prop
96chevtruck
Twin Falls , Idaho
I am building a Tubine Cub kit with a Aerosport 0-375. What prop would be good for this setup?
The Pawnee prop 1P235 is a good metal prop, also the Catto composite prop is becoming popular with 0-375 owners.
Whirl Wind Aviation 200G ground adjustable or the 200G/CS constant speed.
I've been very impressed with both.
Thanks for the reply. I have seen the Catto props but I wonder about the non-metal leading edge on how it holds up , have you heard anything on it. I saw the video of Valdez and a Cub with a 0-375 and 3 blade Catto which looked nice. Thanks again , Bill.
Stainless leading edge on the Catto now. I'm sure it helps, but it's no bushwhacker.
I've heard a lot of advantages and only a couple, yet important disadvantages...
I just talked with craig today and they have a nickle leading edge for the prop. much better then the SS.
