Page 83 of 84 FirstFirst ... 337381828384 LastLast
Results 3,281 to 3,320 of 3343
Thread: Oops, darn it...
  1. #3281
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,219
    [QUOTE=stid2677;836219]This one is a makes you wonder, anyone seen this? How the heck did he fall out?
    https://aviation-safety.net/wikibase/300307[/QUOTE
    Over at the Bearhawk forum, it's thought that a bird strike took out the elevator or tail function in some fashion. https://www.abc27.com/news/top-stori...nover-twp/amp/
  2. #3282
    Dec 2014
    152
    I was told the tail VGs came out because of the tail strake on the Boundry Layer Research VGs for the PA18.
    After reading the report it appears the altitude this pilot was doing stalls at was 400 feet?
    Our camp is near the crash sight,, I have a couple hundred hours flying in that area,, Mr Gary is correct about the winds,, even when Fairbanks is calm, there is most often an easterly wind at 10 mph or so, usually a burble too coming from a couple high spots to the east and south. His GPS flight track shows an average of 1500 ft AGL and the terrain elevation near the crash sight is 400 ft ish, so to me it looks like he was doing his airwork at 900 to 1000 ft AGL. Lower than I would do so,, any thoughts on the skis maybe contributing to the airflow over the tail in a high AOA???
  3. #3283
    12,689
    Quote Originally Posted by stid2677 View Post
    Definitely a possibility. Chances are good the flight testing for approval of the VGs did not include flights with skis installed. Thus ....... low altitude initial testing would not be a very wise decision.
    Likes stid2677 liked this post
  4. #3284
    Dec 2014
    152
    [QUOTE=courierguy;836228]
    A bird strike does make more sense,, I wonder if this was a 1- 2 punch, the original issue may have been the right rudder clevis coming loose, and then they hit the bird,, he removes his belt to lean out and look, then the tail comes apart, throwing him out???? Have a friend that knew the PIC said he was well respected.
  5. #3285
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY & Middlebury, VT
    3,016
    This crash was a tragic incident, like all, but this borders on bizarre.
    Facts : Ron Snyder and Mike Bowen, both pilots from Farmers Pride in PA had been flying that day. They left Wyoming Valley (PA) to go home, and a few minutes later in a stable cruise attitude there was a sudden pitch down and 400’ drop in altitude. Ron departed the aircraft, and all parts fell nearly vertical. Both men passed.
    Witnessed events: witness reports seeing geese near flight path but not seeing contact. A witness reported seeing the sudden pitch change and Ron leaving the aircraft.
    Knowns : Ron had a reported weird yaw when he banked into a turn, and another pilot flew and noted what Ron was describing but neither could pinpoint a cause, nor did either feel it was an unsafe condition, just an anomaly compared to others. Otherwise Ron had quite a number of hours flying it after completing the build and all seemed fine.
    The investigation narrowed down to the tail area.
    - Left stabilizer and elevator largely intact and bent 90* around the tail, to a trailing position over the tail wheel. Trim tab intact.
    - Right Stab has impact damage in leading edge, and was folded down and aft, ripping out the front bolt from the attachment angle at the fuselage. Right Trim tab ripped off elevator but still attached by control arm.
    - Vertical stabilizer was essentially destroyed, but pieced together shows breaks in leading edge; breaks, kinks and bends on internal braces and tubes; and tailpost broken in 2 locations.
    Conjecture:
    While a goose strike was expected, no evidence of any bird strike could be found.
    Other evidence gives them reasons to believe that Ron may have been ejected vertically through the skylight, where he then impacted the tail surfaces, rendering the airplane uncontrollable.
    It is a complete mystery as to why, or when, Ron unbuckled his lap belt and shoulder harness. He was visibly seen latching it at Wyoming Valley airport prior to taxiing. The harness was a Crow assembly.
    There is no historical evidence nor does it seem likely but IF the right trim tab had developed a flutter or had some condition that ripped it from its hinge, during the time it was ripping off would be an extremely wild ride in the front seat. With no belt fastened it would easily toss a pilot out.
    I truly hope that more meaningful evidence points to a greater smoking gun than theory, but without in flight cameras it may be a hard one to ever understand.
    Transmitted from my FlightPhone on fingers…
    Thanks courierguy thanked for this post
    Likes stid2677, kestrel, Bowie liked this post
  6. #3286
    4,891
    https://aviation-safety.net/wikibase/wiki.php?id=191909
    Sounds like he started at 1000ft descended to 469 agl.
    Seems to me if I was going on a test flight I’d start a little higher.
  7. #3287
    12,520
    There is significant guidance related to recommended minimum altitudes for stall practice.
    From the Airplane Flying Handbook: “ It is recommended that stalls be practiced at an altitude that allows recovery no lower than 1,500 feet AGL for single-engine airplanes, or higher if recommended by the AFM/POH. Losing altitude during recovery from a stall is to be expected”
    From Private Pilot ACS: “The applicant demonstrates the ability to:Clear the area.Select an entry altitude that will allow the Task to be completed no lower than 1,500 feet AGL (ASEL, ASES) or 3,000 feet AGL (AMEL, AMES)”
    Note that this guidance states that RECOVERY must be complete by no less than 1500 feet agl. Further, while this recommendation is not regulatory, if one were to violate that guidance during a Private Pilot Practical Test, the pilot would fail the checkride, and be required to retest.
    Now, add to that the fact that this was not a routine flight training operation, but in fact a post maintenance flight test, specifically testing the flight characteristics of the addition of an aerodynamic modification which was specifically designed and installed to alter the stall characteristics of the subject airplane. Added to this, the aircraft was operated in a configuration not flight tested by the manufacturer of the VG kit.
    While I see nothing in this scenario to suggest any ugliness in the proposed flight, the argument to maintain significantly HIGHER flight test altitudes than are recommended for routine stall practice certainly seems compelling.
    I’ve conducted a lot of post maintenance flight tests, and those ALWAYS start above 3000 agl if stalls are to be demonstrated. To me that is a common sense safety precaution.
    In this case, it seems the Pilots choice of an exceptionally low height to demonstrate stalls was the cause of the accident.
    I’ve flown 7GCBC aircraft both with and without VGs, including considerable stall practice. I’ve never seen anything I would consider “unusual” in the stall characteristics of that aircraft. In an accelerated stall (steep bank with pull) the airplane exhibits an abrupt departure, but is fully recoverable using normal recovery techniques. Altitude loss can be significant in this regime. But the subject accident didn’t suggest any turning prior to the stall.
    i can’t imagine practicing full on stalls at the altitudes this pilot conducted them.
    Likes DENNY, Brandsman liked this post
  8. #3288
    4,045
    A Caravan crashed in the Seattle area yesterday, both occupants killed.
    Original conjecture was that it was a skydiving jump plane out of Harvey Field S43, which is just west of the crash site, however this was not the case.
    It was apparently owned or at least operated by Lake and Pen Air out of Alaska, and had been doing flights out of Renton KRTN all week.
    This flight involved a lot of maneuvering over the eventual crash site.
    N2069B
    2 dead after plane crashes, catches fire in field near Snohomish – KIRO 7 News Seattle
  9. #3289
    Vermont
    417
    How about: Pilot unbuckles for unknown reason, gets surprised by the birds, goes hard negative("hard dip") instinctively. Ejection and negative structural failure. Or collision with tail group.
    What's a go-around?
  10. #3290
    4,207
    One comment on the 7GCBC. I flew mine for 10 yrs in winter on Landis 2500 fixed skis (his were smaller 2000's), I tested and did lots slow flight running a trapline with a STOL kit, and never had what I'd call a hard to recover deep stall or tail stall. Maybe the VG's allow that. The elevator always worked reliably for me except at way forward CG. He was calculated 3" behind the front limit and 2" forward of the aft datum during the accident in the Final Report.
    During slow level flight forward visibility of lower flat terrain for me at 5'9" was lost under the cowl. This pilot was taller, but someone had modified his seat mount to allow further rear extension for presumably more leg room. That may have limited his forward view of the ground. Being too low to recover seems right.
  11. #3291
    12,689
    ...This pilot was taller, but someone had modified his seat mount to allow further rear extension for presumably more leg room. That may have limited his forward view of the ground. Being too low to recover seems right.
    Do you suppose this restricted the forward movement of the rear stick which limited down elevator for stall recovery?
  12. #3292
    4,207
    It's very likely but only if the rear control stick was installed. The Report doesn't mention its presence or absence. Bellanca offered control sticks that S-curved away from the rear of the front seat or forward panel area. I had more issues with the aft stick hitting the rear seat padding (or occupant's body) than the front seat, so flew with it removed and the exposed stub covered with a raised cover approved for their Scout model. I doubt he had it installed because of potential clearance issues but don't know.
    The left side seat bracket that was modified for more rear travel broke allowing those two support legs to detach from the airframe mounts.
  13. #3293
    Dec 2014
    152
    N2069B
    I saw an inview on this one,, they were doing flight test for a cargo pod STC,, something about modification to the current pod design.
    Thanks mvivion thanked for this post
  14. #3294
    Dec 2014
    152
    Any thoughts on the modified seat bracket possibly failing in flight?? At a high AOA more weight would be on the back of the seat, if it let go while almost at a stall, seems one would naturally pull back more on the stick since it would be your only point of contact.
  15. #3295
    4,207
    My thoughts are tempered by Cessna's known seat rail wear issues and initially a lack of adequate seat stops. Back went a C-185 seat for me only once on takeoff...grabbing the seaplane V-brace above the panel prevented a control problem. Pics (#9) of the broken seat brace can be viewed in the Public Docket available below.
    From Post #3240: It can be found in the accident Docket report under #11 Photo Array by going to CAROL basic search below and entering the NTSB number ANC17FA009:
    https://data.ntsb.gov/carol-main-public/basic-search
    I linked this flight test of VG's on a Beech earlier. Take the time to read it and note the engineer's process of evaluation. Quite different than the low and slow approach here:
    https://www.nar-associates.com/techn...ide_screen.pdf
  16. #3296
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,181
    Pete, also the Cardinals also had a lot higher angle of incidence and people would flair to a level picture and the wing would start loosing lift and it would slam down, nose low. Taught in them when they first came out.
    The Short 360 would get interesting when you got a bunch of ice, it would porpoise big when the tail loaded up.
  17. #3297
    4,207
    Route of the last flight for N2069B. Several prior tests as well. Might have included stalls according to one Alaskan news source:
    https://www.flightradar24.com/data/a...2069b#2e41b36c
    Edit: Speculation> https://www.pilotsofamerica.com/comm...eattle.140639/
  18. #3298
    12,689
    Flight testing can be dangerous, since something no one else has done is being learned about while operating the airplane at or beyond the limits of it's anticipated envelope. Sometimes something happens which is totally unrelated to that which you are investigating. The average airplane pilot/owner has no clues as to what paces any particular type of airplane has been put through in order for it to be operated safely by the average pilot.
  19. #3299
    22,352
    Thanks, I just read the NTSB report and somehow came up with that 400'.
  20. #3300
    4,045
    TV news is now reporting 4 people were on board. All killed.
    N2069B
  21. #3301
    Dec 2014
    152
    This is a video about the Caravan.
    https://www.youtube.com/watch?v=C2ji...el=blancolirio
  22. #3302
    aktango58's Avatar
    18AA
    9,929
    Seems to me lots of speculation.
    Lets leave the pontification out of this until there are some facts to determine the Why.
    Likes Paul Heinrich, MT12, tedwaltman1 liked this post
  23. #3303
    4,207
    Here's an update: https://www.seattletimes.com/seattle...a-test-flight/
    And here's type of work Raisbeck Engineeering undertakes: https://raisbeck.com/raisbeck_product/epic-caravan/
  24. #3304
    Dec 2014
    152
    I misunderstood the purpose of this thread,, I deleted my comments and will not participate any further.
    Likes JeffP liked this post
  25. #3305
    Grant's Avatar
    At Work.....
    2,077
    A buddy just texted this image - Not sure when it happened or where (maybe Maryland). Sounds like two people are alive but they are trying to get them down. Not sure how many are onboard. Just that two are alive.
    UPDATE - https://wjla.com/news/local/gallery/...n-road?photo=9
  26. #3306
    SJ's Avatar
    Jan 2002
    Northwest Arkansas
    16,008
  27. #3307
    Farmboy's Avatar
    Jan 2016
    3,016
    I looked at that yesterday as we have seen a few powerline related incidents recently.
    Powerline towers on approach to GAI average 140-160' AGL, 1.3 miles from the threshold, unmarked and unlighted. Pretty low on approach for a mooney, but his track approaching the airport shows potential weather diversions or indecision perhaps.
  28. #3308
    Formandfunction's Avatar
    May 2022
    65
  29. #3309
    12,520
    Quote Originally Posted by Formandfunction View Post
    I saw that one earlier today. I’ve never seen a plane that badly balled up in a “landing accident”. Gotta be more to this story. Terrible deal in any case.
    Likes DENNY, Richgj3, OLDCROWE liked this post
  30. #3310
    May 2022
    65
    Thought the same thing,so horribly balled up for a landing accident. There is literally nothing out in that area so they would have to have been doing touch n go's or slow flight in pattern Maybe. Possibly a stall spin
    Likes DENNY liked this post
  31. #3311
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    243
    The weather here on Sunday was garbage... 300 - 400 foot ceilings most of the day.
    Thanks Farmboy thanked for this post
  32. #3312
    4,207
    Recall the recent Caravan C-208 crash in Washington? Right wing came off or at least landed away from the fuselage. While waiting for the preliminary results read this:
    https://www.faasafety.gov/files/gsla...v01-071118.pdf
  33. #3313
    12,520
    Yow!!!
  34. #3314
    4,207
    They allegedly approached or may have exceeded Vmo plus pulled some "G's" as part of their testing. Still speculative of course and awaiting any results from focused NTSB metallurgy exams or airframe inspection.
  35. #3315
    12,689
    In reading post #2 my antennae were raised. Spins are stall maneuvers. Recovery from spins should be completed at low airspeeds in order to prevent an airframe overload. Why did this declared "Pilot DAR" allow the plane to accelerate to Vmo during recovery? This one admission makes me disregard any other comments he makes. Any airplane should not need to accelerate to any where near Vmo during spin recovery. I have never flown a Caravan, however I would still expect to be able to recover from a spin without exceeding 100 knots.
    Post #2: "I calculated a momentary peak rate of descent of 9600 FPM, at Vmo, and a 2.5G pull to recover the dive resulting from the spin recovery."
    Also pulling 2.5G at Vmo?????? What's with this guy?
  36. #3316
    22,352
    Having been around some flight test engineers working for the FAA this doesn't surprise me in the least. Performance take off for the PA18-150, accelerate to 35 mph, pull full flaps and climb at 45 mph. I voiced my concern for this testing, especially with a pilot with an FAA test pilot with 8 hrs tail wheel and even less in the Super Cub. It got heated and I did not attend anymore flight briefs until they ran the aircraft off the runway on a botched landing.
    Likes TxAgfisher, tedwaltman1, BC12D-4-85 liked this post
  37. #3317
    22,352
    Scary.
    I did learn a lot reading Aviation Maintenance Alerts (AC-43-16) when the FAA compiled and printed them. Never understood why they stopped.
  38. #3318
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    786
    As someone in the employ of a Caravan modifier, I am watching this with both great interest and sadness. Every test flight carries risks even when efforts are made to minimize and mitigate them. Sometimes what the FAA views as risky in a test plan has a disconnect from what we pilots know to be risky during actual operations.
    I did talk with some folks who have had the opportunity to test Caravans and the opinion was that this airplane had been put through the ringer, but also that it was a young airplane and not likely to have high cycles/fatigue issues. It is possible that a manufacturing defect existed causing a premature failure. Many questions unanswered at this time, and those I spoke with noted that ADS-B data has limitations compared to more detailed data systems.
    I hope the data survived so we can learn more. It is of little solace to the friends and families left behind, of course, but the best we can hope for at this point is to learn so it does not happen again.
    —Amy
    Likes DENNY, MT12, BC12D-4-85, 180Marty, Bill Rusk liked this post
  39. #3319
    4,207
    A local B-EX Caravan exceeded ~200 and ~10K during an IFR upset/stall/recovery. They survived but both wings are being replaced while awaiting the speedo mod planned for here. Tough platform for sure.
    For N2069B the accident plane discussed there were about 8 test flights recorded by Flightrader24. The prior use history and maintenance to these tests will likely be investigated.
  40. #3320
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,219
    Besides landing a Long EZ, apparently deadstick, (?) in a overall mountainous area with minimal damage to the plane and none to him, I really like the way he handled the press. This is the best feel good accident report I've heard of in a while.https://www.hjnews.com/news/accident...78e984ba9.html
    Hmmm, not dead stick, more details, draw your own conclusions. https://www.abc4.com/news/wasatch-fr...o-plane-crash/
  1. oops
    By 907cub in forum Cafe Supercub
    Last Post: 05-04-2012, 09:18 AM
  2. Oops
    By cubdriver2 in forum Ski Flying Forum
    Last Post: 03-04-2012, 07:25 PM
  3. big oops!
    By Randy in forum Cafe Supercub
    Last Post: 03-14-2007, 09:35 AM
  4. Darn temperture dropped
    By Alex Clark in forum Cafe Supercub
    Last Post: 11-02-2004, 03:32 AM
