Page 14 of 14 FirstFirst ... 4121314
Results 521 to 534 of 534
Thread: Olibuilt 's New Cub project
  1. #521
    1,498
    More flap about flaps and ailerons:
    See page 27 on for a discussion: https://ntrs.nasa.gov/archive/nasa/c...9930091708.pdf
    https://generalaviationnews.com/2015/04/21/cubcrafters-introduces-carbon-cub-ex-2/
    http://cubcrafters.com/c/2017/02/g-s...ailerons-faqs/
    Note the cove gap tapering to the outlet and hinge line.
  2. #522
    9,046
    One enigma though is we tend to slot flaps and seal ailerons. That may be simply due to the cove design in front of each. Citabrias are like that for their ailerons and partially sealed flaps. Unless it flows well to help then a seal simply reduces any loss of pressure air from below or above and makes the control more effective (like the aileron).
    Gary, I learned to fly in a 7AC and do like the entire series of models, however their controls are sloppy at low speeds. The current manufacturer has an optional spade which is supposed to correct the aileron's sloppiness. It is only a band aid. The airplane does pass all certification requirements, however...........................
    We can discuss this in depth if you wish but let's do it on another thread than Oli's.
    Thanks vj88 thanked for this post
    Likes Chicken Hawk, vj88 liked this post
  3. #523
    Mar 2016
    792
    I started a new thread here so the discussion of slots and seals can develop further.
    https://www.supercub.org/forum/showt...lots-and-seals
    Not sure my link is right.
    Likes Geffert liked this post
  4. #524
    Apr 2018
    15
    It works here on my end.
  5. #525
    9,046
    Had the time to do a little flight test today. It still fly, that is the good thing.. Hahah ...
    First impressions may be wrong:
    -less tail shake a 45mph, with 45 flaps
    -less sink rate at 45mph with 45 flaps
    Did only one landing. Will report feedback when I have the chance to test it more.
    Oli, How is this working out for you? Can you give us a report on how well the improvements worked or did not, please?
    Thanks Lowrider, baron55tm thanked for this post
  6. #526
    4,396
    45* flaps at 45mph? Why?
    Total flap deflection is an interesting topic. When I started building my plane we wanted 70*. That was problematic and as it turns out, unnecessary. These days it’s 50*. I don’t know where BCSC is with the Rev 3 flap but initially they were targeting 30*.
    Thanks baron55tm thanked for this post
  7. #527
    9,046
    My TCOW 110" long and otherwise stock Piper flaps go to 56 degrees. There is no tail shake and only minor pitch up nearing max deflection.
  8. #528
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    806
    I realize I cannot say those gap seals makes a big difference. No extensive test were done...
    Don't forget it is also the first BushWheels season with the 3"x3" extended elevators too..
    And my skills are always improving
    The thing is I've changed the way I handle the plane:
    -I now only use flaps at 45*, instead of 65*. The plane appear to be able to fly slower at 45*
    -I now feel comfortable at around 30mph IAS (smooth air)
    -I'm now confident on my skills to handle water assisted landing.
    I know that when you think you are in total control, it can bite. But I really feel I can handle that plane...
    http://photos.app.goo.gl/wfcHQyxEdfTa6AuC9
    Likes CamTom12 liked this post
  9. #529
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    806
    Airplane is going strong, I really love it.
    86" Catto prop pulls very hard, but I sometime wich a little more cruise speed....
    A short video of my latest flying:
    Hope you like
  10. #530
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    806
    New suspension fairings. Hoping for supersonic speed, nothing less...
  11. #531
    Jan 2018
    10
    That hatchet is gonna cost you at least 5 knots...
  12. #532
    Dec 2004
    Inkom, Idaho
    1,264
    Fairing the long shock struts could get tricky, probably why you haven't, yet?!I think I have the only faired cabane I've seen on Cub style gear, beside the shock struts and A frames, all with trailing edge taper, not just covered. If it's round, I want to fair it, don't care about speed so much but it helps climb and range also.
  13. #533
    9,046
    If you look at a stock PA-18 with the metal speed fairings over the shock cords after landing, you will see that they are not in line with the center line of the plane. They reflect the twisting of the airflow from the propeller rotation. While yours may appear to have streamlined the airflow, any advantage may actually be counteracted by the corkscrew flow from the prop.
    Did you notice any difference in your speed? Aerodynamics is sometimes quite complicated and at other times a very small thing can make a big difference.
  14. #534
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    806
    Did only a small flight yesterday, but it looks like about 4mph speed gain.
    I will try to tape small aluminum angles to the trailing edge of the shock struts.
  1. Another Project
    By Glenn5ft19 in forum Cafe Supercub
    Last Post: 10-12-2010, 02:03 PM
  2. What to do with project?
    By J5Ron in forum Super Cub Sick Bay
    Last Post: 05-21-2008, 11:18 AM
  3. PA-12 project
