Results 1 to 29 of 29
Thread: Need Help Running Hot
    Evan's Avatar
    Oct 2008
    Gonzales LA
    125
    OK I have a 0320 150 hp it started running a little hot last summer over the winter no problems this summer temps were getting 230/240
    so i checked and re checked the baffling. Next i brought to ap he checked changed the vtherm still hot next new eci titan cylinders still running hot
    next was the rear mount cooler it was a older aluminum cooler that Niagara crossed to be equal to there 20002 model so i ordered the larger 20003 model with 9 rib core
    new lines installed to cooler checked the cooler line placements where they come to and from cooler, engine oil pressures good but still running 230/240
    1400 hrs on bottom cam everything looked good when cylinders where changed . I just don't know what else it would be but please give me your ideas
    what am i missing ? oh and let me say it doesn't just go straight to hot quick it takes about 30 mins to get there, and we checked the temp gauge its right
    10,759
    crosswinds http://www.crosswindsstol.com/ sells a fiberglass lip that goes/rivets on the bottom cowl for with their rear mount cooler or engine kit or?? or something??...
    not sure if he will sell it without his kit/STC.....
    Dec 2010
    37
    Timing ?
    Louis
    Evan's Avatar
    Oct 2008
    Gonzales LA
    125
    Checked timing
    Tim's Avatar
    Petersburgh, NY
    3,499
    Do you have the oil cooler plumbed correctly? Oil should go in the bottom and out the top or you'll get air pockets in the cooler.
    Evan's Avatar
    Oct 2008
    Gonzales LA
    125
    Tim its not plumped that way it was aways plumbed high pressure side in the top discharge out the bottom could that be the problem
    any experience with this? i have heard that but the ap's here say it did matter but ill try it let you know
    Upper Peninsula of Michigan
    418
    My C90 is runnning a little hot too. 215-220....then I was taxiing up to the dock and switch failed....couldn't turn off.....not a big deal, unless you are approaching a dock on floats! Do you suppose my mag switch crapped out....or have you heard of hot engines continuing to run because of hot deposits???/someone told me that was possible. I think I need an outlet on the bottom of the cowl for the cooling, but the mag switch problem seems intermitten.....any suggestions?
    Feb 2011
    154
    If you have "Blow-by" past the rings the hot gases wind up heating the oil.
    Compression?
    There is a check using a ASI as a manometer but I don't have figures.
    HOW did you check the baffles?
    Tim's Avatar
    Petersburgh, NY
    3,499
    Evan, do you have a CHT instrument? If so what are the temps.? If your CHTs are 350 to 370 in cruise and your oil temp is still high, I'm not sure what it is. If your CHTs are 400 or higher, I'll PM you what it might be.
    10,759
    Quote Originally Posted by Dan Gervae View Post
    yes mag switchs go bad, there is an AD about this on the bendix brand switch...
    http://www.ercoupe.net/ads/76_07_12.html
    here part of it, more at the page above...
    76-07-12
    BENDIX IGNITION SWITCHES
    Amendment 39-2575 as amended by Amendment 39-3024
    Applies to All aircraft employing magnetos and using Bendix ignition switches
    listed in the table below except switches identified by four digit date code (new)
    adjacent to the model number or a white dot (modified) on the support plate
    adjacent to the Bendix logo.
    Rotary Action,
    Bendix Switches Key or Lever Actuated
    Switch Function Bendix (series) Part Numbers
    Twist-to-Start 10-357XXX, 10-126XXX
    Twist-to-Start/Push-to-Prime 10-357XXX, 10-126XXX
    Push-to-Start 10-357XXX, 10-126XXX, 10-157XXX
    Compliance required as indicated:
    1. For switches subject to this AD, conduct the following checks within the
    next 100 hours' time in service and each 100 hours thereafter to detect
    possible switch malfunction:
    (a) Observing regular ground run-up procedures, allow the engine to
    reach operating temperatures and perform a normal magneto check.
    (b) With the engine at normal idle, rotate the switch key or lever through
    the "OFF" detent to the extreme limit of its travel in the "OFF"
    direction.
    (c) If the engine stops firing, this indicates an airworthy switch.
    (d) If the engine continues to run with the switch in the extreme "OFF"
    direction indicating a malfunctioning switch, prior to the next flight
    accomplish Part III outlined in Bendix Service Bulletin No. 583, dated
    April 1976, for Repair and Replacement or use an alternate method
    approved by Chief, Engineering and Manufacturing Branch, Eastern
    Region.
    2. The aircraft may be flown in accordance with FAR 21.197 to a place
    where these modifications can be accomplished.
    3. The checks required by this AD may be performed by the pilot.
    4. Upon submission by an operator with substantiating data, an FAA
    Maintenance Inspector subject to prior approval of the Chief, Engineering
    and Manufacturing Branch, FAA Eastern Region may adjust the
    compliance times specified in this AD if the request contains
    substantiating data to justify the increase for the operator:
    NOTE
    If the engine continues to run when complying with paragraph 1 and
    repair or replacement cannot or will not be accomplished immediately,
    the magneto (primary circuit) should be grounded in accordance with
    Bendix Service Bulletin No. 583, dated April 1976.
    Amendment 39-2575 was effective April 14, 1976.
    This amendment 39-3024 is effective August 30, 1977.
    DUSTERMAN's Avatar
    Nov 2009
    Heyburn, ID
    68
    Evan could your engine be running lean. Not sure what other equipment on your engine. I remember my mechanic telling me that they had to richen up a carb on an o-320 when they put on upgrade exhaust.
    Clearwater,Fl
    2,543
    Two things come to mind, one, a bad -New vern, the second is the verns housing assembly. They wear out and most likely it's one or the other or even both. I've experienced both situations. remove the oil filter/vernatherm base and boil in water for test. Lycoming has a seat resurface tool but bases are affordable especially the after markets.
    Meanwhile,...
    5,144
    Evan, Obviously you're using too much Slap your Momma
    Kirby
    windy's Avatar
    Dec 2005
    Utah
    656
    To rule out the vernatherm, you could try putting in the spring and ball and see if the oil overheats.
    What's the oil pressure been when the oil's running too hot?
    behindpropellers's Avatar
    NE Ohio
    6,772
    gauge working correct?
    Meanwhile,...
    5,144
    When we we're there a few weeks ago we talked through most ideas tossed out. Evan has gone after them all to no avail.
    Veri-thingy in/out
    Gauge checked
    Cabin heat inlet plugged for the season – plumbed not the issue
    No change after topping it with new cylinders
    This is a nice L21 that was converted to a 150 with a cruise prop.
    His temp is a steady climbing (temp, it Louisiana they don’t climb) event with a cruise power setting at sea level in warm humid conditions.
    He's not running it terrible hard but we did notice while there playing that our fuel burn and oil consumption was higher than normal,,, I backed the RPM off a bit for being at sea level and that made a difference but I still burned more fuel and oil than at home and we’re not high by any means and none of the other 4 cubs (including Lance’s Green Hornet which has to work pretty hard to keep up with us speed wise) were running anywhere near hot.
    Any chance he could have spun a bearing that has not revealed itself in other ways?
    Kirby
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,230
    Evan says its not a good time to buy granite from him... your going to get gouged!
    windy's Avatar
    Dec 2005
    Utah
    656
    My oil temperature was running hot like that, tried all the tricks you did. On the way back from OK18, in Liberal, KS, Flip's oil temp reached the red line. I'd had enough, so if it was going to sieze up, it might as well do it in Kansas, where the whole state is a landing area. I decided to help the oil boil more, so gave it full power, without climbing, which sped up the air speed. Lo and behold, the oil temperature dropped 20F. My problem was not enough air flow over the oil cooler, so higher power settings are needed to keep oil under the red line in the summer. I use more fuel too, and especially more fuel when I'm down closer to sea level.
    oil flow
    air flow
    surface area
    the oil temperature heat problem is something to do with one of them, you can bet on it.
    Cub@H20's Avatar
    Oct 2007
    150
    When I attempt to save a little fuel by cruising at 2200-2300 (150,A2B) my oil temp indicates approximately 210-220 (OAT 75, leaned). Increasing to 2400, temp drops to about 190 (rich) and 200 (leaned). I've often wondered what effect the root design of the propeller has on airflow to the cooler. Gary
    Evan's Avatar
    Oct 2008
    Gonzales LA
    125
    Mine just the opposite runs cool at low rpms hot above 2200 rpm's took engine off today going to split case rebuild
    (put some fresh slap ya momma in it)
    Pokette's Avatar
    Apr 2007
    Chesterfield, Missouri
    649
    I have a 0-200a that has had some issues
    If I run at 75% power I am close the maximum oil temperature.
    If I run at 65% it drops 10 degrees.
    (on a 90 degree ambient day)
    So... I say....
    Install a lower lip or better yet cowl doors from CubCrafters
    Evan's Avatar
    Oct 2008
    Gonzales LA
    125
    Ok engine bottom shot scaring on crank on bearings
    Crank already turned so what's the options new crank or find a Serviceable crank Click image for larger version.
    Meanwhile,...
    5,144
    Evan,
    So there you have it, too much "Slap" and will burn you bottom every time!
    Seriously though very sorry to see that as the issue, but you'll essentially be fresh under the hood after this little set back.
    I know some on here have used them too but I would give Aircraft Specialities http://www.aircraft-specialties.com/ in Tulsa (of course) a call for re-manufactured cranks and other needs. If you end up doing business there let us know if there is anything we can do to help from this end.
    Kirby
    19,247
    How much under is the crank? Give bob at AC Specialties a call and he can either turn it or has one for sale. Get that case done as well.
    nutter3's Avatar
    Jul 2006
    Kenai,AK
    71
    Evan,
    So there you have it, too much Slap and you'll burn you bottom every time!
    So is there something that is done to an engine to cause this? Too fast on throttle changes, to fast cooling, too short of a preheat? I'd like to learn from Evan's misfortune so I dont have similar problems. Our 0-360 seems to run real hot as well, and the previous owner said that it always ran hot. I am searching for ways to determine if we have a problem with the sensor, or if it really is running close to redline.
    Meanwhile,...
    5,144
    FYI - Slap is an inside joke http://slapyamama.com/ use too much and it will burn for days!
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    677
    Boy I was terrified to click that link . . .
    Proud owner of a collection of airplane pieces (sometimes in one big piece) known as the Oklahoma Kid.
    Meanwhile,...
    5,144
    Quote Originally Posted by Amy View Post
    Yea Amy, but did ya'
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    677
    I ponied up the guts to do so and figured it would at least be an interesting explanation if anyone ever asked what on earth I was doing . . . So I bit the bullet and clicked it! Don't I just live an exciting life?
  1. c-85 not running right
    By thaefeli in forum Super Cub Sick Bay
    Last Post: 12-13-2009, 10:34 AM
  2. 160 Running hot
    By Jacques in forum Super Cub Sick Bay
    Last Post: 06-11-2003, 07:26 AM
