Mike and Todd
Thank you for those good and helpful posts
The new pump came in. Thanks MMR for your help. On the left is the Parker 914 series pump. It takes 25/22 strokes to raise and extend the gear. On the right is the new Parker 910 series. It takes 13/15 strokes to raise and extend the gear. It is about 18 ounces heavier than the 914 series and a little fatter. They make three models of the 910 pump. The only difference is the fitting ports. I got the 910-6D2BC model
Another angle. Notice also the handle and how it fits. The 914 handle slides into a tube. In the 910 series the handle goes over an extended stub.
This is how the pump is mounted to the seat post and also how the valve bolts right into the pump (with the right fittings of course). The 914 series pump will require a Fragola 495110-BL and a 495111-BL. The 910 Pump uses 2 of the Fragola 495110-BL fittings. This gives you a male AN-4 fitting out. I drilled and re-tapped one of the fittings for the bottom for an AN-3 pipe to male fitting so it took less space. You will also need a 499304. This is a 1/8NPT to a -4 female. This connects the male out of the pump to the 1/8NPT in the valve.
This is the bottom of the pump where I tapped into the O ring 495110 fitting to put a std AN fitting in to keep it smaller, for clearance issues. You will want to mount the pump as low as possible.
This photo shows the longer handle stub. You can see the step where the normal handle slides down over and rests at the step. The handle supplied with the pump is a steel tube, that I swear weighs 10 pounds and is 2 feet long (with a bicycle grip). I will make a shorter handle out of aluminum tube.
This is the pump in the airplane (w/o the valve, which would be on the left as you are looking at it). You will note that I had to cut the handle at the step for clearance. As it is now the stick does not hit or interfere with the pump in any possible way (picture is with FULL right aileron). It is also clear of your legs and feet. You really can't tell it is there. But as noted earlier, I will have to make a removable handle, that will slip over the stub that is left in order to get adequate leverage.
In this configuration there is no interference with the back seater's rudder pedals, feet, etc and no issues for the front seater as well.
What it looks like in the airplane with all the plumbing hooked up. I will refine the plumbing lines in the future. I just wanted to get things hooked up so I could test it out.
Photo is a little deceptive. The rudder pedal is full forward and there is about 3/4 to 1 inch of clearance. That includes shoes, stop to stop, and all that.
Hope this gives you some ideas, and that it helps someone out there, even if you decide you don't want to do it this way. This will work for me, but it might not be right for you.
PS
I took your suggestion and angled the aft end of the pulley housing for more clearance.
