Results 1 to 13 of 13
Thread: c90 cam question (again)
    Apr 2007
    4
    Ok, I read a lot on this forum about the cams available for the c90 I'm presently overhauling. I bought 4 eci cylinders and NFS 9:1 pistons I got a spare cam on hand and I have to make a choice, please help me with your advices...
    531076 cam from the engine (1825 hrs on it) and I measure 0,330" of lift
    it's the 24° overlap cam
    I have 2 overhaul manual with one saying 0.330 lift and one 0.410 but mine is 0.330
    626608 cam (O-200 cam 0 hr on it) grinded for more duration it's the 35° overlap cam and I measure 0.360" of lift.
    What would be your choice?
    Eric
    Jerry Burr's Avatar
    Sedro Woolley, Washington.
    712
    I would vote for door #1. The 90 cam has a rounder profile and therefore milder valve action. The pointey O-200 cam will give more upper cyl wear per turn. The only way I know to increase duration is to grind the base to effectively widen the lobes. I wouldn't care for that process in an airplane. Jerry B.
    White City, Oregon
    951
    I agree with Jerry....Plus I would never, ever....did I say NEVER...use a re-ground cam EVER again in a fresh engine....last one I used lasted 10 hours before the cam lobes went flat and wiped out the lifters...
    Brian..
    nd
    3,723
    In the overhaul manual, that .410 was a mistake believe it or not.
    Apr 2007
    4
    Quote Originally Posted by Jerry Burr View Post
    Thanks Jerry,
    in fact, the O-200 cam have visibles rounder lobes than the C-90 one. At least 0,030" have been removed from the base to compensate what was removed at the top, probably 0.030" more to add the additionnal lift. The seller claims that this cam would turn a 54/68 prop at 3900 RPM. I would expect to turn a 74" prop at 3000 RPM with apropriate pitch but I'm not sure now...
    Eric
    Apr 2007
    4
    Hope this is the only mistake
    nd
    3,723
    Stock exhaust on a c90-8 with a 7440 mac, wide open cruise, my tach shows 2500 with the 531076. It isnt one of the premier tachs out there so could be off a little.
    Mark Lund's Avatar
    Jewell, Iowa
    154
    O-200 with ECI Cylinders, standard ECI pistons, 531076 cam, 50 degree air temps, 1200 ft msl, Legend Cub style exhaust (no muffler), McCauley 7148 prop, full throttle = 2525 rpms in flight.
    Oct 2003
    Hartford, Wi. HXF
    73
    I think if you check the power curve charts for both engines, you'll see the C90 puts out more HP. Use the 90 cam
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    I have the master for a 530788 at a cam shop in Mpls if you want to use it. Just send in a old cam and have it remade for about $150.00. Have to use straight pipes or a 4 into one exhause. Can't take any backpressure.
    nd
    3,723
    Thats why continental went to the 531076. For stock exhaust.
    May 2004
    Sweeny, Texas
    1,454
    Just mentioned it in case he wanted to make more power
    Apr 2007
    4
    Quote Originally Posted by Roger Peterson View Post
    Thanks I'm interested in the plan if you have it. PM me if you want.
    I think I'll have to sell this spare cam,
    Eric
  1. A Performance Question and a Flap Question
    By bob turner in forum Modifications
    Last Post: 01-11-2015, 10:40 PM
Tags for this Thread
