Page 2 of 2 FirstFirst 12
Results 41 to 80 of 80
Thread: Cessna 180 rear seat?
  1. #41
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,600
    I have the BAS seats, I like them a lot. The plane is a two place plane most of the time anyway, but when we are going to be three or more I tell people to "bring pillows to sit on".
    sj
  2. #42
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    By the way, here is an article about an AD on the Atlee Dodge jump seats, regarding the seat belt installation.
    http://blog.aopa.org/vfr/?p=1217
    This is what sent me down the road asking about how the BAS style stacked up. I think there are a couple of seat belt attach options for the BAS depending on what serial number and age your plane might be.
  3. #43
    aktango58's Avatar
    18AA
    9,094
    I had a 57 180, and if memory is correct, the center belts attached to the bolt hole in the floor that the original rear seat back leg used, and the outside belts went to a structural hole on the sides, or a small bracket that was a quick rivet job to install
  4. #44
    9,373
    I'm nervous about a seat belt anchor being a "quick rivet job". I know that there are approved installations that are done this way. I have seen wrecks in which all of the rivets have sheared with the result not being to the benefit of the occupant. I would prefer a belt which was bolted into some primary structure.
  5. #45
    2,646
    Quote Originally Posted by Alex Clark View Post
    By the way, here is an article about an AD on the Atlee Dodge jump seats, regarding the seat belt installation. http://blog.aopa.org/vfr/?p=1217 .........
    Even though I have BAS seats, I found the article interesting. Thanks for posting it.
    I do wonder how attaching the seat belts to the original Cessna side brackets or not running the belts through the guide could result in the rear seat pax being ejected through the windshield. Esp the brackets-- the clip-on ring intended for the outboard seat belt attach attach ring as shown is only a couple of inches above the Cessna bracket.
  6. #46
    aktango58's Avatar
    18AA
    9,094
    My way of describing led you to the wrong impression, my fault.
    It has been years, but when I was doing the change I had a couple things happening, including ski fittings. The rivet job was not just a rivet onto a skin. The easy part as I recall was it was all above the floor, so you did not have to be lying on the floor, arm inside a little hole cutting your arm and reaching a bucking bar at an odd angle. Everything tied to the bulkhead area just forward of the baggage door.
    Primary structure for sure.
  7. #47
    4,655
    There's no excuse for poor seatbelt anchors. Add rear seat shoulder harnesseses, too. Simple stuff.
  8. #48
    9,373
    No fault, your remark reminded me of the seat belt attachment plate of perhaps .120" aluminum which was riveted to something. All of the many rivets which had held it in place had sheared with their tails remaining in the plate. Obviously it had been under-designed. I can not recall what type of airplane in which it had been installed. My only point being that no matter how strong that you think the parts may be, it is the fasteners and the structure to which the parts are fastened which need to have equal or greater strength requirements.
  9. #49
    aktango58's Avatar
    18AA
    9,094
    These types of discussions and exchanges of information sure remind me of why I spend time on this site.
    Engineers with slide rules and computers may design this stuff, but experience in seeing how it handled use is invaluable, and is helpful to those of us wanting to modify our stuff.
    One question on rivets, do they shear from being brittle, insufficient numbers, improper installation, or the wrong fastener for the job?
    Thanks for the info!
  10. #50
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,421
    Us engineers dont use slide rules anymore although I used to make it smoke!
  11. #51
    9,373
    ...One question on rivets, do they shear from being brittle, insufficient numbers, improper installation, or the wrong fastener for the job?
    There are numerous inputs as to the number of, the diameter of, the alloy of, etc. the rivets. The shear strength of each rivet is not that great. Figure that the shear strength of a particular alloy is xxxx psi. The area of a 1/8" diameter rivet (Pi*1/16*sq) is a very small percentage of one square inch. The bearing strength of the sheet into which the rivet is placed is part of the equation. There are many little things to look at in any little design. The failure strength of an assembly is no greater than the weakest component in that assembly. This discussion could go on forever, but I'm sure that you get the picture.
    Also in the case of a seat belt, each fastener/belt/anchor only has to hold half of a human times the load factor because there are two ends/fasteners for each belt.
  12. #52
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    I have done a little more research. The BAS seats use a Cessna seat rail as mounts while the Atlees use cargo rails.
    The BAS style can be removed and the original bench seat can be re-installed without hitting the rails. I believe the Atlee seats do not let you install the bench seat.
  13. #53
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    Also the BAS style seat-belt kit is not needed if your original seat-belts are anchored to the plane and not the set frame.
  14. #54
    DJ's Avatar
    Jan 2009
    Bolivia
    184
    correct the Atlees require drilling out rivets and removing the original seat front support brackets and putting the extruded aluminum side rails in their place. At least for later models.
  15. #55
    2,646
    "Seat front support brackets".... the early model bench seats mount with a bolt into a nutplate at a bracket a little ways aft of the rear door post on each side, and a bolt into a nutplate in the floor at centerline front and rear. No "support brackets" that I'm aware of. You have to unbolt the BAS seat's side slide tubes in order to reinstall the bench seat. I imagine you could do the same with the Dodge side rails, if they're bolted in, so the deciding factor with either would be whether the bench seat & floor rails conflicted.
  16. #56
    Dec 2015
    1
    The Atlee side rails are riveted in place and not removable. There for you can not reinstall the bench seat. I just installed the Lakeview (BAS) seats in my 170. There is a thread going over at backcountrypilot.
  17. #57
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,377
    Waterboy, That needs to be corrected......The Atlee side rails are not riveted in place. They are removable, fastened by multiple 10/32 structural countersunk screws into nutplates.
    However, the midway support bracket for the side rail and the floor mounted tracks may interfere with some other rear seats installations
    Last edited by Dave Calkins; 12-14-2015 at 01:36 PM. Reason: spelling, punctuation
  18. #58
    Jul 2002
    Anchorage, Alaska
    5,377
    Quote Originally Posted by Waterboy View Post
    Do you have photos? Any upholstery? Retainer tabs or bungee cord?!! Thanks
  19. #59
    2,646
    I have seen a lot of BAS and Dodge jumpseats, but I have only seen one set that didn't use bungee cords to keep them in the stowed position. About the best you can do is get a matched pair of bungees, hopefully color-coordinated with your airplane.
  20. #60
    DJ's Avatar
    Jan 2009
    Bolivia
    184
    I have some pictures of an install and also the diagram for the stock rear seat 1953-1962 180 but the post was denied because of "urls" of which there were none. Any advice?
  21. #61
    Skywagon185's Avatar
    Sep 2006
    Bigfork, MT
    65
    I'm in the final stages of installing the FAD seats. Not a quick installation but very heavy duty and thorough. The side rails are removable as stated above. I really like the fact that the seat belts use a bulkhead (station 90) vs. other designs.
ID:	23247   Click image for larger version.
  22. #62
    Meanwhile,...
    5,044
    Very nice, looks like much less fun than replacing the front seat rails
  23. #63
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    Wagon Driver, is that you????
  24. #64
    Nov 2008
    College Station, TX and Uvalde, TX
    73
    To go along with OP's question, what do these seats tend to weigh bare bones?
  25. #65
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    My stock back seat is 25 pounds.
    From what I have seen so far, the BAS style weigh 11 pounds for a pair of them installed.
    Still waiting on word of the Atlee Dodge installed weight.
  26. #66
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    LakeVue folding seats anyone installed them?
    I have a set I bought along with the STC ect...
    Hoping to find an IA to help me install them somewhere on the Kenai Peninsula.
    All of our local folks are buried in work..
    Anyone know about how long the install takes?
    The LakeVues used to be BAS.. They are light duty and lighter weight than the Atlee Dodge types.
  27. #67
    9,373
    Installation can be done in 8 - 12 hours for both seats by an experienced mechanic.
    http://lakevueaeronautics.com/id2.html
    It doesn't look difficult Alex. Most of the time appears to be removing and replacing the interior panels and floor covering to install the fastener locations. Adding the late model seat belt hardware probably takes a lot of time. You don't need that do you? It shouldn't take much time to inspect the finished job if you have a friendly local IA. Talk to him beforehand, of course.
  28. #68
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,600
    Do you think we can merge these three C-180 rear seat threads into one?
    sj
    Likes Skywagon185 liked this post
  29. #69
    Jun 2015
    2
    Here's some pictures of my Lakevue (BAS) install from a yr or 2 ago; my grandchildren and son-in law said they they were fine after a one hour flight:
    https://www.flickr.com/photos/129286...57673010758662
  30. #70
    aktango58's Avatar
    18AA
    9,094
    Easy install. You should be able to do most yourself, then get a sign off. Took me a day if I recall, most of that the rivet banging.
  31. #71
    18,760
    I hope you have that understanding with your mechanic prior to starting.
  32. #72
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    My seat belt mounts will work as they are. The couple local guys who have done folding seats have only done the Atlee versions and they used screws to mount the Brown-Line rails and not rivets.
    Install time guest-ta-mations have varied wildly...
    I have been trying to get somebody to help me install these things for a year... I am on floats all summer, and when I do my winter annuals it is always a big rush to get in and out of the IAs hangar.
  33. #73
    Flying Miss Daisy's Avatar
    Jun 2004
    Wentworth NH" The WAD" NH96
    3,290
    Quote Originally Posted by sierra bravo View Post
    Consider adding rear seat shoulder harnesses to whatever seats you decide on. They're a simple and inexpensive addition.
    Attachment 6311
    very nice looking interior
    Life should not be a journey to the grave with the intention to arrive safely in a well preserved body but rather to slide in sideways, well used up proclaiming "WOW What a Ride"
  34. #74
    aktango58's Avatar
    18AA
    9,094
    Always!
    Plan ahead with them, and do according to plan.
  35. #75
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,254
    Do you think we can merge these three C-180 rear seat threads into one?iu
    sj
    Yes.
    Now if we just knew someone who could do it.
    "...We're fast enough to get there, But slow enough to see..."
    Fron the song "Barometer Soup". By Jimmy Buffett
  36. #76
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,600
    Quote Originally Posted by Ruffair View Post
    Yes.
    It's hard to get good help these days...
    sj
  37. #77
    AKCRUISER's Avatar
    Oct 2016
    AK
    30
    You try Ward in gwood?
    Thanks Alex Clark thanked for this post
  38. #78
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    Well,,,,,,,After a year of begging I finally managed to find an IA who would help me install my folding seats in my C-172N.
    Three other IAs blew me off over the past few months.
    Last night we discovered that the Seaplane versions of the C-172s have 80 thousandths thick doublers along the back floor right where the seat rails need to go. Plus some extra thick underside bulkhead work underneath the floor. And they even have a couple extra inspection plates. My plane is NOTHING like the one they use in their instructions...
    I have attached some photos We are going to try making some doubler shims of the same material and use them to support the rail. Plus take out some rivets and replace them with flush rivets. Although since float flying season is here, the seats might spend yet another another season in the box. I am loosing money already this year.
    I need to buy a C-180....
Name:	2012-12-31 015 (768x1024).jpg
ID:	31439   Click image for larger version.
Name:	2012-12-31 019 (1024x903).jpg
  39. #79
    18,760
    So I have to ask, who does your maintenance and annual inspections? They weren't interested in installing the STC or were you wanting someone to let you help or do the work and then them sign it off?
  40. #80
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,144
    I wanted to pay somebody to do it. Or pay somebody to do it with me helping them. Or whatever worked....
    I believe that a couple of the folks who blew me off simply could not handle the thought of carrying through with the project. Regardless of how much cash I waived around.
    We have a limited number of IAs locally. There are at least 4-6 I know of who will only work on their own gear or the gear for the company who employs them. ( 135 operator/ owners )
    Then there are 3 who can be hired when the time is right and they are not buried in helping the 135 outfits. Or fixing the stuff that is messed up by the summer time hires at the larger 135 outfit.
    Only one of those three has his own hangar. He is also the best and is super booked up, seven days a week. He worked on a Beaver from out of town until 9 last night and then came over to help me for 90 minutes. He does my annuals in the dead of winter and even then we are going as fast as can be and then out the door. My 100 hr checks during the summer while on floats are a huge pain in the butt to schedule.
    There have been times when I have trailer-ed my floats for over 200 miles to have them installed. I had to fly a 100 miles a few years ago to have somebody help me install and paperwork my Power Flow exhaust.
    I need to get back to work. It looks like the seats are going back into their box and I will need to go onto my floats without them again. Had I known I sure as heck would not have removed as much of the rear liners as I did. They are old and brittle.
Name:	2012-12-31 022 (1024x768).jpg
ID:	31442   Click image for larger version.
Name:	2012-12-31 021 (1024x768).jpg
  1. front seat brakes versus rear seat brakesa
    By kevind in forum Modifications
    Last Post: 06-13-2015, 04:59 AM
  2. Remavable Rear Seat Crossbar and Pilot Seat Belt Attach
    Last Post: 03-10-2008, 06:23 PM
