Wag@+2 - thats a Red Fox hat. Pete - great idea, unfortunately Stabs are covered.
Folks
Fuel Pod
Today I did a quick trial fit of the Airglass Fuel Pod. Seems to fit fine even with the extended stick and box built to handle that. (noted earlier in this thread).
I think I have offered my thoughts on this but if you will indulge me I will again. I think the fuel pod offers a lot of advantages.
The Bill Rusk "Build for 90% of your flying" rule.
Most of our flying is around the local area, putzing around the local grass strips, maybe to a nearby sand bar or gravel bar. Going over to a friends house/strip. etc. Then once or twice a year we go to Johnson Creek, OK18, New Holstein or someplace like that. The bottom line is for most of us 90% of our flying is local. For that mission we don't need a HEAVY, cross country, auto pilot, reclining seat, dual door, Cub with 72 gallons of gas. What we really need, for local fun flying 90% of the time, is a light, fun to fly, C-90 powered Cub. But some of us can only afford one airplane so we make some compromises. The idea is not to compromise such that we build a Cub for only 10% of our flying and don't really enjoy the other 90%. So.......do you need lots of fuel just to putz in the local area? Probably not! (unless your "local area" includes the Brooks Range). The problem with having lots of tank
capacity is most folks keeps their tanks full to avoid the moisture condensation issue. Thus not only do you have the extra weight of the tanks themselves, you are carrying extra fuel, which effectively adds weight. So with the 24 gallon tanks you add about 15 pounds (I don't have an exact #yet but I will) then you add 12 gallons at 6 pds a gal = 72 pounds, and now... just fooling around the local area you are carrying an extra 87 pounds. With the fuel pod you can be light in the local area but strap on the pod, weighs about 25pds, so it will be heavier than the added tank weight between 18's and 24's but you have an additional 32 gals Vs 12 added gallons with the larger tanks. Light when you want to be light and fuel for the long cross country trip.
Physics
The more weight you have up high in the wing the easier it is to stand the airplane on its nose upon landing. When you brake all that fuel sloshes forward and then wants to rotate about the pivot point which in this case is the wheel axle. There have been more than a few of the cubs with 72 gallons of fuel (2 X 24 tanks plus 2 X 12 tanks, a common configuration on a lot of the Smithcub/Backcountry Cub kits) that have been stood on their noses. Its just physics. It is an issue on all aircraft with the fuel located up in the wings. Pretty common on a lot of the old biplanes. So the more fuel you have up in the wings the more careful you must be while braking on landing, thus longer landing rolls. Not only must you fly faster on final, to generate the lift required to support the weight, you touchdown faster and then can't brake as hard. A triple whammy. So a 20% increase in weight increases the landing distance by 40% or more. Rough rules - don't get too technical on me folks - I'm just trying to make a point. With the fuel pod the weight is low so braking hard has MUCH less adverse effect.
The pod does not seem to add any drag, and in fact, some have reported a slight 1 or 2 knot airspeed increase in cruise. It seems the pod smooths out some of the turbulent airflow from the gear struts. There may also be some adverse effect from extra fuel in the wings on the roll rate. A pod puts the fuel a little closer to the longitudinal axis of the fuselage. Thus the wings don't have to fight the longer moment arm to move that weight. In some circumstances it is much easier to add fuel to the pod (tough to stand on a ladder on floats to get up to the wing tanks) as the port is down low, then pump the fuel up into the wing tank.
Design
As long as I am on the subject of fuel I will offer another opinion. I do NOT like the fuel tank design whereby the tank hangs from the lid. Or where the top of the tank overhangs and is attached to the spars. This is
UNSAFE. This is a feature of some, or perhaps all of the 30 gallon tanks. In a mishap, even a hard groundloop, that tank top will be ripped open spilling fuel everywhere. Big time fire hazard, and if you are covered in fuel, even if you manage to get out you will be badly burned. I have personally seen this (mishap at E.Tenn fly-in) but thankfully in that case there was no fire. This feature is also part of the Hatz Classic and I still don't like it. Put the tank in a cradle as per the original Piper Supercub design.
My last Smithcub had two 24 gallon tanks and they are nice but on this build I am going back to two 18's for all the reasons above.
You might remember from a previous post I welded in some saddles with a nut so I could use an Eyebolt to attach the pod strap. It will make for a cleaner installation and also less mess when the pod is not on. (disregard the safety wire, my eyebolts were/are not long enough so I will have to order the proper ones, this was just a test fit)
Top of the saddle. You do not have to worry about the eyebolt backing out. It can not rotate once the strap is attached.
I was able to find the pod used in Portland and I owe a HUGE THANKS to DW for storing it, and then for packing and shipping it to me. THANK YOU DW.
You can also do a combo pod with cargo space and fuel, or a cargo only pod and use some type of fuel bladders in the pod. The downside to that is it can sometimes be a real pain to find a place to land, lift a 30 plus pound bladder up on to the wing to transfer the fuel. Lots of options. Choose what works for you and your mission.
Hope this helps
