Bill Rusk
BENEFACTOR
Sandpoint, Idaho
fancypants - Thank you. Learned something.
Fooling with the fuel sight gauges today. The first thing you will note is they are NOT the same size as the fuel tank bungs. The fuel tank bungs are about 5 3/8" apart (center of hole to center of hole) the sight gauge is about 7 1/4 hole to hole. The fuel lines will not be straight out to the sight gauges. There will be a little bend in there. Its OK.
Next thing you will note is they won't fit straight up and down, they have to be slanted. Its OK. But when you make your slant be sure to watch out for this guy. You will actually straddle this "C" channel brace.
It will look like this from the backside.
I put my lower hole in line with the lower bung and about 1" up from the bottom of the door window (right side).
On the left side you will measure from the bottom of the window channel. That way they are both at the same height.
I used about 3 1/2" of slant. That puts the center of the top hole about 3/4" down from the skylight.
My friend Bernie has built 4 airplanes and is an expert on electrical stuff (I'm not). I was telling him about my idea to put the PTT switch in the throttle....he says....."I think I can help you with that". Next day....bam....I have the PTT switch in the throttle. Has a nice feel to it too. How cool is that? I didn't get a part # from him but I'll see if I can in case someone else might like to do this.
Another shot of the PTT switch in the throttle ball.
Hope this helps
Hope this helps
