Page 1 of 2 12 LastLast
Results 1 to 40 of 47
Thread: 100LL in small gas engines
    Stowe, Vermont
    82
    I'm tired of the short shelf life of regular auto gas in my chainsaws, weedwhacker, generator, snowblower, and other small engines. Seems like I'm always having fuel related problems. Whether it's the ethanol or just poor quality gas I don't know. I use Stabil in my gas cans and it seems to help a little.
    Other than the additional cost are there any issues using 100LL in these engines? Fouled plugs? Can I mix it with 2 stroke oil for the saws?
    DesperadoPilot's Avatar
    Jan 2009
    Brazoria, Texas
    412
    I burned about 5 gallons of AvGas in my Harley-Davidson panhead once. Ran fine. Actually, it seemed to run quite a bit better. But I only did it that one time once when I was at the hanger on my bike and didn't have enough gas in it to make it to a gas station.
    I fly IFR (I Follow Roads).
    jjack's Avatar
    Dec 2007
    coastal n.c.
    214
    I've been running 100LL in lawnmowers, generators, Polaris Ranger, ATV's, Harleys, chainsaws, and boats that sit up all winter with no ill effects over many years. Only had a problem with one small chainsaw and resolved by adjusting for the high octane. Oil mixes fine with 100LL. Just my experience, I'm no expert on the topic.
    JohnnyJackson
    11,110
    It works fine, generally. I've run it in generators, MANY hours in outboards, etc, etc. Never had a problem, and it's good clean fuel.
    These days, auto gas is who knows what.....
    Dough Head's Avatar
    4AK6/DVT
    249
    I usually run a 50/50 mixture, or a 75% mogas/25% avgas in the small engines with no problems. Left my chainsaw with 75/25 mix for 3 years without starting it, and it started on the third pull.
    JayH's Avatar
    Mar 2005
    NE Iowa
    269
    I run it in all the stuff you want to run it in. Works good, it's the only thing my Gator will run on. Mixes with 2 cycle fine. You won't see a cleaner carb.
    Aussie Scout's Avatar
    Aug 2010
    Tasmania Au
    87
    My experience is all two strokes run fine, even better sometimes on 100LL than they do on auto fuel but my sawmill has a 4 stroke Briggs and Stratton V Twin and nothing fouls the plugs faster than a bit of avgas. Reverting back to unleaded auto gas cleans them again ...
    Scooter7779h's Avatar
    May 2004
    Anchorage, Alaska
    1,025
    Thats all I have run for 30 years. First 80/87 then 100LL.. Premix, or injection 2 strokes for snowmachines, outboards pre-mix, chainsaws, weedwhackers, no problems. Also have run my Honda 1000 generator probably 75 hours exclusively on 100LL, at about 70 hours it was misfiring, and I just had to clean some clinkers out of the sparkplug. 100LL is very stable and can be stored a long time unlike this crap they sell with oxygenatives in it. It is a great high octane fuel, that is stable and mixes well with 2 stroke oil. Only downside is it has some lead, so you need to look at the plugs and possibly carbon depoists on the piston/cylinders with real high use volumes.
    PA-12 fan
    pittsdriver's Avatar
    Feb 2008
    221
    Chevron Supreme works the best of all the brands of auto gas. No ethanol and it has additives to keep it from gumming up. The only thing I used in my jet skis and snow machine and never had to clean carbs at the beggining of the season.
    StewartB
    Guest
    My Yamaha 1000w gennies like 100LL alright. I had to change a plug after 11 years on one but aside from that they've been trouble free. My Honda 2000 inverter gennie not so much. I have to clean that plug every 15-20 hours if I run LL in it. As for 2-strokes? They run but according to radar guns and computer engine monitors a 2-stroke is happier with pump regular, at least up here where we haven't had any oxygenated fuel for many years. I suspect that makes our pump gas a little more stable than the stuff you lower-48ers get, too. My seasonal stuff like snowmachines, 4-wheelers, and boats use pump regular that's been stored for up to a few years in 55 gallon poly drums and it works just like fresh gas.
    SB
    Jun 2004
    Belgrade, Montana
    56
    Oh yeah. In my chainsaw, lawn mower, weedeater, and other small engines 100LL is the ticket. They sit full of avgas all winter and start on the second pull in the spring, while other guys are pulling the carburetors off to clean the stinky autogas gunk out..
    Yep, the spark plugs only last 8-10 years, though..
    The only use I've found for autogas is in my autos.
    May you always choose the time and place you land..
    Stowe, Vermont
    82
    Thanks for the feedback, I'll run 100LL this summer and see how it goes.
    Clearwater,Fl
    2,559
    When adding oil to gas, does that lower the octane?
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,059
    While my experience is a little different, I poured about a quart of Iowa E10/2cycle oil into the Lawnboy mower last May and it started on the first pull---was very surprised. The fuel had been mixed the previous August and that quart sat in a sealed/airtight 2 gallon plastic jug through the winter in an unheated garage. I don't remember running the mower out of fuel in Sept. when I cut the grass the last time for the season so there was probably a trace of fuel that sat in the tank for seven months. Not sure how you guys would rate that for "shelf life" but I don't think it is to bad.
    hottshot's Avatar
    Jun 2002
    Joseph ,Or
    1,083
    the only thing that I have had NOT like 100ll was my honda weed eater.. 4 stroke, for some reason it just wouldn't run for beans.... everything else ATV Motor cycles mowers and even my Turbo Apex loves 100ll
    StewartB
    Guest
    Quote Originally Posted by Fortysix12 View Post
    I'm not sure lowering the octane is the proper description but the oil will displace the available gasoline and will subsequently make the engine run leaner. Lots of guys in Alaska will add 2-stroke oil on really cold days thinking since the cold already leans a carbureted engine's mixture the oil will protect them. Many a guy has burned a piston as a result, too.
    SB
    behindpropellers's Avatar
    NE Ohio
    6,844
    I make it a point to fill everything up and run it a bit with 100LL before each winter.
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,059
    Here is a picture of the jug I store the E10/2 cycle oil in. There is about a quart and a half left in there that was mixed in August and I'm pretty sure it will be good next April or May when I start the mower. Judging from the shape, I'd say there hasn't been a lot of air exchange since the Sept. air looks like it contracted quite a bit. That is the secret for keeping auto fuel in condition.
    nanook's Avatar
    Aug 2002
    northern alaska
    1,694
    Stewart, That is interesting that your yamaha 1000 likes 100LL. My Honda 1000 died after @ 200hrs. On a diet of straight or 50/50 mo-100LL....leaded up the valves and guides and trashed the top of the cylinder....I would not recommend running 100LL in any small Honda...2 strokes seem to love 100LL, except when you have to start them cold.....
    StewartB
    Guest
    Likes 100LL is an overstatement. It runs okay on it but honestly it runs better on car gas. Since my doctor found high lead levels in my blood I've quit burning LL in everything but the airplane.
    SB
    adventruousairman's Avatar
    Matanuska Valley, Alaska
    33
    100ll
    Hey there,
    I've been running 100LL in all my equipment for the last 25 years, never had a single problem, from Jonsered chainsaw (same one for 30yrs.) 98 Skiidoo Summit 583, Troybuilt lawn mower, Craftsman snow blower. All 100% LL, no issues. Good luck, safe flying,
    N8052C
    Apr 2007
    Savannah Ga
    738
    I use it in my Quicksilver ultralight all the time it is a Rotax 447 and I mix it with Pennzoil Air Cooled 2 cycle oil and it runs great
    May 2004
    Anchorage, Alaska
    1,025
    @Nanook.... need to run some Marvel Mystery oil in the 100LL every once in a while in the little Hondas to clear the lead accumulations out. No big deal, and the things will run for ever. I have way over 200 hours, looks clean as a whistle in my 1000's combustion chamber due to the MMO servicing.
    PA-12 fan
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,005
    Yes, oil reduces the octane.As an aside -FWIW- high octane fuels are not only more resistant to detonation but also burn slower than low octane fuels. Although avgas is GREAT for its long term integrity it is likely to cause plug fouling in lower compression engines that don't actually need it. They don't generate high enough peak combustion temps to vaporize the lead and it deposits in the plugs.Also, due to the slower burn rate,peak combustion pressure occurrs later than optimal in the power stroke and power is lost. In this case advancing the timing will help. Just put it back when returning to standard fuel. Personally I would think a 50% avgas blend would be a good compromise. And yes, our modern mogas is total crap!
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,059
    Perry, you sound pretty knowledgeable so I'm wondering if you know what the difference is between the 87octane E0 that is available now vs. 15 or 20 years ago here in Iowa. In other words, what hydro carbon molecules have been changed? I thought they were probably the same. I do understand that the gasoline portion of the fuel you guys out west get can't be used by itself.
    nanook's Avatar
    Aug 2002
    northern alaska
    1,694
    Scooter, Thanks for the tip....MMO=coal oil, is that still true? There are going to be times that you just can't get around draining fuel out of the airplane for the generator....
    StewartB
    Guest
    MMO- light weight base stock cut with Stoddard's Solvent. A too-expensive additive to supplement already too-expensive gas so that it burns almost as well as the readily available and less expensive fuels recommended by the equipment manufacturers. Good idea! Do you get a hat with that?
    SB
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,059
    Iowa must have some super gasoline to mix with ethanol. Since it warmed up to about 32* today I thought I'd see if I could get the Stihl 017 chain saw to run. It's probably been 2 and 1/2 years since I ran it and it had just a trace of fuel in the tank. Found the jug that has fuel for this saw and it still had a little bit that was probably mixed 2 and 1/2 years ago(at least that long). I started pouring it in since it still looked green like when it was originally mixed up and started pulling the cord. I pulled quite a while before I figured I'd try putting it on warm run instead of full choke and it popped right off. It started and stopped numerous times before it ran good enough to go cut something. I do think I will drain and mix up some fresh E10/oil before I work it. Just feeling pretty lucky that Iowa must have better fuel since the rest of you guys would have had white goo in the tank and jug.
    Apr 2010
    Clara City, MN
    18
    I've ran 100LL for years in Honda loading pumps for spraying and only problem I've had is replace a muffler because of corrosion. I have a 5.5 horse that I've used for at least 15 yrs and will still start on 3rd pull.
    AntiCub's Avatar
    Aug 2007
    North Pole
    476
    Not initially, but mixed gas starts to break down after about 12 hours. General rule of thumb for those of use running Rotax power aircraft was to throw out mixed fuel more than a week old. That's part of why oil injection is so nice.
    I always ran Chevron in my 150, never once tested positive for alcohol. And I never had any fuel system problems (unless you count noticably more carb ice issues). I run it in my Rotax now, and lawnmower. The lawnmower sits all winter and fires up first pull each spring.
    Phil
    Jul 2015
    Davis Junction, IL
    1
    I have used 100LL in all my mowers, generator and snow equipment. It will probably burn a little hotter but it is cleaner as well. I did use it in my car (79 Dodge Omni) when I was 16 but after replacing the 3rd head gasket I went back to Regular Leaded gas when it was sold then to unleaded. Good luck to ya!!
    Clearwater,Fl
    2,559
    I always understood that the higher the octane the cooler the burn.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,665
    octane rating measures detonation resistance allowing higher compression. The rest is a myth.
    WhiskeyMike's Avatar
    West Boxford MA
    941
    As I understand it, higher octane burns slower. as it is less volatile hence, it is still burning as it goes by the exhaust valve and runs hotter. In a Cesnna-180 I had, I found auto fuel ran coolest, followed by 80 Octane, and hottest with (so-called). The EGT showed substantial differences. In my old pickups, I found hard starting with 100LL. That said, it runs in most everything without a lot of worry.
    Feb 2011
    154
    Octane is resistance to detonation.
    Reid Vapor Pressure ( RVP ) is how volatility is measured.,
    RVP in MO-gas is adjusted by seasons.
    Mo-gas is not.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,665
    Quote Originally Posted by WhiskeyMike View Post
    As I understand it, higher octane burns slower. as it is less volatile hence, it is still burning as it goes by the exhaust valve and runs hotter..
    http://www.racegas.com/article/10
    nanook's Avatar
    Aug 2002
    northern alaska
    1,694
    Regardless of all this, 100LL killed my Honda 1000. The combustion chamber was not hot enough to scavenge the lead. The lead was all over the piston and exhaust valve, there was no compression.
    Sep 2006
    corvallis,or
    422
    The main people who will object to running 100LL in our small engines are the repair shops. They love to see us coming because they love to charge $100 to clean the varnish out of carbs.
    cubflier's Avatar
    Nov 2003
    1,313
    Quote Originally Posted by Vermont Supercub View Post
    Don't use it in a Yamaha EF1000IS generator. The lead coats the inside of the valve guide on the exhaust valve till the exhaust valve can no longer move. This is what's required to get the valve out on a brand new generator after ten hours of use. I have also used 100LL in my Honda EU2000IS for awhile now but not any more.
    Jerry
    If it looks rough...it is!!
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    I use it in my Yamaha EF1000IS generator all the time and have for the last 10 years, but I mix TCP and MMO in with the gas. Still runs great.
  1. Great website for small continental engines
    By scout88305 in forum Cafe Supercub
    Last Post: 03-12-2007, 08:09 PM
  2. Lead Content in 100LL and Use in New Engines
    By Erik in forum Cafe Supercub
    Last Post: 09-19-2005, 01:09 AM
  3. The Future of 100LL???
    Last Post: 09-11-2004, 07:16 PM
