Results 1 to 8 of 8
Thread: Long Time reader, 1st time poster
    Dec 2010
    Clinton Mo.
    1
Name:	EAA Walrath 004.jpg
ID:	677Click image for larger version.
Name:	EAA Walrath 007.jpg
ID:	679Walrath from clinton mo.
    Experimental ww cub pictures
    Wirsig's partner
    Were both dumber than a box of rocks, you can ask our wivesClick image for larger version.
Name:	EAA Walrath 001.jpg
    fly_cubs's Avatar
    Chapel Hill, NC
    402
    Which motor do you have hanging on the front of that bird?
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,052
    Looks like it should be fun. Must be geared down pretty good as long as the prop looks.
    wirsig's Avatar
    Rocky Mount, VA
    305
    High end 2332 w/ a Valley Engineering 2.2 Redrive swinging a Culver 94-60.
    Aluminum super case, Forged & shaved crank 84mm stroke w/ chevy journals, H beam race rods, 94mm jugs, ported & polished heads, 1.25 ratio rockers, and an eagle K8 cam grind. Also building a megasquirt tuned port fuel injection & crank trigger ignition w/ redundancy on all electrical.
    We should make around 110 hp at climp power setting.
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,405
    Welcome Walrath!
    Wirsig, what RPM's at full power?
    I haven't recently been around a high-end 2332 w/ a Valley 2.2 for, like, ever! Assuming Volks-based??
    DAVE
    wirsig's Avatar
    Rocky Mount, VA
    305
    It is VW based but with all race parts. We're planning on cruising in the 3's and climbout in the 4's. Engine RPM of 4750 and prop speed of 2159 has the tip at 80% Mach so we'll keep it below 5. The pic below shows what a similar engine produced.
    Torch's Avatar
    May 2003
    Fairbanks, Alaska
    2,027
    Be honest, in that pic were you two making airplane noises with your mouth?????
    wirsig's Avatar
    Rocky Mount, VA
    305
    You better believe it! We had our last EAA meeting at Walrath's where we're building the plane. That's one of our members LeRoy Cook in the front & I'm in the back. LeRoy no more walked in the shop then made a B-line to the plane and climbed in. I hadn't been in it on the gear so I couldn't resist!
  1. Clock time or Tach Time?
    By Anne in forum Tips and Tricks
    Last Post: 09-17-2011, 06:40 PM
  2. Long Time No Post...
    By Wendy in forum Cafe Supercub
    Last Post: 03-28-2005, 08:53 AM
