighter than AN fittings, Aeroquip hoses, and aluminum lines. I’m putting dual brakes in the Clipper, so double the Aeroquip lines. The plastic poly flow (or whatever tubing) and fittings would be a lot easier as well.
    For my fuel system, I’m switching to AN fittings, aluminum is a lot lighter than the brass Weatherhead fittings. I’ll have a hybrid system, still keeping the 12 gallon nose tank, but a Dakota Cub 23 gallon left tank with SuperCub wing root gage.
    https://www.summitracing.com/parts/AER-FBM1101
    https://www.summitracing.com/parts/AER-FCC0420
    Thanks tedwaltman1, flybynite thanked for this post
    Likes Rotormech, bcone1381 liked this post
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,764
    This company will make hoses any length you want. I used them on my 180.
    https://www.pegasusautoracing.com/gr...pID=CUSTOMHOSE
  1. Fuel line hoses
    By mpawlie in forum Cafe Supercub
    Last Post: 05-01-2010, 08:13 AM
  2. fuel line ?
    By jon in forum Experimental Cubs
    Last Post: 12-20-2004, 11:17 PM
  3. Fuel line
    By pa19guy in forum Modifications
    Last Post: 08-31-2004, 12:30 PM
