I know a few guys who have crashed Cubs and been splashed with fuel. Without exception it's been from the wing tanks, not headers. If you're building a Cub from the ground up (like CC does) it probably makes good sense to eliminate expensive outsourced parts. Duh. In my plane? I have headers and a L/R/Both fuel valve. I didn't ask for it. When I took my airframe to the recognized PA-12 expert for the fuel system installation that's what he put it. With Atlee headers, too. I have no reason to think my fuel system is superior to anyone else's. I'm comfortable that it isn't inferior, either. It's proven airworthy. That's satisfactory for me and my family. If you're one of those guys who flies with minimum fuel in order to allow you to get into short places in the mountains to chase sheep, you're bucking the winds while you work your way under the clouds to the only notch that will let you get to the other side, you line up to fly through only to be met with turbulence that hurts, the only option to escape is to do a high power 60* plus face bender right at the granite wall that's filling your windscreen, and the very last thing you want is to hear your engine stumble? Your decision to remove your headers might be different than the other 99% of Cub owners who will never push themselves or their planes to that extreme. You know what? If it doesn't apply to my capabilities, performance potential doesn't matter. I could get along with or without headers. It sure as hell isn't worth arguing about.
My Atlee HD header tanks are aluminum.
SB
