WhiskeyMike
MEMBER
West Boxford MA
Does anyone have the installation instructions for the Ferguson tips? "Upper Valley Aviation exhibit no. 2a report 101-250 dated august 30, 1965.
Thanks in advance!
Thanks in advance!
Should be plenty of pictures on this board of tool time Tim's 2+2 with the wag aero tips. Good looking airplane/wing tips, don't know if they are good or bad for performance. Wing tips and their merits are highly subjectiveanyone have any pictures of wag aero wing tips already on
....BTW, giving it some thought, anyone have plans for the droopy ailerons some have in their cubs? I was considering a mechanism that, when flaps, and droopy ailerons are enabled, a spoiler would be used to gain aileron authority for slow flight. I know Alec mentioned that it was not working as expected on the Double Ender for extremely slow flight, but it would be interesting to test it.
A lot of guys have removed the droop aileron system myself included I found at the very low numbers you lost most of your aileron authority with no down force on your up wing and in very Windy conditions best to not use it at all.
I had mine separate from the flaps on off any time I wanted them...I would get maybe 3 to 5 slower if I was doing straight in approaches but working it in around trees in tight turns just didn't like the feel..another thing is I think you lose a little in aileron authority because of the springs in the system.
my complete system was about 4 1/2 lbs
On a super cub the springs hold tension on the pulley
If it was connected to the flap handle then there are two springs in the system right there. I believe they are also referring to a system where the ailerons droop independantly of any flap setting.Only one of the four that I mentioned is in a Super Cub. I can not remember the details of the Cub, though I do not think that it had any springs. It was connected to the flap handle. I havn't seen that plane for a while, so it will be difficult to verify.
