Page 77 of 83 FirstFirst ... 27677576777879 ... LastLast
Results 3,041 to 3,080 of 3317
Thread: Oops, darn it...
  1. #3041
    12,530
    Quote Originally Posted by Richgj3 View Post
    Bolt and nut missing (assumes the nut was ever there.)
    This is why I never put a castle nut on without putting in the cotter pin. This even if I think I may have to remove it again. It is too easy to forget or miss an important one.
    Likes DENNY, Richgj3, algonquin liked this post
  2. #3042
    4,114
    And flag anything that is only partly done with bright colored masking tape, and a notation if not obvious.
  3. #3043
    Nov 2017
    Anchorage, AK
    16
    I’m new to the DHC-3 this season and learning every day. Garrett-12 on EDO 7850 floats. Observations in just under 250hrs. Amazing performance! The controls are smooth and you have to remind yourself that you are flying an 8000lb airplane because it doesn’t feel like it. If you feel a slight vibration in your feet trim the rudder. The cannon plugs for the fuel sending units loosened enough to effect the fuel quantity gauge. The cylinder release screw on my S&W 629 pistol that I carry in the airplane came loose (not aircraft related but interesting).
    An old DHC-3 1340 pilot shared a story when he lost the elevator jackscrew in flight and had to have all his passenger run to the rear to maintain altitude. Was able to land safely.
    I’ve had an inflight rudder failure in a Cub and was able to maneuver to a safe landing. So these Otter incidents have me very concerned very alert.
    Likes DanaD, Scooter7779h liked this post
  4. #3044
    4,013
    ^^^^What's normal cruise speed and how close is that to maximum? Edit: Like Vno or Vne?
  5. #3045
    4,760
    An extremely high time Garrett Otter pilot told me once that the turbine has little effect on 'forward' speeds but makes a huge increase in climbing speeds. Makes sense as the design of the wings and airframe will set airspeeds no matter how much horsepower is under the cowl.
    Likes 62E liked this post
  6. #3046
    4,013
    Web, here's why I ask about airspeed> https://data.ntsb.gov/Docket/?NTSBNumber=ANC15LA037
    Read the three Docket files for their analysis.
    Thanks sjohnson thanked for this post
  7. #3047
    4,760
    My point is that the limits like Vne are dictated by the airframe, not the engine. Now if someone exceeded an airspeed limit, then damage is probably going to occur.
  8. #3048
    4,013
    Web, yes I agree. Which is why above I asked Yetnacruiser what indicated and true airspeeds were experienced during normal ops, and in what configuration?
  9. #3049
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,323
    I have towed with several different aircraft. I alway set trim after landing so I was in trim for the next tow. Did the accident report indicate how far out of trim this tug was?
    I found the report. It happened in May of 1984. Funny how time flys as we get older. . Not much detail. No mention of trim position. PIC did not have a current BFR and was fairly low time. But that’s not what killed him. The airplane got re-covered and its annual inspection 30 hours before by the same shop. They were assigned the bulk of the responsibility.
    They found the bolt but never found a nut or cotter pin.
    Good advice to set the trim.
  10. #3050
    12,348
    Web,
    Not sure about the Otter, but when DH converted to the Turbo Beaver, they were required to reduce Vne to the top of the “normal operating range”. That eliminated the yellow arc, which turbines don’t have. Vne on a recon Beaver is quite a bit higher than a Turbo Beaver. At least the DHC-2 MK 3s that came out of the factory.
  11. #3051
    4,013
    If readers do nothing else at least read the "Aircraft Performance Study" linked in #3022 and #3046. Note the difference between the calculated Calibrated and True Airspeeds. Then ask yourself which one the airframe is most affected by?
  12. #3052
    frequent_flyer's Avatar
    May 2021
    Arizona, USA
    1,032
    INote the difference between the calculated Calibrated and True Airspeeds. Then ask yourself which one the airframe is most affected by?
    I think the answer is EAS (equivalent air speed) but few aircraft display EAS. Many aircraft do have Vmo reduced at increasing altitude to take account of the increasing difference beween CAS and EAS. This Vmo vs altitude table may be included in the TCDS and may also be required to be placarded on the instrument panel.
  13. #3053
    4,013
    One more question: At any time during flight - takeoff to landing - can propeller blown air over the empennage exceed V-limited airspeed that's sensed by the pitot-static system?
  14. #3054
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    318
    There are a lot of operators flying turbine otters, year after year after year. Look a the pics in the links you posted. The smoked rivets are pretty much a dead giveaway as to what started that ball rolling. If this was some huge issue, outfits like AWA would have lost the otters years ago. I think poor maintenance and even poorer preflights are probably a much larger cause of problems than some prop blast over the tails.
  15. #3055
    Aug 2002
    Talkeetna Alaska
    314
    If memory serves, redline for turbine Otter landplane is 115 kts, seaplane 124 kts IAS. I've heard it is not easy to exceed those speeds in level flight by more than a few knots, especially if loaded.
  16. #3056
    Oct 2003
    East Boston
    151
    If it lawn darted into the water and the tails aren't falling off these aircraft on a regular basis pilot incapacitation is the most likely cause.
  17. #3057
    3,972
    I captured a screen shot of the tail end of that flight off FR24,
    looks like it had been cruising at 700' doing 80 knots.
    Pretty normal flight profile for these aircraft.
    I saw two turbine otters (probably Kenmore's) flying the same path a day or two later.
Name:	turbine otter flight path.jpg
  18. #3058
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,185
    I got a rare call for crane service on a Sunday, usually when that happens it's a overweight trucker stuck at the local Port of Entry until he gets lightened up. A rare chance to show my crane AND plane chops all at the same time. The Piper Saratoga landed gear up, pilot just forgot, I joshed him a bit until I remembered the times I've landed (Datum retracts) wheels down on snow, and skis down on the grass.
    I rejected the first front rigging point, suggested by one of the helpers, of using the lift lug on the engine, the one that's there to pick the engine, not the whole front of the plane. Then I rejected another's idea of rigging to the motor mount, in front of the rubber mounts. I pointed out that using the mount structure that's bolted to the firewall, would not torque on the rubber donuts, and being "the crane guy", we did it my way..... The rear pick point, using a 4" wide strap to spread the load as much as possible, was directly under a fuselage station, didn't want to oil can that surprisingly thin tin. We took our time, made one adjustment on the rigging length, and then she levitated up at the normal AOA just high enough to let the pilot (finally) put the gear down. Based local, he then was able to tow it to his hangar. Fun job, beat swinging trusses. The funds earned are earmarked to go directly to "airplane stuff." Best of all, no local media coverage whatsoever.
ID:	62822   Click image for larger version.
    Likes utb 44E, jrussl, 180Marty, Farmboy, RVBottomly and 3 others liked this post
  19. #3059
    S2D's Avatar
    May 2002
    Montana
    4,289
    Until now
    Likes MT12, grbreen liked this post
  20. #3060
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,185
    You guys don't count. No N number visible, made sure of that.
  21. #3061
    4,760
    Saratoga?
    Likes courierguy, hotrod180 liked this post
  22. #3062
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,323
    Saratoga?
    The rare high wing version. .
    That’s ok. I can’t identify a thing on that crane.
    Likes skywagon8a, hotrod180 liked this post
  23. #3063
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,185
    That's what I was told, a Saratoga. I do know the fuselage skin was like tin foil, kinda surprised me what light gauge it seemed to be, gets the job done though.
    Thinking back, after I hoisted it up high enough for him to put the gear down, and he motioned to me to let 'er down, I should have asked first, "you SURE the gear is down?"
  24. #3064
    Sep 2004
    Anchorage
    520
    No wing struts, looks like a 210
  25. #3065
    4,013
    Cessna 177RG? Triangular panel in front side windows.
    Likes Richgj3 liked this post
  26. #3066
    Dec 2014
    133
    I think you are correct,, looks like the Cardinal I fly in Texas.
  27. #3067
    Apr 2017
    ND
    193
    We lost another good pilot and person. Doug will be missed> https://aviation-safety.net/wikibase/281506
    It's August and hunting season so be careful.
    I read the ntsb report on this crash, and the trim was full nose up. ???
    In every picture I find of this airplane, including at a different accident, the stab is set full nose up.
    Why is that?
  28. #3068
    4,013
    Quote Originally Posted by MoJo View Post
    Why is that?
    That's a good question ( NTSB ANC22FA066). I spoke with a local FSDO inspector that first mentioned the trim position. Driving around the local airports I saw several PA-12's on conventional gear with PA-18 empennage and long engine mounts (and most with upgraded engines/props). They had their trim-horizontal stabilizer nose resting near or full down. Most PA-18's not as much. This accident plane also had large tires and a Crosswinds STOL kit but I have no idea about that relationship to the trim.
    Maybe PA-12 owners could comment on their typical trim position inflight or after landing?
  29. #3069
    2,983
    I don't know the plane or the pilot. Unless I have a pretty heavy load I usually do all my landings with full nose up trim in case I need to really get on the brakes. Takeoff is 9 turns nose down , unless I re trim for takeoff as I taxi back to the hanger mine will be at or close to full nose up when parked. A long mount 12 with a big motor and Borer will likely use more nose up trim, could be just how that plane is set up. Some pilots just don't use the trim much and just strong arm the entire flight. It is really just wild ass guesses unless you knew the pilot and plane.
  30. #3070
    4,013
    Two pics of the accident aircraft prior show the trim to be at or near full nose up when at rest. The only reason it was discussed locally after the accident is that we, as current non-owners of that model, wondered why that position? That's all and it's not being guessed by me whether or not it contributed to the crash. I owned a PA-12-180 for a few years ('97-2001) on wheels, skis, and floats but don't recall the typical trim position in flight or after landing. And, we knew the pilot and plane for years.
  31. #3071
    stewartb's Avatar
    Wolf Lake, AK
    7,748
    The report says he was at gross. If he was fighting "violent" winds he was likely flying at or below Va, and when heavy having the trim set for nose up makes sense. As it does for lots of planes post-landing when the pilot doesn't reset it for the next flight. Personally I trim as part of my pre-takeoff routine, not post-landing, so my trim in parking is typically near the nose up limit.
  32. #3072
    4,013
    Here's the Preliminary Report for N3937M PA-12. See Page 2 for 08/11/2022 Arctic Village Alaska> https://data.ntsb.gov/carol-main-pub...th=8&year=2022
  33. #3073
    12,530
    Here's a brief flight in a turbine Otter.
    Likes JeffP liked this post
  34. #3074
    4,013
    Now fill the plane with passengers and fuel then repeat the slow flight-stall series from about 04:00 on. In gusty conditions preferably. I don't know - maybe there's a safety margin in there somewhere.
  35. #3075
    12,530
    Notice at 5:20 he says at full gross weight the stall speed is over 100. I didn't hear him mention cruise speed, but at full gross there doesn't appear to be much margin
  36. #3076
    4,013
    ^^^^Yes. and ~torque will roll you inverted, and ~ full power on the tail stalls and it snaps over straight down (my words - watch for actual text). I bet that pilot is very good at what he's does, but some may not be as well qualified.
    Then there's this legalize word salad regarding an Otter crash in Alaska. Note the STOL kit data and rear CG limits tested. https://www.casemine.com/judgement/u...53d00e93023f2f
  37. #3077
    12,530
  38. #3078
    Jul 2012
    Montana
    534
    in my 12's, with long mounts, the more weight I add the more the trim moves to nose down for cruise and landing, as all added weight goes to a rearward CG. Empty I land with full nose up trim, at gross I am probably several turns towards nose down on landing. With a gross weight increase and my ELT way back by the tail at full gross my trim is WAY nose down in flight.
  39. #3079
    windy's Avatar
    Dec 2005
    Utah
    786
    Quote Originally Posted by MT12 View Post
    In my PA-12 with 180hp & short mount, my trim is always somewhere in the middle. After I take off, I set the trim for cruise & never have to adjust it again for that flight. When slowing down for landing, I add a notches of flaps to counteract the pitch down. No horsing around needed. The controls are light enough to fly with two fingers.
    The only time the trim goes to full nose up or full nose down is at the annual.
    Thanks mixer, 12Geezer2 thanked for this post
  40. #3080
    12,348
    I noticed that as well. That’s quite different than what appears in the print version, which makes MUCH more sense.
    There, he states that after takeoff, flaps up and 90 knots for climb. He then quotes the pilot: “The biggest gotcha is that the Otter can stall at nearly cruise speed with a heavy load when the flaps are up and the pilot pulls hard during a steep turn.” He went on: “Then, the torque can roll the airplane inverted.” The article continues: “Steep turns with partial flaps, however, are extremely forgiving and the Otter can turn around using minimal real estate.”
    That is classic deHavilland flight characteristic. When I checked out in the Beaver, Jack Cory really beat me up with turns…..slow down in anticipation, lower some flap, then turn. At altitude, attempting steep turns with no flap resulted in pretty impressive stalls. And flaps in these planes require some monkey motion: Select flaps to down, then pump them down to the desired position. Not something you’re going to do once you’re started in a turn.
    The Baron STOL kit was specifically address this characteristic. I’ve never flown a Baron wing Beaver, but a stock plane will turn with the best….IF you have flaps deployed.
    Equipped with a Baron STOL kit, I can’t believe that plane stalls at 100 knots in level flight.
  1. oops
    By 907cub in forum Cafe Supercub
    Last Post: 05-04-2012, 09:18 AM
  2. Oops
    By cubdriver2 in forum Ski Flying Forum
    Last Post: 03-04-2012, 07:25 PM
  3. big oops!
    By Randy in forum Cafe Supercub
    Last Post: 03-14-2007, 09:35 AM
  4. Darn temperture dropped
    By Alex Clark in forum Cafe Supercub
    Last Post: 11-02-2004, 03:32 AM
