Rib Repairs
Leading Edge Repairs
Trailing Edge Repairs
Tip Bow Varnish
Trammel Wing
Lift Strut Fittings Checked
Butt Hinge Fittings Checked
Drag Wires Tight
Drag Wire Anti-chafe
Strobe Wire
Nav Light Wire
Nav Light Ground
Pitot System
Landing Light
Landing Light Wire
Electrical Wires Secured
Rib Lacing
Jury Strut Brackets
Aileron Hangers
Flap Hangers
Flap Bellcrank
Flap Stop
Flap Spring
Aileron Cable
Aileron Pulleys
Cleaned Wings
Repair Diagram Completed
Pre-fabric Tape
Blow out the wing with air including the false spar and spar caps to get rid of all the drill cuttings etc.
We use one piece tapes from the trailing edge on top of the wing, around the leading edge and terminated at the trailing edge of the bottom of the wing.Hey Steve, on #45, do you really mean wrapping the tape around the leading edge? And would you want to mention adding the drain holes on the bottom of the trailing edge of the wing (maybe specifying exactly where)?
