I did it as part of putting a Big(by scout standards) extended baggage area in.... no fwg CG issues, with all his cr*p back there....
... the REAR glove box! Very little room back there in the Scout.
8GCBC:
ACA now has the firewall battery on the TC, no stc required. I did the batt move as part of the extended baggage install on my Scout, which is required with that stc.
You have to use the PMA Hawker version of the battery, not the oddyssy PC680. You will lose about 13 lbs with the small batt which is good for our portly Scouts. It will really whirl the starter with the new short cables. Wont do you much good if you need some ballast in the rear for the amphibs.
your Scout brother
Jim
What voltage are you setting your regulators at when using the Odyssey battery? They seem to have left that info out of my paperwork. Jim
* The regulator is pre-set at 14.4V.
I "think" B&C said 14.4
The battery absorbtion is 14.7 on web site? That seems high?
no idea, never have had need to adjust a B&C... that's worked well for years and the batteries last for ever.....
