Page 1 of 2 12 LastLast
Results 1 to 40 of 44
Thread: 3 Piece Boot Cowl - A Handy Design
    Darrel Starr's Avatar
    Plymouth, MN
    2,524
    For those of you building or planning to build a Super Cub or similar plane, I would like to recommend building your boot cowl in three pieces. The top piece rolls around the top of the firewall. The two other wrapper pieces slip under the top piece then meet at the bottom in the middle. Dakota Cub builds boot cowls of this general description. Husky boot cowls are in 4 pieces. If you design it to screw together with nut plates on the firewall, you can easily repair it or reach parts hidden underneath.
    I really didn't think I would ever take mine apart but after a couple years of use, paint started to bubble around screws. The problem turned out to be a mistake I made when prime painting the parts. I first primed with self etching VariPrime, which is a dark tan, then sprayed over that with white PolyFiber Epoxy primer. I didn't properly prep the surface and the paint separated between primer coats.
    It was relatively painless to unscrew the two boot cowl wrappers and the false boot cowl pieces also.
    Since I wanted Bob Schefter in Fergus Falls to strip and repaint the parts and since his shop is off airport, having the parts in small pieces rather than flying the SC into Fergus Falls meant that he could use his paint booth and get a nice smooth dirt free surface.
    Anyway, just one example of why I'm glad the boot cowl comes apart.
    Also, imagine if the rear seat heater box needs repair, not a problem - just take off the right side boot cowl wrapper and have at it.
    Thanks Colorado-Cub thanked for this post
    Apr 2007
    Kingsburg, CA
    1,256
    I second to what Darrel says. I made my boot cowl for my -12 too. Instead of using a 3 piece, I made a 2 piece using a pattern off the old one with posterboard. The top "saddle" piece will make the boot cowl easier to fit because instead of working with 2 big pieces, you are working with 3 smaller pieces. I realized this when I was trying to fit my boot cowl to the frame. If I have to take my boot cowl off the frame like Darrel has had to do, I will have to take my windshield off. For securing the boot cowl to the 3/8 channel, nut plating the channel is the way to go.
    Every restorer has a "If I had to do it over again, I would do this different..." list. a 2 piece to 3 piece boot cowl would most likely be on my list.
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,312
    That's how I did mine. Very convenient.
    SpainCub's Avatar
    Feb 2009
    612
    Darrel, thank you for your contribution! I always take something away of great value with your posts! and great picture to back your explanation... that really helps us technically illiterates.
    Plymouth, MN
    2,524
    Spaincub, thanks for your comment; Much Appreciated.
    Meanwhile,...
    5,462
    Wish Piper had done it that way...
    kase's Avatar
    Feb 2002
    Billings MT
    1,601
    Just had a guy make one like that for my cub.
    . Click image for larger version.
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,506
    Darrell, a nylon washer under the screw heads will help keep your paint nice....Husky's have them......I put nylon washers under every screw on new paint on Cessna's, for sure, every one!
    AkPA/18's Avatar
    Feb 2003
    Big Lake Ak
    748
    Another cub??? Looks good Alan!
    Mark
    http://thrustline.com/
    kase's Avatar
    Feb 2002
    Billings MT
    1,601
    No just doing a little repair work. Started out with a craked tailpost. Ended up adding a 3 ft metal belly to the tail and a new boot cowl cause I didnt like the way the other one fit.
    Plymouth, MN
    2,524
    Dave, I do use nylon washers under all of the screws -- but the paint lifted anyway, no cure for a bad bond short of stripping it off.
    Apr 2018
    Wagga Wagga Australia
    17
    Hi Darrel,
    I'm quite new to Supercubs and whilst waiting on a PA18 kit I've ordered, I'd like to buy a pan-box brake to make a 3 piece cowl and some smaller projects whilst building. What width do you think I'll need for the this cowl work? I'm currently looking at a 50" and a 36" unit.
    3,901
    Darrel hasn't been on the site for a number of years, but I've been hampered by a brake / roll that is too small. Get the bigger one unless there's a good reason not to.
    Likes tackdog, Steve Pierce liked this post
    21,313
    I have an 8' brake and a 6' press brake. The 50" will work perfect for most Cub work.
    Dec 2004
    144
    a four foot shear is handy - if you have no other uses it for it other than your cub project, it’s probably not worth it...quality tin snips work just fine.
    4,149
    Sheets of aluminum come in 4 foot by 8 foot and 4 foot by 12 foot. Get brake and shear that can handle at least the 48" distances.
    Jan 2017
    Utah/Alaska
    362
    I have a Niagara rotary beading tool from about 1900 that I used to do most of my light joggle work, along with the 48" brake and 52" shear I also have a set of 1/4" bead rolls, which add nice stiffeners and edges. I still want to learn to do a wire roll. Good luck, Tim
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    867
    I am looking at rebuilding my boot cowl. What’s everyone’s thoughts on the firewall, stainless or titanium?
    Jan 2017
    Utah/Alaska
    362
    Have fun with Titanium...
    21,313
    I have made several firewalls from titanium. Considerably lighter and I did not find it difficult to work with, just different. Drill slow.
    11,481
    There are special drills for drilling titanium. As I recall they have a very shallow angle.
    11,481
    See if you can notice the angle of the grind on the drill in the first two pictures. The third picture is comparing the titanium grind on the left with a "conventional" grind on the right.
ID:	57518 Click image for larger version.
ID:	57519 Click image for larger version.
    The flatter grind cuts nicely through titanium. One of my first aviation jobs was drilling holes on the production line for Sikorsky. This flat drill is what we used for drilling the firewall on the top of the S-61 fuselage. I think it was Titanium? It was long ago.
    Thanks Charlie Longley, RaisedByWolves thanked for this post
    Likes RaisedByWolves, Hardtailjohn liked this post
    stewartb's Avatar
    Wolf Lake, AK
    6,595
    Given the choice a couple of times I’ve chosen stainless.
    My EXP kit’s standard firewall was aluminum with fire-proof paint. I passed on that.
    Meanwhile,...
    5,462
    Ti
    Jan 2008
    Arlington, WA
    867
    My boot cowl is in pretty good shape. Firewall not so much. I’ll probably order a Ti firewall from Atlee and just have them punch the holes I need.
    is the hole in the picture for a defroster?
    21,313
    The fluted edge on the Atlee Dodge titanium firewall in a pain. I fit it on a Super Cub build several years ago.
    Likes tackdog liked this post
    21,313
    I didn't like how the boot cowl sheet metal fit around the flutes and cut them off and used a firewall channel from Clyde Smith $85. https://www.cubdoctor.com/stainless-...lls/index.html He makes a very nice set for reasonable money. Now I order my titanium from Titanium Joes ($200-300) and cut out my own firewalls. I have punches for the holes if you decide to make your own and want to borrow them. Compare to $768 plus shipping on the Atlee Dodge unit. https://fadodge.com/pa-18-titanium-firewall/
    21,313
    I used nut plates in the flange so the boot cowl can be removed in sections and used PRC sealant around the flange, front and back.
    11,481
    Is the difference in weight between Stainless and Titanium really enough to compensate for the difficulty in working the material? What is the weight difference? Assuming the same thickness.
    21,313
    It is considerable but will have to look it up. I don't find it hard to work with. Shears fine, drills fine just slow down the drill and punches fine.
    21,313
    A friend just built a titanium firewall to replace the stainless firewall on his PA11/AL11 Legend Cub and he saved 3 lbs titanium vs stainless.
    11,481
    Interesting, I would not have guessed it to be that much. Now I can understand the interest in Ti.
    4,149
    Mr. Pierce
    What's the proper rivet for the Ti? Monel or is there something else that is less reactive?
    Jan 2008
    Arlington, WA
    867
    Thanks for the links Steve! After sleeping on it I am going to build a 3-4 piece firewall. I have a slip roller and punches. My “welder” has a good shear I can go over and use.
    Jan 2008
    Arlington, WA
    867
    Where did that engine mount lug come from Steve? It doesn’t look stock.
  36. #36
    supercrow's Avatar
    Dec 2008
    547
    Thrustline mod.
  37. #37
    Apr 2018
    17
    Hi everyone.
    For ease of future maintenance when making a 3 piece boot cowl, do you make a ''formed seal'' (I'm not sure of the term that you use?) with heatproof goop like PR812, where the boot cowl is screwed to the firewall's nut plates? Ie: goop one side, petroleum jelly the other and screw them together to form the panel seal?
    If you have a avionics maintenance issues, is it easier to make some large removeable panels on top of the dash, or do you remove the windscreen and the top boot cowl panel? I've read that some people use felt to mount the windscreen similar to a Cessna 172, yet others use a caulking compound and I'm not sure if this is a thing that once trimmed and fitted well, you never ever want to remove it again due to the risk of cracking or just being a PITA.
    What's the preference for the panel join in the wrapper? A flange / lap seam or a simple overlap with a slight panel edge break?
    I'm hoping I can modify the standard parts in my kit when they arrive to suit - they mirror the stock cub setup where the boot cowl wrapper has the fluted formed edge that folds down over the firewall.
    Thanks again
    Damian
  38. #38
    21,313
    Mr. Pierce
    I have used standard aluminum rivets on all the ones I have built so far.
  39. #39
    21,313
    Quote Originally Posted by tackdog View Post
    Hi everyone.
    Thanks again
    Damian
    I have not made a seal. The Short Wing Piper series have an airworthiness directive to seal the firewall with a non-hardening seal because they used a fiberglass insulation under the floor that would get saturated with fuel and oil and cause a fire hazard. I have not seen any issues. I have removed the side panels to get access to under the panel but usually access from under the instrument panel using a modified creeper that sits on the front and rear seat bases. The top panel can be removed but the windshield would need to come out. I seal around the windshield with a urethane sealant. At the over laps I brake a flange on one side for stiffness.
    Thanks tackdog thanked for this post
  40. #40
    Jan 2008
    Arlington, WA
    867
    Steve what thickness/grade of Titanium are you ordering?
    Likes astjp2 liked this post
  1. Metal for boot cowl and engine cowl
    By Jim Miller in forum Experimental Cubs
    Last Post: 05-13-2015, 10:30 AM
  2. Supercruiser Top Cowl piece
    By Fortysix12 in forum Tips and Tricks
    Last Post: 02-15-2005, 09:04 PM
