Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 98
Thread: How to set up a groundloop
  1. #41
    2,560
    Saw the title of this thread and jumped right to it. Then I realized that it was a pilot thing, not an avionics thing. Sigh
    Likes fobjob liked this post
  2. #42
    Bill Rusk's Avatar
    5,245
    Web - pretty funny
    CuBob, and others. I guess I've been a little distracted lately. But lets try to get this thread back up to speed.
    THE FOLLOWING NOTES ARE GENERALIZATIONS - THERE ARE EXCEPTIONS TO EVERYTHING -
    Traash - You make an excellent point and one I had not covered so lets talk about that a little.
    In life we sometimes get "Negative Transfer". This is when a motor skill that works in one situation is wrong in another situation. A perfect example is kids sleds. The rudder bar on the front of the sled, for your feet (or hands), works exactly the opposite from an aircraft rudder. So kids that do a lot of sledding have to unlearn that hand/eye muscle memory motion when learning to fly. The problem is that in a "panic" situation we often revert to a previously learned skill set. As I recall that falls under the "Law of Primacy" ie you will revert to what was learned first.
    A taildragger is pretty much the opposite of the trike in just about EVERY respect on the ground.
    Throttle - If you get in trouble with directional control on the ground in a tricycle gear airplane the correct action in almost every case is throttle idle and get on the brakes. In a taildragger - when having directional control issues - throttle up gives more tail authority and is the correct response most of the time, but that is the opposite of what you would do in a car, or with a horse, or with most other things in life. We pull back and slow down. But in a tail dragger we need to push up and lean forward.
    Brakes - again...... in a trike - get in trouble - get on the brakes. With the mass in front of the mains this is stabilizing. In a taildragger it will make things worse (unless using just one brake to supplement rudder).
    Elevator - in a trike letting the stick/yoke come forward, lowers the nose and thus AOA and is again stabilizing and generally good. In a taildragger if we let the stick come forward (three point or while high speed taxi - landing rollout etc) it lifts the tail so we loose the tailwheel steering component and we loose the drag pulling back on the tail so it is DESTABILIZING. Again the opposite of what works in a tricycle gear airplane.
    Rudder - in a tricycle gear airplane the center of mass in front of the mains means it will pretty much auto correct and it WANTS to roll straight. In the tail dragger it WANTS to go backwards. So the tricycle gear pilot learns to minimize rudder on roll out to avoid over correcting or PIO (Pilot Induced Oscillation). The taildragger pilot MUST use rudder. Again - almost an exact opposite control input needed.
    Bottom line - a taildragger is pretty much the opposite of a trike on the ground. They are not the same. One of my mantras............is......
    Airplanes are different and each must be flown according to its characteristics in order to maximize utilization, performance, and safety
    You do not use rudder in an F-16 but it is critical in a sailplane, you use the elevator and throttle differently in a tricycle gear airplane Vs a taildragger (on the ground). A high sink rate in a swept wing aircraft can be deadly, much less so in light wing loading, high lift wing like a Cub. The bottom line is that you don't fly a Cub like a Cirrus, or a Pitts like a Waco. Fly each airplane differently according to what it needs.
    Controls while taxiing
    Remember the axiom when getting your private pilots license "Climb into - Dive away"? That is the one that says to "position the controls when on the ground taxiing so that you are climbing into a headwind and diving away from a tailwind". With a headwind we have the stick back, ie climb, and the aileron into the wind thus "Climb into" the wind. With a tailwind we put the stick forward and the aileron away from the wind thus "dive away" from a tailwind. That is only about 1/2 correct for a taildragger. You should ALWAYS have the aileron into the headwind but the elevator depends. We have our forward speed and the propwash over the tail so MOST of the time in a taildragger the elevator should be full aft while taxiing. If you are not sure where to put the elevator (you don't know if the air is flowing over the elevator from the front or from the back (tailwind)) just stick your hand out of the window. Is the wind hitting your hand from the front or from behind? You will find that about 95% of the time it is coming from the front thus - stick back. It takes a LOT of wind (probably over 20knots) before you need to taxi with the stick forward. You could argue that the wind is not the same from where you have your hand out to where the tail is and there would be merit to that argument but it takes a LOT of wind from the rear to make a 180 degree change in that 10' difference in distance. Furthermore I am an advocate of stick ALL THE WAY AFT - WELDED TO THE STOP when taxiing. If you let the controls flop around you beat up the elevator and back end of the airplane when it bounces over every bump. Additionally you loose directional control with the tailwheel when it is not on the ground or when it is so light it slides sideways rather than gripping and turning. Now as I said before there are exceptions to everything - if you are on ROUGH ground you may need to lighten the tail to keep from pounding the tailwheel over the rocks. You may need to lift the tail to turn over an obstacle. Etc. But I see guys all the time taxiing with the elevator bouncing stop to stop, pounding the back end of the airplane all to hell, and I just want to run out there and tell them to hold the stick back because they are tearing up their airplane. Be kind to your airplane, treat it with respect, STICK BACK, STICK BACK, STICK BACK.
    To adress shimmy. FIX IT!!!! The tailwheel should not shimmy. Period!! Yes Tom - your technique is good and will help -until you can get it fixed. But I would maintain that regular use of stop gap measures is not really all that good and the best solution is to fix the tailwheel.
    This area - Control position while taxiing - is probably the area with the most exceptions. Some of these rules must be modified when taxiing downhill, or on a side slope, or based on the particular type of airplane, etc etc. Please don't beat me up too much, just remember...... MOST of the time keep the aileron into the wind and the stick aft.
    GROUND CONTROL EXERCISES
    Someone mentioned it earlier so lets take a few minutes to talk about ground control exercises. Some have called it flying while on the ground. You MUST have complete control at all times when on the ground or in the air (unless doing aerobatics, then it can be kinda fun to momentally be totally out of control).
    Exercise 1
    You should be able to do one wheel "touch and goes" anytime, every single time. Okay - exceptions - (man I get tired of trying to think of every possible exception) but here are a few. Doing a one wheel touch and go on asphalt with NO crosswind might work but it will be exciting and scrape a lot of rubber off. With grass there is usually enough sliding ability that the tire can slide a little sideways and you can do a one wheel T&G even without a crosswind. Wet grass in the early morning helps too. Obviously a crosswind makes it better. So......with a little crosswind you should be able to land on the upwind tire and roll along for as much runway as you feel comfortable, and NEVER touch the tail or downwind tire. A one wheel T&G if you please. Get good at it. Everytime!! MAKE THE AIRPLANE DO YOUR WILL.
    Exercise 2
    If the is no crosswind then land on one wheel, roll a few seconds, switch to the other tire, roll a while, go back to the first tire. Practice, practice practice.
    Exercise 3
    Not really an exercise but in fact something that can be practiced in a light or strong X/W. A proper wheel X/W landing is a three pointer. 1st point - is the upwind wheel, 2nd point - slowly "fly" the tail down, 3rd point - the downwind wheel touches when you run out of aileron authority. Upwind, tail, downwind - IN THAT ORDER. Practice, Practice, and Practice. A three point landing might be tail, upwind wheel, and downwind wheel. The difference is this will all happen in very quick succession Vs the wheel landing above where there might be several seconds between each wheel.
    Exercise 4
    If you have a nice wide grass runway, or can get to one, do a wheel landing on one edge of the runway, while rolling down the runway on the mains, move to the other edge of the runway. Go back and forth. This will actually be uncomfortable the first few times.
    Exercise 5
    Try dragging the tailwheel down the runway without ever touching the mains.
    Exercise 6
    Landings. There are lots of different types of landings. You should be able to wheel land (in a Cub) at about 70MPH. You should be able to wheel land at 50mph. These two landings are quite different. Then there is the tail low 40 mile an hour wheel landing where you touch town in a very tail low attitude (but not on the tailwheel) and then roll it up on the mains.
    Three point landings can be 1) tail first, 2) three point, and 3) tail low but not completely three point until just a moment after touchdown. I think that even if you prefer wheel landings and rarely do three points you should try to maintain proficiency in all types. It will make you a better pilot. It's like tools in a tool box. The more tools you have the more jobs you can do, and the better you can execute those jobs. But that tool needs to be rust free and well oiled when you take it out of the box to use it, even if you do not use it often.
    Exercise 7
    Turning takeoffs and turning landings. Good stuff to practice if you can find a place to do so. Just remember, turning takeoffs to the left are higher risk, due to torque, "P" factor, Slipstream effect, Gyroscopic effects, and opposite rotation.
    Exercise 8
    Highly dangerous and not recommended. Do a wheel landing, add power as necessary, brake to a stop with the tail in the air. Take off without having ever touched the tail. In NO WIND/CALM WIND conditions, after coming to a stop as above, do a 360 piroutte, then take off, again never touching the tail. Learn to land with the brakes locked. On final get behind the power curve so you are below stall speed. At the landing point, chop the power, drop flaps and plop down, brake hard. These are dangerous exercises and I do not recommend you do them.
    Attitude landings
    In higher performance taildraggers you will set a landing attitude and maintain that through the flare/float to touchdown. Normally higher performance airplanes touchdown in a three point attitude well above stall speed so the aircraft is still flying and still has a lot of energy at touchdown. This is commonly seen in aircraft like the Pitts, Thorpe T-18, RV's (a little), and most other high performance types. Here is what I mean. Once you get in the flare in a Cub we hold it off (assuming a three point) until all the airspeed is gone and the airplane effectively stalls into the touchdown. If it stalls a foot or so above the ground its is no big deal, just keep the stick back and it will plop down just fine, though perhaps a little unceremoniously, but it will be safe. If you get a Thorpe T-18 in the flare then hold it off like this it will eventually get pretty nose high, touchdown on the tail first, but when the mains come down you will get into a fore/aft pitching (PIO) motion - porpoise- I like to call a "crowhop" and things will get exciting really fast. You can not just get in the flare and "hold it off" in a high performance taildragger. Before you take off you take a moment to fix the attitude you are in while sitting on the ground firmly in your head. Where does the horizon hit the glareshield/windscreen? What angle is the horizon relative to the wing? What do you see over the nose? How high is your rear off the ground? When you get in the flare you find this attitude and maintain that, using throttle but NOT increasing AOA/attitude, until touchdown. If you float in the flare you must use the throttle to control sink and attitude to keep from dropping in, or dropping it in tail first.
    OK folks. Probably lots of opinion here so take it all with a salt lick
    Hope this helps
    Fire away
    Very Blessed.
  3. #43
    9,840
    Yikes, I've gone 3400 TW hrs without a ground loop because I thought it was easy. Now that Bill needed a thousand words to explain it I'm afraid to go flying Thanks Bill
    Likes Oz. liked this post
  4. #44
    spinner2's Avatar
    Montana
    1,729
    Good stuff Bill and and pertinent exercises. Makes me want to go practice one wheel landings in the morning again.
    I have two takeoffs I remember that were almost ground loops. The first time I landed on the side of an open hill side aimed uphill. It was probably a 15% grade or so. When it was time to leave there was some wind blowing downslope so I had a tailwind. Because of the terrain I took off with a quartering tailwind from the left. Full right rider wasn't enough to keep the tail from swinging to the right and I had to stab in hard right brake to straighten it out. That did it and about that time I had enough airspeed to fly on down the mountain level with the grade.
    The second time was last month flying up the Trench in BC. Showers were blocking my way near Mica Dam and rather than fly back to Golden to wait I landed on a piece of road that didn't get flooded by the reservoir.
    Road is above jury strut.
    I landed with a tailwind and that was no big deal. But later when the path north opened up I had to takeoff with a tail wind.
    I was was up tight against the trees to start the roll and there wasn't any wind. But once past the shadow of the trees the wind turned into a quartering tailwind from the left and once again it took quick brake action to keep things lined up on the narrow road.
    Looking towards the the reservoir from my takeoff location.
    I guess the lesson that was reinforced was takeoffs with a tailwind from the left may exceed rudder control at lower air speeds.
  5. #45
    RaisedByWolves's Avatar
    Feb 2005
    3,822
    Seems like the baby bushwheels are more prone to shimmy on pavement. I have the new HD Bushwheel spring and it will still shimmy from time to time.
    Likes pfm liked this post
  6. #46
    Bill Rusk's Avatar
    5,245
    Tom - Not entirely sure why they do, but I agree.
    Very Blessed.
  7. #47
    Sep 2002
    1,621
    I wasn't flying during the landing I remember best. I was riding front seat as we were doing search and rescue in a J3, refueling on the top of the White River levee in eastern Arkansas. My brother was pilot. All was well till someone parked his pickup in front of us so that we had to slip in, then immediately lock the brakes and slide to a stop before we reached him. All still well, BUT the right hand brake elbow fitting blew out while we were still doing about 25 mph on the 11 foot wide top of the levee with left wheel locked and suddenly no right brake at all. We did an immediate left turn straight down the side of the levee toward the trees at the bottom. I remember thinking, "We're gonna take this sucker home in a basket". But my brother firewalled the throttle, applied down elevator to blow the tail off the ground, and full right rudder using the prop blast to swing the plane around backwards. He then halted the turn with us descending the levee backwards, sat the tail back down, used the propblast to stop us and to taxi back up to the top of the levee. As an aside, when you pop the top of the levee, you gotta be ready to shut down right then so you don't repeat the whole process on the other side of the levee.
    Thanks Brandsman thanked for this post
  8. #48
    Jun 2002
    NC
    402
    Golly, I need to go to Poplar Grove!
    Usually I fly off asphalt because it's more common here and I figure if I can handle asphalt, grass is always easier. Also, I usually three-point unless it's gusty or things don't go as planned.
    If I'm going to have a problem it's most likely due to flaring a bit too high or a bit too low. I've worked on the three-point sight picture but have trouble determining wheel height… so if I'm beginning to fall the last foot I massage the throttle into an extended landing. I hate that. 75' or wider runways are the worst… you've really got to concentrate. I don't have flaps and enter the flare about 45+/-. Directional control is not normally a problem, just the wheel height.
  9. #49
    Sep 2002
    1,621
    I've always had a problem with wheel height on the levee tops. That, and the lack of ground effect, and there always seems to be a gusty crosswind, so you have to contend with the updraft on the windward wing, and the erratic burble on the leeward wing. Directional control is easy though -- it's immediately obvious when a wheel starts getting close to the edge of the levee.
  10. #50
    musket's Avatar
    Mar 2003
    Baja Oklahoma
    270
    A bit of humor (humour?) to lighten up a serious subject: http://www.supercub.org/forum/showth...undloop+musket
  11. #51
    WindOnHisNose's Avatar
    Lino Lakes MN (MY18)
    4,197
    Folks, threads like this make this one incredibly valuable website. Honestly, the type of heavyweights who weigh in with their inputs is incredibly valuable.
    This is one of those threads that I will bookmark for many days to come.
    Randy
    Likes wirsig liked this post
  12. #52
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,820
    Quote Originally Posted by Bill Rusk View Post
    1) longer fork arms increase the effective caster angle.
    2) larger tire diameter raises the tail and increases the effective caster angle.
  13. #53
    Jul 2007
    222
    From what I have read, the majority of ground loops occur because of incorrect technique in a cross wind, Bill's lessons to practice also lead me to believe this. While rereading Mr. Imeson's book " taildragger tactics" he states never land when the cross wind component exceeds 20% of the stall speed. When asked the question of what individuals max cross wind is on this forum I get answers that go well above 75% of the stall speed. What is a proper limit you use? With some of the numbers quoted is it even possible to be done safely on a day to day basis?
  14. #54
    Sep 2002
    1,621
    When current, my maximum direct crosswind limit on grass in a J3 is about 27 kts, gusting 33. You have to accept that the plane will be scrubbing sideways and compensate for it. Throttle and rudder are your friends. It is not safe on a day to day basis, and I will go out of my way to avoid it. I see those limits maybe once or twice a year. I'd rather not see them at all. The maximum direct crosswind that I am comfortable with in a J3 is a little over 20 knots, and taxiing is still an unpleasant chore.
    When not current, my limit is more like 12-15 kts. Depends on how long it has been since I've flown in significant crosswinds.
  15. #55
    spinner2's Avatar
    Montana
    1,729
    I had fun with one wheel landings and high speed taxi work on one wheel this morning Bill. I went to a nice long grass strip and worked both directions on alternating mains. I probably put a couple of miles on one tire this morning.
    It it had been a few years since I practiced these and there was a little rust but it didn't take long to get oiled up. And near the end I had an actual crosswind to work with too.
  16. #56
    Sep 2002
    1,621
    My favorite tailwheel practice is to place the tailwheel on the ground and attempt to hold the mains off while I run the length of the runway. I don't do it as well as when I was young.
  17. #57
    10,506
    More mass in the wheel is the primary culprit.
  18. #58
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,820
    I'd like to know how mass creates the issue. The heavier wheel will likely occilate at a lower frequency/higher amplitude, but I maintain the problem lies strictly with the geometry. I've worked on numerous trucks with this issue in the front end (commonly referred to as "death wobble ") and reducing the weight/size of the rotating mass is not how you solve it. Taking out caster is.
    Thanks pfm thanked for this post
  19. #59
    Sep 2002
    1,621
    When the tailspring is heavily loaded, the bottom of the kingpin still needs to be forward of the top. If it is, no shimmy.
  20. #60
    May 2013
    Alberta Canada
    56
    Thanks for the write up Bill. I don't post very often, but I am on this site every evening learning a tremendous amount from all of you more experienced SuperCubbers.
  21. #61
    spinner2's Avatar
    Montana
    1,729
    i would agree with MTV on this Perry. My 3200 tail wheel will shimmy on almost every landing on pavement with my tail ski attached. Without it, it doesn't.
  22. #62
    spinner2's Avatar
    Montana
    1,729
    Quote Originally Posted by CuBob View Post
    For me no more than the minimum required for full windsock deflection or about 15 knots. If it is more than that I'll land crossways or at an angle. I did that at a towered airport last month. The wind was blowing from 24 at 18 with gusts in the 20's. The active runway for light planes was 19. I setup for the left side of 19 and set it down at an angle and stopped before getting to the opposite side of the runway. Everyone was happy.
    I have found that when I'm really in tune with landings and crosswinds, that I don't even think about what I need to do, it just falls into place and I've questioned if it really is blowing as much as the windsock says. But it is.
  23. #63
    10,506
    Mass doesn't create the issue, but it exacerbates it. I'm not a physicist by any means, and I'm not sure I understand all that's going on here. You're correct in that the caster angle is the primary culprit. But, my point is, you can take a tailwheel with proper caster angle, add mass to the assembly, and it will often shimmy. Sometimes it will always shimmy. My experience with this is with big tailwheel tires and with tail skis. Maybe it's not the mass, perhaps it's that the mass is extended further from the axle, but I can tell you from experience that if you add mass to your tailwheel, shimmy will often follow.
    Thanks TJAK, pfm thanked for this post
  24. #64
    Meanwhile,...
    5,051
    If all ya'll REALLY want to do one, it can be arranged. Well, for a small fee of course.
  25. #65
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,820
    Yeah, I have to agree Mike. The more I thought about it the more I realized the two issues are related. The smaller/lighter tire lets you get away with poorer geometry before it wobbles.
  26. #66
    3,366
    Adding mass without changing the geometry or anything else will decrease the natural (resonant) frequency of the mass/spring system.
  27. #67
    Oct 2015
    267
    Now if I ground loop I'm going to have to blame Bill because now I have to think about it.
  28. #68
    CubDriver218's Avatar
    Sep 2007
    Minnesota
    626
    There is simply no substitute for one wheel practice on the ground. I tell students that, while you will use this technique in a crosswind, perhaps the more important lesson to be derived from it is that you CAN control the airplane, even at very slow speeds.
    The one wheel drill forces them to CONTROL the airplane at very slow speeds, and improves landing approaches immensely, not to mention hopefully preventing ground loops as well.
    After reading this thread today I went out and practiced one wheel landings (everything seems so much easier in the grass!). I'd felt really comfortable with these a few years ago when I was flying almost every day on grass strips. Tonight was on a paved runway and I didn't feel awesome about my one wheeled landings, however I did a few runs down the runway on one wheel and did just find keeping her straight.
    My question is - Can't this cause quite a side load on your landing gear? I almost felt bad like I was beating on my poor plane. Touching down on one wheel if you're not going perfectly straight isn't that pretty hard on the gear? Even when going down the runway on one leg I felt like I was producing side load?
    Is this the case or am I just not used to the feeling?
    Fast or slow, always low, freedom of flight soothes the soul.
  29. #69
    10,506
    Richard,
    Yes, you're putting a little side load on your gear. That said, if you'd witnessed a few of my landings, you wouldn't worry at all about the robustness of your landing gear..... The main thing is to minimize the AMOUNT of side load you put on the gear at touchdown. Once you have the weight on that one wheel, the loads aren't ugly at all.
    As someone noted earlier, one wheel touchdowns are easier with a little bit of crosswind, but if done well, they're really no big loads at all. And, as I noted above, a major portion of the value of this exercise is for you to convince yourself that you can finesse the airplane. Landing on one wheel in a calm wind does require some finesse.
    And, by the way, folks, while this thread is all about wheel plane flying, seaplane pilots can benefit equally from one float landings and takeoffs. In light chop, touch down on one float, pick the plane up, then touch with the other float, repeat. Again, a confidence and finesse builder. You CAN control the beast.
    Likes LMartin, DENNY liked this post
  30. #70
    Lisa Martin LMartin's Avatar
    Jan 2012
    Coeur d'Alene, ID
    53
    This makes me laugh, "...it is not going forward and aft all over the place on landing" because I picture all those times I brace each elbow to corresponding hip bone and encircle the stick with my hands, thumbs to fingers, ready to stop the over-motion. I never considered the elevator component before. Mattias, the German, was talking about the rudder but could have told me something about the stick too.
  31. #71
    Jul 2016
    Anchorage, AK
    106
    I'd like to add variables to groundloop situation; Lately I've been landing the flats with muddy and/or wet grass on mud which now has turned to frozen mud. Add a crosswind and the aircraft can be difficult to control at the end of the rollout with slow speed and ineffective rudder. On a hard surface one can use brake to assist however on the mud the tire locks up with minimal braking.
    Separate situation is landing muddy or icy locations where brake cant be applied because it furthers the landing distance and further reduces control on ground with one tire getting ahead of the other. I've heard of pilots locking both wheels when landing similar conditions but these situations are of interest to me on how to further my skills.
    thoughts?
  32. #72
    Jan 2012
    Coeur d'Alene, ID
    53
    In a short ldg competition on skis and snow I found the best I could do was land as slow as possible, dragging the tailwheel immediately and as heavily as I could, drop flaps to zero. Brakes only increased the ground roll. Maybe mud works the same.
  33. #73
    kase's Avatar
    1,562
    Thanks TCE thanked for this post
  34. #74
    1,704
    Need to show that one to the NO TAILWHEEL CONTROL CABLE GUYS!! See how the tailwheel is backward on landing, it can cause a lot of problems!!!! Might have been better if he did a wheel landing but looks like it was kind of gusty wind. Tailwheel control is always important. Hoping you will do a good wheel landing is a very poor plan!!!
    I use a tail ski for several reasons. If I need to slow on skis I do a several hard tail wags. Getting the ski sideways is hard on the fuselage but it will stop the plane.
    Likes LMartin, SteveE, TCE liked this post
  35. #75
    Jan 2012
    Coeur d'Alene, ID
    53
    So would you have to drag the tailwheel on with power to get it straight before touchdown? If he'd landed on the wheels, the tailwheel would have still been crooked when it came down, wouldn't it?
  36. #76
    Sep 2002
    Southern NH
    485
    Most airplanes I have flown with a free castering tailwheel have a tailwheel lock system...
  37. #77
    10,506
    The problem there was that when he touched down he was “neither fish nor fowl”. He was neither in a wheel landing nor a three point attitude. That put the tailwheel in LIGHT contact with the pavement, with little weight to cause it to stick and trail, but the tail not high enough to keep the tailwheel off till slowed.
    I see this frequently in folks new to tailwheels also.
    I tell these folks to either perform a full stal landing, get the tailwheel down and weight on it, OR touch tail low, then get the tail up and steer with the rudder till slow enough to put the tail down gently.
    He or or she did neither......hence neither fish nor fowl. Watch the elevator after the first touch: Elevator was in trail till the plane had already ground looped.
  38. #78
    don
    706
    Heck You haven't lived without a few groundloops under your belt.
  39. #79
    S2D's Avatar
    Montana
    4,063
    Quote Originally Posted by LMartin View Post
    If you watch the landing again, you will see that the tailwheel was in tow during the landing, it only spun when he landed it improperly
    Like Mike said, with that type of tailwheel, one needs to make a wheel landing and gently lower the tail as the airplane slows down (When on pavement.)
    Likes LMartin liked this post
  40. #80
    10,506
    Heres one for you. What’s wrong with this picture?
  1. Dynamics of a Groundloop
    By kiwicubber in forum The Art and Science of Flying
    Last Post: 09-11-2009, 10:34 PM
  2. How To Groundloop Your Taildragger
    By musket in forum The Art and Science of Flying
    Last Post: 08-15-2005, 12:29 PM
Tags for this Thread
