Hi guys, I'm back
Lets talk a little about fuel lines and routing. All fuel lines must be secured and well protected from chafing. You can't just let them rub against things.
When you can use adel clamps like this it works well. This is the right rear pick up line going aft around the baggage area. I ran this line outside as I will be using a fabric headliner and this routing will give the least profile. It will just follow the bottom of the wing to fuselage junction. It will only be noticeable to someone who really knows cubs and is very observant, like Jason Gerard or Steve Pierce.
Another photo of the same line.
Now here is a mistake. I had a helper and I did not give enough direction. The line needs to be as low as you can get it to the structure to ensure that it is even with, or below, the outflow from the tank. The picture below shows it about an inch above the structure. Not good......
This is where it should be ...... note it is sitting on the structure.....
All of your fuel lines should be as low as you can get them at the pick up points and they should all go in a continuous line downhill to the low point, drain, fuel valve etc. You do not want a place for water to gather except at the sump. There are places where the adel clamps just don't work out, so here is another idea. Wrap the fuel line with cloth tape, or I like to use plastic tubing like Nylaflow, then wrap it to the structure with flat rib stitching cord. Smear a little epoxy over it all when done and it will hold quite well and have a minimum bulge under fabric. Tie wraps are not such a good idea unless you protect the fuel line quite well as they will chafe right through aluminum lines (steel too).
Here is a place where I used cloth tape and smeared a little epoxy on there as well.
This is the right rear line again. It will transition inside to prevent showing through the fabric on the outside. This will have a different routing if you are going to use a metal headliner. I will have a bulge for a few inches inside the headliner until it goes behind the side panels, but again I don't think it will be all that noticeable. Note that this is the only junction, or joint in my fuel lines. Each junction is an opportunity for a leak and also quite possibly a reduction in flow. Even if you have to scrap a little fuel line and re-bend em a few times, try to get the lines in without a bunch of joinings.
Another rib stich cord attachment.
Not the best picture but the left rear line runs down in the gap between the window channel and the structural tube. This is an easy one and when its all covered and painted no one will know its there.
More to follow
