ENGINE WEIGHT DATA
This is still a little incomplete but I got these numbers from Bart at Aero Sport Power. Bart is a Cub guy so he understands the weight issue. If you folks don't already know it he is one of the top engine builders out there. Someone told me the top 5 places at the Valdez Short Field TO/LND contest all had Bart engines this last year. He does great work and has an impeccable reputation. Highly recommended.
Weights may vary
All engines have fuel system, 2 mags, starter
ECI O-375-C2A 283.5LBS
ECI O-320-D2A 276LBS
ECI IO-340 280LBS
LYCOMING O-360-A1A 285LBS
SUPERIOR O-360-A1A 284LBS
So a NEW 0-360 is going to be very close to 285 pds, an 0-320 will be 276 or approx 10 pounds lighter.
My 0-360 engine built by Bart (with extra attention to weight) came in at 270. That is with a carb, pmags, flywheel (lightened) and starter.
