Folks
In the continuing saga.......Wip issued a Service Bulletin for the pump out tubes and so I am replacing all my pump out tubes in order to bring things up to par.
The original tubes had a flat bottom and I guess it was possible (pretty unlikely but possible) for the tube to suction seal itself to the bottom of the float so that it would not let the water in.
So Wip recommended shaping the bottom of the tube like this, so that it would not suction seal itself up.
The tubing they use (for the 2100's at least) is available from McMaster-Carr. It is part #5181K27 Crack resistant Polyethylene tubing 1/2" ID and 5/8"OD white.
But, as you might be able to see, it needs to be flared to fit the pump out fitting.
I used a piece of dowel rod. I heated the end of the tubing with a heat gun and then while it was soft forced to onto the dowel which expanded it enough to later fit on the pump out shaft. It actually worked out pretty well.
So......another SB complied with.....and the floats are coming together. Next up = putting a floor in the float lockers.
Hope this entertains or helps
