Results 1 to 18 of 18
Thread: X-Brace
    Binty's Avatar
    Jan 2005
    South Island, New Zealand
    381
    X-Brace
    Im looking for some info on the overhead X-brace as one has been installed in our cub from way before we bought it.
    Bushwhacker Air's Avatar
    New York
    435
    No doubler - a mod added to the existing tube. My understanding is it was added to keep the right flap/wing area from coming into the cabin in the event of a crash and hitting the passenger. Size: .875 x .035 tubes
    Chris Hatin
    Bushwhacker Aircraft Company, LLC
    www.bushwhackerair.com
    Properly trained, a man can be a dogs best friend...
    19,972
    Here are a couple of not so great pictures. Like Chris said, 7/8"x .035" wall tubes. I was in an accident where the right wing hit the ground and the rear spar carry-thru tube collapsed behind my head and the fuselage side caved in. The "X" brace will let the wing fold up and help keep the cabin structure in tact. I have installed it in everything from PA15, 16, 17 and 18. Atlee Dodge has the STC.
    Thanks WindOnHisNose, Mattpeed thanked for this post
    Likes OLDCROWE liked this post
    nanook's Avatar
    Aug 2002
    northern alaska
    1,693
    Actually the X brace tubes are .875 x .049.....the short .50 tube(shoulder harness holder) is .035, all are 4130
    19,972
    Nanook is correct. I tried going off memory and that is always bad. I knew I got a bunch of 7/8" x.049' wall drops from Air Tractor for a reason.
    Likes WindOnHisNose liked this post
    Jun 2007
    New Zealand
    489
    The existing diagonal can fail in buckling due to compression loads in a crash and bend down into the cabin. At least that is what happened to my Cub when a previous owner crashed it. Not as severe as Steve's crash, but more of a knock and you can imagine what would happen.
    From memory the original diagonal is only 1025 on an original Piper fuse, so the amount of strength this adds in this area is enormous.
    When I first started buying stuff from Atlee Dodge he'd include the X-brace STC and a hand-written note; "This is a freebee. You must do this mod". That the guy would care that much about someone in little old New Zealand was enough; all I had to do was cut the tubing to length!
    Cheers, Andrew.
    Darrel Starr's Avatar
    Plymouth, MN
    2,524
    Some more pictures.
    New York
    435
    The original diagonal is Piper part #10562-81, and calls for 7/8" x .035 1025. Not sure what Atlee calls for in the STC, but using 7/8" x .035 4130 will give you a 30-40% increase in strength by nature of the material alone over the original Piper engineering. Not sure where the .049 is coming from (again, unless that is what Atlee calls for)
    Chris Hatin
    nanook's Avatar
    Aug 2002
    northern alaska
    1,693
    Right off the STC instructions from Atlee
    Jul 2019
    11
    Quote Originally Posted by nanook View Post
    What’s the preferred method of attaching the shoulder harness to the .5” tube? Atlee’s attachments won’t work for a .5” tube.
    Does a thimble with a cable and nicopress sleeve work? Any other ideas?
    Thanks hangarmonkey thanked for this post
    19,972
    The 1/2" tube is a guide for the belts only, the inertia reel is attached to the rear spar carry-thru tube.
    Likes nanook liked this post
    Jul 2019
    11
    Ah, that makes sense now. Thanks for educating ignorant me on this subject.
    19,972
    Thanks MEM-PA12 thanked for this post
    May 2017
    740
    Quote Originally Posted by Bushwhacker Air View Post
    Column buckling strength of 1025 and 4130 is basically the same. 4130 is only stronger in tensile.
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    761
    Dodge uses .049. Rocky Mountain Airframe calls for .035.
    3,669
    For "slender" columns, that is correct. See "Slenderness Ratio" about halfway down in this page. https://www.engineeringtoolbox.com/e...la-d_1813.html
    Jul 2020
    11
    Reading through this thread it seems a no brainier to do an x-brace. How are the carbon cubs able to get away with a V-brace? Does the V also protect against these issues or are there other changes to the airframe cub crafters made to protect against these issues which allows them to get away with just a V brace?
    19,972
    V brave serves the same purpose. Husky has the V brave as well.
    Likes DENNY liked this post
  1. Top X-Brace
    By Grizzley in forum Modifications
    Last Post: 03-05-2010, 02:33 PM
  2. Reverse Dog Leg Brace
    By behindpropellers in forum Modifications
    Last Post: 03-10-2006, 10:14 PM
  3. PA-12 X-brace and cowling
    By Shawn in forum Modifications
    Last Post: 03-31-2004, 12:50 PM
