Page 3 of 3 FirstFirst 123
Results 81 to 90 of 90
Thread: Check That Muffler
  1. #81
    4,520
    Thanks mike mcs repair, DavePA11 thanked for this post
    Likes Cubswede liked this post
  2. #82
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,980
    Why I hang out here, though I fly behind a Rotax 912S...... you guys have a lot of fleet knowledge helpful to even a non Cub flier.
    I currently have 2340 hours on my muffler, with zero issues, BUT, this thread will make me check things over more often, and "more better." Original heat muff also.
  3. #83
    Cubswede's Avatar
    Aug 2009
    Sweden
    53
    Yeah the exhaust system is almost allways in the need for a little "fix" here and there at every annual.
  4. #84
    Apr 2017
    ND
    178
    Can the stock muffler be pulled out without swinging the engine?
  5. #85
    Apr 2009
    AK
    221
    No
  6. #86
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,980
    Ha, I forgot about this..... At 2600 hours, I started hearing a rattling sound, turned out my muffler had shed it internals, thus the noise. A simple fix (new muffler, though in retrospect I could have repaired the old one with what I know now, the stainless can was fine, just the baffles needed replacing), and the heat muff was still pristine so I put it back on.
  7. #87
    21,200
    Tailpipe is welded to the muffler. Not hard to swing the engine. Should just take loosening the tach cable and removing the two right side engine mount bolts at the firewall.
  8. #88
    RVBottomly's Avatar
    Sep 2017
    1,230
    Do you still have that Swiss muffler? That seemed pretty neat.
  9. #89
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,980
    After about 1700 hours the internal stainless mesh that holds back the muffler packing loosened up a bit, so instead of a perfect cylinder it was possibly contributing to excessive back pressure, so I took it off the other day. It goes off and on in about 3 or 4 minutes, real simple. Previous static RPM tests showed no discernable difference in power. 6 pounds including mount hardware though, back to the stock in cowl Rotax muffler now, for the time being at least.
  10. #90
    3,036
    Suziki, Yamaha, Honda, BMW, and other motorcycles have offered variable exhaust valve flappers for years....EXUP valves Some's for noise reduction but the main reason is adding or subtracting exhaust back pressure which can fill in engine torque dips at certain rpm's. I always wanted to try a manual valve in a common pipe collector to see if there's anything to be gained in a free flowing system at partial throttle.
  1. muffler still available?
    By little pat in forum Super Cub Sick Bay
    Last Post: 09-19-2010, 08:24 PM
  2. muffler bad?
    By little pat in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 08-03-2010, 10:46 PM
Tags for this Thread
