BENEFACTOR
I wore the king pin bore out on mine, Knurled the kingpin and heated the head and pressed it back in. Lasted quite a while.
I have never see a 5 spring pac. Head angle is off and will be worse with a load. New springs should fix both problems, (is that new 3 leaf in bottom pic?) will need a new clamp under spring. what is the width of the old springs you have I might need them for a project ?
Re arch the springs.......................
Before and after ABI overhaul kit, new spring and some paint. 36 gal autogas.
View attachment 54069View attachment 54070
I did read that in the instructions, AN42-7 eyebolt IIRC. NAPA is closed on Sunday. Rudder horn does show wear. Thanks!
