Page 85 of 90 FirstFirst ... 35758384858687 ... LastLast
Results 3,361 to 3,400 of 3581
Thread: Oops, darn it...
  1. #3361
    Waldo M's Avatar
    Jan 2018
    Finger Lakes area, western NY.
    217
    Quote Originally Posted by salex View Post
    I have my first bird with a header tank, and don't feel as informed about it as I would like even after reading lots here on sc.org.
    Since you have a PA-11, here's a little more info regarding the header tank installed on that airplane. At least as Piper built it.
    Keep in mind that the stated capacity of the main fuel tank is given as 17 U.S. gallons. The header tank was manufactured by Piper, so I assume they are all of similar capacity although I have never seen that capacity published anywhere.
    The last time we restored our PA-11, the fuel system was completely drained and dried. After we put the airplane back together, 3 gallons of fuel were added. The tail was lifted and the airplane was placed in a level attitude for a few minutes to ensure that the header tank was full. [The header tank picks up it's fuel from a "T" on the bottom of the fuel gauge.] The airplane was put back in the three point attitude and the fuel flex hose was disconnected at the carburetor. Fuel was drained until the flow started to diminish and then the line was reconnected. Fuel was added from a pump with an accurate meter until the tank was full. It took 18.1 gallons to fill it. I consider that the usable fuel capacity of this particular airplane. I wouldn't take that figure as gospel unless you do the same test on your airplane. All bets are off if your fuel system has been modified with an extra fuel tank or in some other way.
    Incidentally, we calibrated an 11" generic fuel dripstick while we refilled the tank. If you do that test, you may want to take the opportunity to do that.
    Thanks salex thanked for this post
  2. #3362
    11,670
    I calibrated a paint fuel stick on my Pa11 20+ years ago on 800x4 tires. Any thing under 11 gallons didn't register on the stick
  3. #3363
    4,713
    Same deal for me as Glenn. I ended up marking the wing root fuel tubes tail up for floats and tail down in 6 gallon increments.
  4. #3364
    Sep 2002
    1,026
  5. #3365
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY & Middlebury, VT
    3,147
    Yes tragic. I hope the fatalities are limited to 2 as stated. I read rumors of possibly more.
    The track on the Cherokee showed it was on its 4th lap downwind doing touch and goes at the field after coming over from the coast.
    No info on the cub.
  6. #3366
    11,670
    Thanks BC12D-4-85 thanked for this post
  7. #3367
    4,713
    Thanks Glenn. I sent it to several of my pilot friends that were rated at Brown's.
  8. #3368
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,472
    I found it surprising that the commentator suggested ADS-B In for the seaplanes but did not strongly suggest they should have a VHF radio.
    I'm not saying radio would have prevented the accident but, without it, the J3 crew may not have even have known which runway was active at Winter Haven.
  9. #3369
    13,237
    Thanks Glenn. That pretty much jibes with what I suspected. The low wing airplane .... declaring short approach ..... left turn with the CFI in the right seat with his vision obscured.... letting down into the J-3's path ..... the J-3 looking straight ahead, not up into the sun. A sad day.
    I was instructing in a Cherokee doing landings at the busy NORDO OWD airport landing east. When on short final I spotted the outboard half of the wing of a Seabee sticking out from beneath the plane. We went around. When we landed the chief pilot who had seen the whole thing had the Seabee pulled to one side of the runway giving him a talking to about landing straight in without following a traffic pattern. Low wings and high wings don't mix in a traffic pattern very well. The Seabee never saw us at all.
    NX1PA
    Thanks Bowie thanked for this post
    Likes DENNY liked this post
  10. #3370
    aktango58's Avatar
    18AA
    10,066
    Quote Originally Posted by frequent_flyer View Post
    I find it annoying that even AOPA has bought into ADSB as the 'be all end all' of traffic avoidance.
    The unapproved iPad technology with any of the pilot apps will show you way more traffic than ADSB- it picks up transponders!!
    Also, there seems to be lots of chatter about NORDO ops, but how about the instructor making laps with short approachs? Seems to me that seaplane base is well used, so the instructor should have knowledge that the little float planes will be moving in these areas at these altitudes; if one is flying abnormal approach procedures it would seem a good idea to be aware that your approach might intercept a well used flight altitude and route.
    Sad deal, sorry to all involved. Hope we can learn something from the.
    Likes skywagon8a, RaisedByWolves, Willie liked this post
  11. #3371
    May 2021
    Arizona, USA
    1,472
    The iPad has no built in capability to receive a transponder, 1090 ES, or UAT. It must rely on some other hardware receiver, not just an app, to display any traffic.
    A mode C transponder transmits no position information. If only the raw squawk data is received the best a receiver can do is estimate range from signal strength and, if equipped with a directional antenna system, a very approximate azimuth. (ZAON PCAS and FLARM both provided range only capability before ADS-B)
    Position data for transponder only aircraft can be derived from air traffic control radar (as range and bearing) and can be included in the TIS uplink. Still requires more than an iPad to receive and display that data.
  12. #3372
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,196
    The ASD-B has always been about control and tracking not safety. There are several better ways to show traffic, cheaper and simpler than the ADS-B with two different freq.’s , ant. Locations and in and out receivers . Too much freedom with people flying around the country and no tracking.
    Likes skywagon8a, 180_jeff liked this post
  13. #3373
    4,713
    For my non-electric PA-11 I had an ICOM handheld radio with compatible PTT and two place intercom with 9v battery. Not sure what might have helped in this case but they are available reasonably priced.
    Likes Brandsman liked this post
  14. #3374
    12,944
    Yes, I’m amazed they haven’t had separation issues in past, with Nordic seaplanes coming and going right under the traffic pattern of Winter Haven. Sad deal in any case. That seaplane base is a busy place at times.
  15. #3375
    Jan 2021
    Nevada
    161
    Quote Originally Posted by algonquin View Post
    I respect your right to your opinion, but I can't imagine a scenario where I could agree with a statement that starts "too much Freedom." Can't imagine such a thing. Sorry but as someone who grew up in a military family and spent a lot of time with the (US) military myself, that statement really gets under my skin. You have the right to that opinion and certainly to state it openly without recourse, and I will defend with my life those rights. You're not a bad guy for having that opinion or stating it. But "Too much freedom" just doesn't sit right with me.
    I wish I didn't feel compelled to state that.
    Thanks mixer thanked for this post
    Likes mixer, cub yellow, 180_jeff, AKjurnees liked this post
  16. #3376
    SJ's Avatar
    Jan 2002
    Northwest Arkansas
    16,249
    We’ve debated adsb ad nauseam. No need to rehash that on this thread.
    Thanks 40m thanked for this post
    Likes hotrod180 liked this post
  17. #3377
    11,670
    I have an icom in both my Cubs with external coat hangers. They work great, maybe too great. Problem in busy Unicom airspace is your picking up chatter from 80 miles away. It gets stepped on, import jargon, and sometimes unable to understand any of it being all mixed up.
    After awhile your listening but really don't hear anything.
  18. #3378
    May 2021
    Arizona, USA
    1,472
    Quote Originally Posted by RedOwlAirfield View Post
    Perhaps there ought to be a very prominent SARCASM emoji. His meaning was clear to me.
    Thanks algonquin thanked for this post
    Likes mixer, hotrod180, Brandsman liked this post
  19. #3379
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    453
    I put a Stratux receiver in our J3. It is useful in the pattern, but, with the lack of space in the cockpit, it can also be a distraction. Handheld Icom also. Seldom talk, mostly listen.
    Likes mixer liked this post
  20. #3380
    nd
    3,997
    just thinking? i wonder how many car accidents there is every day in this country. going home a few days ago, met a old guy coming down the 4 lane highway the wrong way. he didnt have a clue what he was doing. being alert is a big thing.
  21. #3381
    Dec 2009
    Michigan
    216
    Maybe we've gotten to point where we depend on, spend time watching, and believe it makes us safe to give attention to an inside cockpit gadget for traffic avoidance, while compromising attention we have to See and Avoid traffic.
    Thanks Waldo M thanked for this post
    Likes kase, cubdriver2 liked this post
  22. #3382
    4,713
    Up here, they (who's them?) have started partitioning congested airspace into smaller discrete areas via unique CTAF frequencies. Airports have them already, but areas like National Parks and popular recreational spots get them assigned. Where you live there''s more of everything so maybe that's not feasible due to a lack of available frequencies.
  23. #3383
    3,320
    I rely on Look/See/Radio, not always that good!!! A white Cub/Cessna will just fade away over snow even as I am looking at it. Having at least a radio would have allowed both aircraft to communicate position.
    Likes algonquin, 40m, Brandsman liked this post
  24. #3384
    Tx
    5,000
    Oops, darn it...
    Surprised the airport didn’t have right traffic so they don’t overfly the seaplane base pattern
    Likes kestrel, mam90, algonquin, 39-J3, Brandsman liked this post
  25. #3385
    13,237
    Quote Originally Posted by bcone1381 View Post
    Maybe? I've been preaching that for 50+ years. The influx of "glass" cockpits has increased the dependency upon the inside. Some of it can be blamed on the FAA when they started requiring the use of instruments before solo. That pushed the new pilots inside the cockpit rather than looking outside.
    NX1PA
    Likes supercrow, mixer, BC12D-4-85 liked this post
  26. #3386
    CubCruiser's Avatar
    Jan 2009
    Ormond Beach, FLA www.KidsFlyCubs.org
    239
    Instrument training is not required pre-solo.
    Daryl Hickman, ATP, CFI, XYZ, PDQ
    N452SP 2015 American Legend Cub
    N73TZ 1951 Cessna Bird Dog
    http://www.CubFlying.com
    http://www.KidsFlyCubs.org
  27. #3387
    May 2021
    Arizona, USA
    1,472
    Quote Originally Posted by CubCruiser View Post
    Not required but is recommended. May I suggest a review of Chapter 3 of the "Airplane Flying Handbook" which includes a description of the "integrated" or "composite" method of flight instruction.
    "When introducing basic flight maneuvers to a beginning pilot, it is recommended that the “integrated” or “composite” method offlight instruction be used. This means the use of outside references and flight instruments to establish and maintain desired flight attitudes and airplane performance. When beginning pilots use this technique, they achieve a more precise and competent overall piloting ability. Although this method of airplane control may become second nature with experience, the beginning pilot needs to make a determined effort to master the technique. In all cases, a pilot’s visual skills need to be sufficiently developed for long-term, safe, and effective aircraft control. "
    ref - https://www.faa.gov/sites/faa.gov/fi...04_afh_ch3.pdf
    Last edited by frequent_flyer; 03-12-2023 at 07:53 AM. Reason: delete duplicate "required"
    Thanks skywagon8a thanked for this post
  28. #3388
    Sep 2002
    1,026
    If you want to know how the up and coming pilots feel, try reading the comments associated with the AOPA video. Some of the outrage expressed that an airplane is allowed to operate without a radio and ADS-B is a sign of what’s likely to come, eventually.
  29. #3389
    12,944
    For me, it’s difficult to understand the apparent acceptance of overlapping traffic patterns between the airport and Brown’s. I wonder if they’ve had discussions to try to establish better separation.
    There is no way I’d want to work landings and takeoffs right under a busy student training pattern. Maybe they have tried to sort this out, but regardless of see and avoid, ADS-B or any other safeguard, that just seems like an accident waiting to happen, and I’m betting the attorneys are lining up.
    Likes kestrel, tedwaltman1, Brandsman liked this post
  30. #3390
    May 2021
    Arizona, USA
    1,472
    Sometimes the obvious doesn't seem obvious without the wisdom of hindsight. 2 killed in a midair between a Robinson and a PA-28 at KCHD about 2 years ago. Overlapping traffic patterns had worked fine until the PA-28 did a short approach. Many years earlier 4 killed in a midair at P48 when a J3 on downwind was hit by a glider doing the last loop of an aerobatic demo ride. The glider was in the "box" but the box and downwind overlapped.
    I have refused to tow when I didn't like a conflicting traffic situation. Another tow pilot jumped in and carried on. No accident so I suppose I was being over cautious, or maybe not.
  31. #3391
    8,708
    Overlapping patterns???
  32. #3392
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,196
    Sorry for the confusion, my statement was sarcasm. Anyway after flying 24 years in the Army I’ve seen some busy wild places. Most of the time there were fields for training and fields for daily ops. My best guess was we were all on the same sheet of music, so min. Conflicts. There were entry and exit points, alt.’s published, and patterns. Much easier to pull off when everyone has the game plan and adhere’s to it. The Browns run a good operation and truly sad when something like this happens.
    Likes skywagon8a, tedwaltman1 liked this post
  33. #3393
    Sep 2002
    1,026
    That’s the problem when evaluating safety- but IMO it’s important to remember that the absence of an accident does not define safety. I’ve said no plenty of times when others went ahead and made the flight. In all but one they made it just fine, but it didn’t mean it was safe.
    Likes kestrel liked this post
  34. #3394
    Farmboy's Avatar
    Jan 2016
    3,147
    I just got back from a 4 day trip down through FL and back, and the density level of traffic in FL is quite amazing.
    I didn’t watch the video(s) as I prefer to have my own interpretation, but AOPA seems to be a bit lost these days if they are jumping on the “YouTube accident review” wagon. We already have yahoos doing that.
    The polk school Cherokee came over to shoot touch and goes at winter haven….. because it’s too congested at home?
  35. #3395
    CubCruiser's Avatar
    Jan 2009
    239
    Quote Originally Posted by Farmboy View Post
    ...The polk school Cherokee came over to shoot touch and goes at winter haven….. because it’s too congested at home?
    Yes, now that Amazon is a major tenant at Lakeland-Linder, pattern work forces them to move elsewhere. If things keep progressing as they are, I suspect Sun n Fun will be pushed out in due time. It has already caused modifications of the layout for the show.
    I transit this Alert area nearly everyday to get to a quiet grass strip. I do so at 500' or lower given the extreme amount of training traffic above every day. It's not uncommon to have 7 training aircraft in the pattern at my home airport extending the pattern more than the 3.2 miles that is the diameter of the Class Delta. A poor situation for developing consistency and saving the student time and money. So many of us travel away from "home" to get the job done.
    Daryl
    Thanks tedwaltman1 thanked for this post
  36. #3396
    12,944
    Before you condemn AOPA for being "Lost" by posting these videos, perhaps you might want to WATCH one or two of them first. These are not Bronco Dude or Dipstick Dan videos. In fact, the idea is to get some RATIONAL and non accusatory INFORMATION out there, instead of the other videos. Richard McSpadden is very knowledgeable and offers very carefully considered brief explanations of what happened, without casting blame. I think they are very well done, and every one I've watched to date provides some very basic (and public) information that the news media didn't cover. That extra bit of coverage, by a pilot, is often important to understanding the scenario. Personally, at first I was concerned that this wasn't a good idea, but after watching a few of these, they are well done, very respectful to the parties involved, and offer some idea of the scenario, from the perspective of a pilot, as opposed to the news media.
    Secondly, the comment about the Polk Warrior going to Winter Haven because their home drome is congested? As a CFI, I always try to get "students" (even "students" who hold an ATP) to new airports with different procedures/patterns/problems. That's all part of comprehensive instruction. Operating in a congested environment is also important for training, but a variety of environments is essential for well rounded pilots in my opinion.
    Others have commented about the "short approach" by the Warrior crew. Looking at the evidence, I thought that instructor was doing a great job encouraging the student to fly fairly tight patterns. In any case, none of those patterns they flew were what I'd call a "short approach", but that's me. Unfortunately, that may not have been the best environment to fly tight patterns, but....
    Thanks tedwaltman1, Waldo M, h2oavi8r thanked for this post
    Likes Steve Pierce, kestrel, Brandsman liked this post
  37. #3397
    22,902
    Watch the video Peter, I think Richard did an excellent job as he did on the B17/P63 mid air.
    I am really surprised at some of the comments here. I wonder if the commenters watched the same video I did.
    As for ADS-B, I find it to be a useful tool, not my only tool but a tool.
    Likes JeffP, Waldo M, kestrel, Gordon Misch liked this post
  38. #3398
    Waldo M's Avatar
    Jan 2018
    217
    I think Richard McSpadden does an excellent job with these accident reviews. He makes no presumptions; he simply looks at situations that may have been a contributing factor and discusses strategies to avoid them. His observations are worth consideration.
    When AOPA presented their first one, I had the same reaction as Farmboy before I watched it. In the past, I had started to watch videos from other "analysts" and shut them off before I was 60 seconds into them. After that, I never clicked on them in the first place. I only played Mr. McSpadden's first accident analysis because I had met the man and respected him.
    I will say the the multitude of comments after the piece reveal that there are too many pilots out there that are truly clueless. They reveal an over reliance on and a misunderstanding of technology as well as an ignorance of the aviation world outside of their small slice of experience.
    I don't have an aversion to tech tools and in fact use them when flying an airplane with no electrical system. Like most, I always monitor a portable comm radio and use an iPad, ForeFlight app, and ADS B receiver when flying into an area that will likely have some traffic. All that is great stuff, but none of it indicates all the traffic in the area. Thats why the "glass" in the cockpit that I constantly monitor is the windshield.
  39. #3399
    aktango58's Avatar
    18AA
    10,066
    Most apps have reception from the GPS, which gives lots of interesting data. I am not the tech guru, but I can tell you from experience that when Alaska Airlines used to burn up my back side into Sitka the very expensive FAA funded Capstone box would not indicate their location, but my iPad would show them every time.
    On to our actual discussion...
    Between sun in a pilot's eyes, distractions, (two planes flown by students learning new things), and some bad luck this is a sad deal. As a pilot and instructor my true interest is how can we reduce this type of accident?
    While we sometimes seem to think aviation is shrinking, we are seeing an influx in people doing quick schools with the desire to get in on the airlines hiring frenzy. Get hours, get ticket, get hired. What is worse is as urban sprawl continues, little airports are going away and neighbors are upping the complaints- forcing more restricted airspace use which compacts everyone into a tighter space.
    As stated prior, if you read many comments on the YouTube, or on the Facebook forums it becomes startling how much basic knowledge is missing from so many. Worse, lots of them don't realize and probably don't care they don't know.
    Bottom line for me is the intent to find the brightest lights I can find, make them flash, look outside, glance on occasion at any traffic data I might get inside, ask passengers to look for traffic and point it out, and just remember that even if I am paranoid, it does not mean that someone out there won't try to run me over again!!
    FYI: I hate flying down the highway corridor from the north into Anchorage on a nice day. so many pilots busy finishing up getting their electronics tuned in and just not watching! Out of I think three trips last summer I had near misses on two, one of them we were watching the Bonanza for a long ways come our way and I kept edging away and it never saw us. mountains on one side and restricted on the other!
    Likes cubscout, skywagon8a, Waldo M, Bowie liked this post
  40. #3400
    May 2021
    Arizona, USA
    1,472
    Perhaps it would help if you said what your iPad was actually connected to. A GPS receiver will provide nothing except information about your own aircraft's position and movement. If traffic positions were displayed there must have been something else involved.
  1. oops
    By 907cub in forum Cafe Supercub
    Last Post: 05-04-2012, 09:18 AM
  2. Oops
    By cubdriver2 in forum Ski Flying Forum
    Last Post: 03-04-2012, 07:25 PM
  3. big oops!
    By Randy in forum Cafe Supercub
    Last Post: 03-14-2007, 09:35 AM
  4. Darn temperture dropped
    By Alex Clark in forum Cafe Supercub
    Last Post: 11-02-2004, 03:32 AM
