Lately my four EGT readings (EI Gauge) have been diverging -- #1 remains the coolest, #2 somewhat higher but #3 and #4 slowly creeping up over the last 30 hrs until the spread from coolest to hottest was 200F+ when in the recent past the spread was 80 to 100F. Also #3 and #4 EGTs increased rapidly on takeoff. The EI gauge red light glows when the differential exceeds 195F, so the light was on through the last flight before we started the diagnosis.
My IA, Bob Eckstein, and I checked the primer to make sure it was not leaking internally, we checked the timing (spot on), made sure the impulse coupler was ok, checked compresson, made sure the fine wire plugs were OK (resistance check, cleaned and inspected with a magnifying glass -- all fine.
Then I made an advanced Google search on this subject and turned up this 2003 Supercub.org thread: http://www.supercub.org/forum/archiv...p/t-20372.html
Probes coated with carbon & lead -- so I removed the probes and used a Dremel with a brush and voilá, on the next flight EGTs returned to an 80F spread.
So thanks to a Supercub thread from 8 years ago and an experience shared by "Speedo", we got a big clue that led us to the solution -- thanks Speedy, thanks Supercub.org!
Darrel
