Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
Thread: STC for baggage box on PA18
  1. #41
    aktango58's Avatar
    18AA
    9,346
    I agree, but one would be giving up several inches of baggage area depth by doing such....oh well.....some guys are stuck with those rails.
    I am considering how much damage to the powder coat it will be.... or cutting off the top of the carbon fiber to fit....
    will look in Anchorage.
  2. #42
    11,525
    You will be damaging powder coat with every rivet anyway... No a big issue. Prime the spots Will it fit then?
    Also i thought they DONT field approve otem once an STC is in process?? I would verify
  3. #43
    aktango58's Avatar
    18AA
    9,346
    Looked at the plane again a bit ago. The rails have about four spots of welding to take out to remove. I will get into the packet of STC's and such that came with the frame, and talk to my buds at the FAA to see what it will take...
    Why do you have to go and build something AFTER I have already gone down the old road??????
    so many cool parts, so little aircraft and $$$$
  4. #44
    8856Charlie's Avatar
    Jun 2008
    87
    The frame I am doing my test fit in had the welded rails and supports in, 30 min with my dremel multi tool took care of that, was surprised it cut welds that well. test fit the baggage with lid and I am very happy, here are a few shots.
    Randy
    And Yes the frame is in my living room, I don't know why my wife puts up with me but I'm glad she does
Name:	baggage with lid installed 003.jpg
ID:	1974   Click image for larger version.
Name:	baggage with lid installed 004.jpg
ID:	1975   Click image for larger version.
Name:	baggage with lid installed 005.jpg
  5. #45
    aktango58's Avatar
    18AA
    9,346
    Randy,
    Since my PMA'd frame has the extended baggage rails, and the STC paperwork for the frame only says 'if extended baggage used flight manual 1801 (or some number like that), dated ... must be used'; why would I need a different STC for your box?
    Asking as a solution to more than one issue I have. Also, is there a reach hole in the top, or can one be added easily to push stuff from the back to the front? AND, can you make them in any other color? Like White?
  6. #46
    Jun 2008
    87
    Will know more on the STC question after our next FAA meeting. Does your STC specify what material was to be used for the floor and sides of the Baggage? A hole can easily be cut in the lid, maybe hinge the lid for the hole or make a fabric cover so the lid can be used as a floor for the upper?(looking at making a rear bulkhead for the topside of the lid) Yes colored gel-coat can be added but it will add about 28 OZ and a little $$.
  7. #47
    aktango58's Avatar
    18AA
    9,346
    I will see you and talk to you in Anchorage.....
    I will do more looking before; no specifics on size, material or shape of extra baggage in my paperwork.
  8. #48
    aktango58's Avatar
    18AA
    9,346
    I took a scale and checked the weight of my aft baggage...
    I have an .016 upper baggage floor and aft bulkhead, .o16 sides and aft bulkhead below, and .020 floor in the bottom. I have plastic still on all of the .016, no paint yet. The combined weight was 6.56 lbs. There is still the side rails, nut plates and screws to install, which will bring the entire weight up... but it looks like a good 25% savings in weight with the CF baggage...
    Anyone know what the airframes angle for aft baggage total weight is?
    Likes Airguide liked this post
  9. #49
    Minnesota
    17
    Randy, here anything from the faa? Has any one tried 337? thanks
  10. #50
    Jun 2008
    87
    STC is not done yet, held up on me now I'm going through a divorce. Jerry Lee in Glennallen installed two under a 337 I belive, let me see if I can get a copy.
    Randy
  11. #51
    aktango58's Avatar
    18AA
    9,346
    for me too please!
  12. #52
    Feb 2015
    193
    What ever happened with this great mod?
  13. #53
    Feb 2015
    193
    Bump... Does anyone know what happened to this carbon fiber extended baggage mod?
  14. #54
    Jun 2008
    87
    Slowjunk, I still have it I have not finished the STC but am finally back to it. Had a severe case of life happening, divorce, shutting a business down, new job. I am planning on having one on display at the AK Airmans show and will be on the website soon. Just made one to put in a buddies project they sure install nice, lots of room and light. Carbonconceptsak.com is the site building lots of cool carbon parts for cubs!
  15. #55
    Feb 2015
    193
    Quote Originally Posted by 8856Charlie View Post
    It sucks that you had those difficulties. Thanks for replying and providing the update. I really liked your solution and it's awesome that you are now finding time to work on it. I hope you are able to keep us up to date.
  16. #56
    Dec 2004
    Nikiski, AK
    56
    Have you considered doing one of these for the Willow Mountain STC? I am redoing my fuselage now and am considering that mod.
    Thanx for your time
  17. #57
    Oct 2020
    Whiteshell Manitoba
    43
    Bump.. Any updates on this baggage? seems better then the other options, is it STC'd?
    1967 Piper PA18 Super Cub
    Whiteshell Manitoba
  18. #58
    nanook's Avatar
    Aug 2002
    northern alaska
    1,694
    Well, he said he was getting on it five years ago and still not certified...he has gone down the experimental path...
  19. #59
    Oct 2020
    Whiteshell Manitoba
    43
    Quote Originally Posted by nanook View Post
    damn....
    Whiteshell Manitoba
  20. #60
    3,524
    Another deceased equine about to take corporal abuse . . . .
    Extended baggage is just a non strucural box, whether aluminum or composite. If you attach it without drilling or welding on structural components of the airframe why does everyone think they need an STC or field approval? Show me the reg that requires anything more than a log entry.
  21. #61
    11,525
    Yup.
  22. #62
    aktango58's Avatar
    18AA
    9,346
    Since this thread has been in limbo, there have been quite a bit of 'advancements' in the education and understanding of the regulations by aircraft owners and manufacturing.
    Words like "battery", where in the past was argued by the FAA that you had to have an STC'd battery for model of plane, has now been corrected to be understood that it requires a battery designed and built for aircraft. Same for skis and many other parts. (For aircraft built under CAR-3??)
    With that in mind. Carbon Concepts has been limiting their efforts on items that do require STC's, (pods), and not trying to get approvals for parts not requiring massive paperwork of farm animal roping efforts.
    Buy the slip in pod, and go!
  23. #63
    akskibum's Avatar
    Dec 2011
    Anchorage Fairbanks
    55
    You don't need an STC for a pod if you fly it as an external load.
    Likes DENNY, aktango58, mike mcs repair liked this post
  24. #64
    aktango58's Avatar
    18AA
    9,346
    Quote Originally Posted by akskibum View Post
    Great point!
    But all flights would then be in restricted category, limited to Alaska only, and need external load listed on my insurance...
    But it would work!
  1. model change PA18-125 to a PA18-150
    By cubcrasher in forum Modifications
    Last Post: 02-23-2005, 03:03 PM
  2. 180 lb baggage etc
    By flysurge in forum Modifications
    Last Post: 06-16-2003, 04:21 PM
