Page 10 of 14 FirstFirst ... 89101112 ... LastLast
Results 361 to 400 of 534
Thread: Olibuilt 's New Cub project
  1. #361
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    Decided to give a try at fabricating those gap seals for the tail section. I always tough they were selling them way too much $$...
    So it started out with pipe insulation foam tubing
    So I fabricated a little hot wire setup, with some fishing leader material (realized afterward I could have used some safety wire, or vice versa for fishing?...)
    The hot setup was made to cut the foam.
    Setup was plugged with a 12v charger at 2 amps.
    After a little spay on adhesive to glue them together, it almost looked like a non-perfect gap seal to me. The bottom glued itself together when installed
    Once installed, it was grey, feather light, filled some gaps, took about 3 hours in research, development, and fabrication... And they cost less than nothing.
    No glue on the airplane. They looks very well there when elevator is moving. We will see after a couple flight....
    Hope this helps..... help you saving $ for gas...
  2. #362
    Tim's Avatar
    Feb 2002
    Petersburgh, NY
    3,499
    Oli, looks like you have it figured out. Let us know how they work out
  3. #363
    Lowrider
    Nov 2012
    Idaho Panhandle (ID05)
    1,691
    Oli,
    Very nicely done! Always good to save money and come up with such an effective solution. I'll tuck it away in my little brain.
    BTW, I called the US rep (Pete) for your paint company and he was a nice guy but I never heard from him after we hung up. I have been using Stewarts and it is very acceptable so I will probably go that route, but I do wish they had a brighter orange.
    Fly low and safe!!!
  4. #364
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    I'm in the process of building a new landing gear setup for the cub. I already have a 6'' extended, but a little more angle of attack would be great.
    So I was planning for 3'' to 6'' higher.
    My biggest question is should I bring the axles forward 3'' having a 68 pound tail in the W&B ?? It would be nice to have more braking capability when playing around empty.
    Thank you
    Quote Originally Posted by Tim View Post
    They were holding great until I lost 2 in one flight...
  5. #365
    D.A.'s Avatar
    Free America
    673
    ...So I was planning for 3'' to 6'' higher...My biggest question is should I bring the axles forward 3''
    Olibuilt, one of our gears was built by Wayne Mackey and is extended 13" and also raked forward. I don't know how much it's raked forward but I can take some measurements if you like. When we got the airplane it had a rigid suspension but Wayne told me it originally had a suspension. If we end up running the gear and decide to run a suspension we'll probably have Steve Furjesi build another elastomeric puck system. Let me know if you need measurements.
  6. #366
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    Thanks D.A.
    I've been checking some possibilities. I think I will go with 3'' forward and about 5'' more lift than the 6'' extended gear, and another 6'' wider.
    I have the time to think, I'm waiting the 1.5'' axles from Javron.
  7. #367
    D.A.'s Avatar
    Free America
    673
    ...I think I will go with 3'' forward and about 5'' more lift than the 6'' extended gear, and another 6'' wider.
    I think that's pretty close to what our gear is.
ID:	20897   Click image for larger version.
    Likes cubnut liked this post
  8. #368
    Lowrider
    Nov 2012
    1,691
    Any idea how wide it is between the inside of the axles? Has the turning radius changed significantly with the gear moved forward?
  9. #369
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    Just received the axles from Javron. At 42$ a piece, 1.5'' axle, axle nut and brake bracket tacked welded, can't get better than that.
    Very nice piece, and shipping to Canada was very fast.
    So the new suspension setup will be on the way!
  10. #370
    D.A.'s Avatar
    Free America
    673
    Just received the axles from Javron...
    Axle, nut, brake flange and a beer - - - Can't beat that! What suspension are you going to use?
  11. #371
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    The beer don't come with the kit.
    But a Canadian Budweiser beer is pressed fitted on the 1.5'' axle. Physic is awesome.
    I'll give a try with an airshock setup. I hope I won't be disappointed... Or tuning pressure and oil for the rest of my life...
  12. #372
    Lowrider
    Nov 2012
    1,691
    Canadian Bud is stronger than down here, eh!
  13. #373
    irishfield's Avatar
    Feb 2003
    2,963
    I was going to stay it's not a Canadian beer at all.. must be a Kabec thing! lol
  14. #374
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,482
    I had a Colorado pilot drop by for a visit the other day, he had some real nice looking gap seals, and sent me the link for where to get them. He claims a 1 mph increase in cruise speed. He did pretty rigorous testing before and after to back that claim up. They sure seem like they should clean things up back there, he had them on both sides of his rudder and the top side of his elevator. Rans S7-S. I like your home made ones! www.wingsandwheels.com/tapes-seals/mylar.html
  15. #375
    Aug 2014
    Kenai, Alaska
    184
    Are you happy with your landing gear suspension now that you've run it for a while? Would love to see some more pictures and hear some details, ex: make of shocks you used, tubing size/thickness, etc. Really enjoy watching your videos on youtube also, keep them coming. Thanks, Joel
  16. #376
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    Suspension is working perfectly. I'm now at 330psi with max oil capacity in the Fox 10'' airshocks (old model stock Super Stol shocks). Landing gear is built like a 3'' HD extended, but one thickness thicker.
    Don't have many rock beaches around here. Manage to find.
    (doesn't work on phone or tablet)
    My first rock landings when flood watching:
    Likes CamTom12, Lowrider liked this post
  17. #377
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Nice video. Definitely smooths the bumps out.
  18. #378
    Nov 2014
    10
    The St Lawrence is really high up there isn't it. Beautiful plane
  19. #379
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    Nothing new. Just playing in the corn.
    But I'm still looking forward for bigger elevator, ans maybe a flap dump system. But theese days, USD to CDN is a real stopper for modification.
    Likes AKCRUISER, Ruffair, jrussl liked this post
  20. #380
    Lowrider
    Nov 2012
    1,691
    Nice Oli!!
    Where I grew up you make corn into whiskey and never feed it to the chickens!
  21. #381
    Jun 2008
    sioux lookout
    539
    Nice Oli!!
    i would feed whiskey to chickens! that would be fun to watch.
    Likes WanaBNACub liked this post
  22. #382
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,254
    Great song..! Great filming....! Great acting...! At least I hope that was "acting"....! Hahaha
  23. #383
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    What if some little bugger ate 8 stitches on 2 ribs next to each other? So about 32 knots near the wing tip.....
    Dam little animal, I think he is even smoking in the wing.....!?
  24. #384
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    418
    Can you pull the tape off and rivet the fabric or use a pk screw ? Is this your cub Oli?
  25. #385
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    679
    Re-stitch / Re-tape / Re-paint. Did that once on a J3
  26. #386
    DW's Avatar
    Dec 2002
    pacific northwest
    2,067
    Yup that's what I would do.
  27. #387
    10,759
    Paint some large head pop rivets then just rivet them.
  28. #388
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    I needed a pair of straight skis for next winter. I bought a very cheap homebuilt set. I don't fly very often on skis, and they could do the job without any mods. Skis looks to be ok, But the pedestral part of the ski is very ugly and has way to much "camber".
    I know those skis cannot be compared with the CarbonConcept one... But I am thinking removing this horrible oversize "pedestral" and fabricate a steel tubing pedestarl about 12" in height.
    What do you think?
  29. #389
    Lowrider
    Nov 2012
    1,691
    Those are beautiful...I was afraid you were talking about the sewer pipe.
    I just did a 900 mile Harley trip thru MT, SK, AB and BC and when I got back it was a lot cheaper than I thought I had spent. I suppose the other way around would be less satisfying.
    Wouldn't raising the pedestal place a lot of stress on the ski attach point?
  30. #390
    spinner2's Avatar
    Montana
    1,754
    The Carbon Concept skis put the axle height almost as high as 31s do.
  31. #391
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,223
    Paint them black and red, they’ll be beautiful.
  32. #392
    Apr 2018
    Knoxville, Tn.
    185
    Must have. Don't leave home without it. Bobblehead or hula lady optional.
  33. #393
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    Haha, and it would be just fine.
    But the skis have a lot of camber....
  34. #394
    9,778
    With the design of your landing gear they will be flat when you touch down. What's wrong with that?
    Likes Olibuilt liked this post
  35. #395
    nd
    3,468
    Oli, you can buy solid bushing material and with your talent when you drill the hole for the axle take a little of the camber out if needed.
  36. #396
    10,028
    As do most skis
  37. #397
    G44's Avatar
    Oct 2011
    SW Michigan
    473
    They look a bit small to me. How long and wide are they?
  38. #398
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    Skis are 68" x 16". Will have to decide what I do with them...
    Playing with the cub
    Likes Chicken Hawk, rotto789, jrussl liked this post
  39. #399
    flyrite's Avatar
    Mar 2013
    Lyons,GA
    478
    Theys Rednecks ever where and in every country...…..Not just Down south here in Ga...…..Great video's
  40. #400
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    825
    Likes flyrite liked this post
  1. Another Project
    By Glenn5ft19 in forum Cafe Supercub
    Last Post: 10-12-2010, 02:03 PM
  2. What to do with project?
    By J5Ron in forum Super Cub Sick Bay
    Last Post: 05-21-2008, 11:18 AM
  3. PA-12 project
