Results 41 to 80 of 92
Thread: Scott 3200 Taiwheel refurbishment
  1. #41
    3,065
    Grease depends on how the airplane is used. I treat it like a boat trailer wheel. On assembly, I just pack the bearings and cover the internals. If the guy works the airplane hard and lands on a lot of beaches or dirt strips, I tell them to pump grease through them quite often. This will push grease and water out and leave relatively clean grease inside. Works for the swivel assembly and the axle, both. But there is no substitute for cleaning them and repacking them, at LEAST every annual. More often if you play in the dirt.
  2. #42
    kiwicubber's Avatar
    Jun 2007
    Te Kowhai, New Zealand
    145
    Slightly off topic, but what is the difference between the 3200 and 3200A tailwheel?
    Are they interchangeable?
    cheers Bill
    Bill and Neroli.
    www.supercub.co.nz
  3. #43
    19,593
    I will have to ask Bill Duncan the difference. I believe they are interchangable. Might be the heavy duty steering arm.
  4. #44
    Mar 2014
    2
    Great thread! After watching Steve's videos (thanks Steve!) and receiving my ABI rebuild kit I am pereplexed on how to remove the bearing race (16). Did I miss something? I also had all 5 springs (7) in my Citabria 7GCBC. All but 1 pin had sheared on the thrust plate (6). Should I go back with 3 or all 5 springs? Thx all
  5. #45
    19,593
    Sometimes I can run a few beads in the race with my TIG and it will fall out when I smack it. Other times I have to weld a large washer to it. If it isn't to bad I don't worry about it, doesn't rotate like the wheel bearing.
  6. #46
    Mar 2014
    2
    Steve thanks for the ultra-quick response. I may re-inspect and reuse the race if OK. Otherwise I have several friends with MIGs and TIGs to put a bead or washer. Thanks again Steve!
  7. #47
    Sep 2013
    Fremont, NE
    151
    Can anyone recommend an aviation-friendly spring shop in the lower 48 to get some tail wheel leaf springs re-arched?
    George
  8. #48
    19,593
    My Dad uses a shop in Memphis. I can get contact information but any local spring shop can do it.
  9. #49
    Ursa Major's Avatar
    Oct 2002
    Coeur d'Alene, Idaho
    1,077
    Some shops might not want to work on "airplane stuff". They had no problem re arching a spring set for my "field mower".
    Likes Jim Hann, sjohnson liked this post
  10. #50
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    773
    "atv" ?
  11. #51
    3,097
    .... but any local spring shop can do it.
    I live in Podunk Washington now, but until I was 35 I lived in southwest Los Angeles--
    I don't recall ever seeing a "spring shop".
  12. #52
    19,593
    Pretty common to re-arch springs on big trucks. Pretty common in a large metropolitan area, usually around big truck repair shops.
  13. #53
    Jim Hann's Avatar
    Jun 2014
    Ballwin, MO
    64
    St. Louis Spring did my 22/20 spring. Cash, no receipt, no evidence.
  14. #54
    May 2012
    SE Montana
    214
    Any truck suspension and brake shop should be able to do it. If you have a heavy truck and trailer repair shop around, they should be able to handle it too. Go downtown and look for the old Chevy pickup with a 12" lift. Flag that redneck down and he'll be able to point you in the direction of a capable shop!
    Likes wireweinie, Steve Pierce liked this post
  15. #55
    Lebanon NH
    137
    Scott tail wheels
    Quote Originally Posted by kiwicubber View Post
    cheers Bill
    I belive the 3200 is for the flat spring(used on cubs). The other T/W is for those aircraft that uses the round spring (Cessna 180 or 185). Hope this helps. Best Cliff
  16. #56
    5,129
    The "A" model uses a different steering arm. See page 5 of the attachment. Hard to understand why the Univair price is so much different for such a small change. http://www.supercub.org/photopost/da...emblies800.pdf
  17. #57
    3,097
    Quote Originally Posted by Clifford View Post
    Incorrect, the Scott (and ABI) 3400 series is for the "stinger" tail spring.
    3200 is standard leaf-spring-mount t/w,
    3200A (actually 3224A) is a 3200 with upturned steering arm,
    3200-3 is for two-bolt mounting.
    https://www.airframesalaska.com/3200...els-s/1871.htm
    Thanks Jim Hann thanked for this post
  18. #58
    j3cubcapt's Avatar
    Jul 2003
    Dallas Texas
    23
    Where can I find these videos of Steve’s?
    Quote Originally Posted by DocTX View Post
  19. #59
    19,593
    Thanks hotrod180 thanked for this post
  20. #60
    19,593
  21. #61
    19,593
    Likes Tbag liked this post
  22. #62
    19,593
  23. #63
    19,593
    I need to take the time to cover some more common issues, wear items etc to add to these videos. Hopefully have time in a few weeks.
    Thanks cubscout thanked for this post
    Likes KevinJ, mike mcs repair liked this post
  24. #64
    j3cubcapt's Avatar
    Jul 2003
    Dallas Texas
    23
    Thanks for the links Steve, and if you can those other videos would be great.
    We thank you for your time and knowledge sharing.
    Sent from my iPhone using Tapatalk Pro
    Likes cubscout liked this post
  25. #65
    3,097
    I was hoping that one of the assembly videos might have a secret, cut-and-dried method of adjusting the bottom nut.
    I've always had to rely on trial-and-error,
    too loose and you got shimmy and too tight and it didn't want to steer well or kick out to full swivel.
    I've been counting how many turns to full tight before disassembling,
    then tighten to the same point when reassembling after cleaning & inspecting.
    Just did that with my C180: it was one full turn looser than full tight.
    But got a little shimmy after reassembly, so pulled the wheel back off & tightened that nut 2 flats worth.
    Seems to have done the trick.
  26. #66
    19,593
    The shimmy is because of your head angle not the tightness of the nut. You are keeping it from shimmying by making it harder to swivel. On Cubs I set it up loose so it is easy to turn and break over. It is all by feel for me.
    Likes PerryB, mike mcs repair liked this post
  27. #67
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,615
    You are just masking the problem.
  28. #68
    3,097
    So you're both saying that the tension on that nut doesn't matter? I don't buy that.
    I have enough experience with 3200's to know that head angle is often the cause of shimmy,
    but also enough to believe that the tension on the kingpin nut can be & often is also a factor.
    BTW this is a 10" 3400-series t/w on a C180, & the t/w head angle is fine.
    I don't think I've ever seen a C180/185 stinger that put an 8" or 10" t/w at a shimmy-inducing trailing angle.
  29. #69
    19,593
    Sure, the head tension will help but if you had a good caster angle it would not shimmy. Post a picture of the head angle when loaded at the point that it shimmies.
    Likes RaisedByWolves, hotrod180 liked this post
  30. #70
    3,065
    The torque on the swivel bolt is to preload the bearing. The drag that's felt when trying to swivel the tailwheel is a function of the five (or whatever number you like to use) springs that apply pressure against the thrust washer, up inside the tailwheel head.
  31. #71
    Meanwhile,...
    5,230
    I don't have the big tail wheel but the only time mine has ever had a shimmy was when it was a bit low (but didn't show it) on tire pressure.
  32. #72
    3,097
    50psi on the 10" t/w tire, good angle.
    I'll get a pic of the angle later today.
    Not much you can do if the angle is trailing,
    never heard of re-arching a stinger like you can a leaf spring.
  33. #73
    3,097
    Yes, but tightening the kingpin nut also compresses those springs.
    Don't know any other way to do it, except maybe add spacers to each spring--
    like adding washers to an oil pressure relief plunger.
    Maybe the springs are weak?
    Tailwheel is an XP Mods, installed about 7 years ago--
    not that long, so I doubt it's the springs.
  34. #74
    3,065
    The only way to adjust spring tension is to go to all five springs or remove them one at a time until it feels right for your operations. The few thousandths of an inch that you might be able to compress the bearing by over torquing it will have a negligible affect on spring tension. Any drag added is the result of excess pressure on the bearing.
  35. #75
    4,030
    My baby bushwheel head is pretty loose, breaks free really easy. I did what bushwheel bill said and added a block between the spring and fuselage and the angle is good. It never shimmy’s.
  36. #76
    19,593
    Bill got a big truck mud flap and cut a bunch of spacers out of it for that purpose last time he was here.
  37. #77
    Jul 2010
    Elizabeth, WV
    579
    Was it a plastic mudflap instead of rubber? I'm sure rubber would be a bit too squishy.
  38. #78
    19,593
    Quote Originally Posted by N86250 View Post
    Hard rubber from an 18 wheeler mud flap. Doesn't compress.
  39. #79
    11,066
    you NEED TO ADD more shims under your bearing if tightening the nut stops swiveling on a cessna style scott
  40. #80
    3,097
    Tightening 2 more flats didn't stop the swiveling,
    it's stopped the shimmying.
    Likes Mander liked this post
  1. Scott 3200 on J3
    By SJ in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 11-15-2006, 02:29 PM
