nesincg
BENEFACTOR
Chattanooga, TN (KAPT)
I got home a day early from work this week which was nice. I used the extra day and my father-in-law to do the old fashion engine removal. First I took a billion pictures of the whole plane now with the skin off. Than we drained the oil first (thanks for the tip) and used Glenn's second storage method, but slightly modified. There it will spend some months until I decide its fate.
After dinner we tackled the boot cowl and all the instruments. Took us forever to figure out that radio has a small screw in the front that attaches it to the back of the tray. I'm assuming all do but being my first time removing avionics, some things got bent. Luckily none that goes back in. The boot cowl is in great shape except it looks like it had a static port at some point and has a patch over this. Unless someone is going to make me a free one, It'll continue to have that patch. I'm still wondering weather or not to replace the firewall or patch those two holes put in for the electrical junk.
Yesterday I picked up a used trailer. Its light duty but should hold the frame just fine for transportation. It folds up nicely in my garage. I'll probably have to add about 3 ft to the tongue for the fuselage to fit center of gravity wise. Unrelated, April and I saw the new Muppet movie last night and it was FANTASTIC.
This morning I spent quite a bit of time re-organizing the shelves that have already become cluttered. Stored many items in the boot cowl and saved a bunch of space. Then my friend Ryan came over and we wrestled all the details like peddles, floorboards and seat belts. We put 71H on Sawhorses and then I removed the legs. Pretty much all that's left is the rear floor panel, the jack screw, and the cables.
Question time:
Given the age of the elevator cables and their rustic look, do I cut the ends and remove them or keep them on there and hit them with the bead blaster or some other idea? There is no large sale rust on any of them.
1.Several pieces of the birdcage are in sad shape. I have the time, but can I repair it as nice as one purchased online?
2.Do you guys chemically strip the plane before hitting it with a bead blaster? Maybe saving blaster time.
3. Is it possible to remove the elevator cables from the frame without cutting them?
As always, a TON more pictures being uploaded as we speak to picasa.
Chris
Question time:
Chris
