Steve's Aircraft (Brian)
FRIEND
White City, Oregon
Brian (Steve's aircraft)... when you added the Sullivan tips to your Pacer could you have installed them without extending the wing? oi meand could you have cut off the spare extention to equal the original wing span? Or does the STC prohibit that?
Dan
The installation instructions are with the wing extended.... To deviate from that would probably require a field approval since the original approval is with the extension. Besides that, you want the extra wing area on the short wing of the Pacer.
When I talked to Ron when doing this conversion he had told me that he originally designed and approved these tips so that owners of Plane Booster/Ferguson droop tips could easily replace them with his tips. The extension of the wing is identical. There are a lot of owners that do not like the droops due to their "blocking" part of your view area past the wing tip.
On another note.... The addition of VG's on the wing bring back most if not all of the aileron control, but I still think getting the ailerons out to the tip would be the best solution.
Brian.
