Page 1 of 2 12 LastLast
Results 1 to 40 of 43
Thread: Tail brace wires
    Jan 2010
    stillwater ok
    438
    Tail brace wires
    I looked all over and the search function kept bring up everything but what i needed.
    In an attempt to clean up the plane. What is the verdict on streamlined tail brace wire?
    Does it make any bit of a speed difference?
    Anything against using stainless mine are painted and im seeing discoloration from corrosion. just seems like a pain to keep painting them?
    9,898
    I've got them on my J4, they are more maintence then the round ones, you need to keep checking them for nicks and I have to paint them every year, do they let you go faster, I would say yes, can you measure the difference ? not sure.
    18,974
    We put 31" Bushwheels on our airplanes, I don't think a set of streamlined wires vs. round wires are going to make much difference. You also have to inspect for nicks per the AD as well. One less AD time to worry about is enough for me.
    Jan 2010
    stillwater ok
    438
    sold round wires it is, I was unaware of an ad for nicks. Any problems going stainless?
    18,974
    Stainless is good, no rust.
    10,580
    Quote Originally Posted by swoeric
    ... I was unaware of an ad for nicks. ...
    nd
    3,345
    Does anyone sell just the clevises or pieces that the bolts go through for the brace wires?
    18,974
    Univair does. I got one today for less than $20. Order the part number in the catalog for stainless. If you order the one in the PA18 parts manual you will get old stock painted steel for $17.
    Bill Rusk's Avatar
    5,258
    I don't disagree with Steve but just for your info, here is a short, 6 min video of the difference in drag between a round wire and streamlined wire. It is absolutely fascinating. Aerodynamics is just so cool....
    http://www.youtube.com/watch?v=ftq8jTQ8ANE
    Very Blessed.
    nd
    3,345
    Steve, ive seen 2 kinds. One where the clevis with the bolt hole is on the brace wire itself,one piece, its just been angled. This is what i have and am looking for in stainless. And others ive seen on a lot of cubs are a straight clevis on the wire itself and another small bracket thats flat thats been angled abit to fit is used. I dont have a current Univair catalog, but in this older catalog they show the kind im using. Thats what your saying they have in stainless? They dont list the parts seperate in this older issue. doug
    18,974
    I have the drawings for two types of tail brace wires. The more common ones are depicted in the PA18 parts manual and the Univair catalog and are available in stainless. The earlier style I have only seen a few times and have not seen any replacement parts. They are made like a Champ with forked rod ends held on a steel bracket with a clevis pin and cotter pin.
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,103
    Hi Steve, do you have a Univair part #? I have searched their website many times for many items and always come up empty. Thanks, Joe.
    "Always looking up"
    nd
    3,345
    top 2 40521-08, 2 on top of stab 40521-07, 2 under stab 40521-09, and bottom 2 40531-00. these are the old numbers in the parts catalog for reference. and stainless ones in same order 61341-003, 61341-002, 61341-004, 61340-000. check me on this though.
    18,974
    The new stainless steel fittings from Univair are as follows:
    Top Wire, Upper Clevis (replaces 40521-008 ) U61341-003 $23.08
    Top wire, Lower Clevis (replaces 40521-007) U61341-002 $31.51
    Bottom Wire, Upper Clevis (replaces 40521-009) U61341-004 $33.23
    Bottom Wire, Lower Clevis (replaces 40521-010) U61341-000 $30.51
    Square Washer U81102-002 $4.21
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,103
    Perfect, thank you boys, Joe
    "Always looking up"
    Jul 2009
    racine,wi
    684
    they have kit that inclues every thing
    Laz's Avatar
    Girdwood, AK.
    115
    I bought a complete set of stainless wires and brackets from DE in Florida. The price was very reasonable, although I can't remember what I was
    Laz
    18,974
    Quote Originally Posted by Laz View Post
    Laz
    Certified or Experimental?
    Laz's Avatar
    Girdwood, AK.
    115
    I'm experimental, but check their website.
    I don't have an address or phone # with me right now(traveling). But I think they are still D&E?
    Laz's Avatar
    Girdwood, AK.
    115
    Steve
    Found them at AC spruce.
    Experimental only!
    Sorry, since I left the certified word, I never looked back
    Laz
    Apr 2007
    Kingsburg, CA
    1,256
    Aren't the stainless steel wire clevis required to comply with the AD for changing to round tail brace wires? Univair told me that they changed to Stainless Steel when that AD came out. I see Dakota Cub sells these wire clevis much cheaper so I'm assuming that they are steel. Which clevis is needed, the steel or stainless steel? Which is preferred???
    18,974
    Dakota'a are stainless. Stainless or steel are both acceptable but the steel, even when primed and painted eventually rust. Stainless doesn't and I have not seen any issues with them unless the special washer is not installed under the bolt and nut.
    Apr 2007
    Kingsburg, CA
    1,256
    Got it. Thanks for the quick reply Steve.
    Kevin
    6,868
    By special washer you mean the ferrule or bushing that allows rotation of the clevis? I have seen these missing on quite a few Cubs, including one I bought recently. The previous mechanic, realizing that the bolt was kind of sloppy in the clevis, simply drilled the stabilizer for the next size bolt. Yow!
    18,974
    No, the square radius washer U81102-002 at the vertical fin.
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    332
    The stainless steel clevis is excellent but the nipple and nut, shown to the right side of the photo above, are brass (I think). I had mine nickle platted by dodgy brothers, to give it the stainless look. Mine are looking ordinary only after a few years. What does everyone else do with theirs?
    If you haven't pulled your wires apart ever I'd recommend it. A few of mine at the time, were well worn.
    Jun 2015
    144
    Regarding post #1 asking about streamline tail wires vs round, I went to our local hobby store and found small aluminum streamline tubing in 3ft. Sections and slid them over the original round wires. I placed a small section of heat shrink at the top ends to hold it in place. The bottoms were left open in case any water gets in. So far (180) hrs, they have stayed in place, and I know in my mind they have to help the speed just a little. They have been a good conversation item any time someone looks at them. Sorry I don't have a picture of them, but I think they are a common item at a good hobby store. Larry v.
    May 2011
    Eagle River
    269
    Cool idea. My curiosity be piqued, do the wires & tail shake less with the streamlines installed? Probably need a GoPro pointed backwards or a chase plane to see tho.
    Jun 2015
    144
    I don't notice any tail shake back there. You can google K & S streamline aluminum tubing and see what it looks like, prices etc. Larry v.
    Sep 2002
    240
    Steve
    How many square washers are required in a tail assembly are they only for the vertical fin?
    Thks
    18,974
    Quote Originally Posted by C-YQK View Post
    Steve
    Thks
    Yes, only the two on the vertical fin because of the steeper angles. I have seen these cracked at the radius a few times when the waashers were not installed.
    Sep 2002
    240
    Thanks Steve u da man!!!
    Binty's Avatar
    Jan 2005
    South Island, New Zealand
    372
    Quote Originally Posted by texmex View Post
    Id 2nd this advice... As I recorded in an earlier post (search "Nipples and Safety") ours were in bad shape too. There are not many 'Jesus Nuts' on the Cub but I reckon these are one such example. To check these properly, they require dis-assembly. I have a feeling the dis-assembly part is often overlooked on inspections- It certainly was on ours.
    If you force it, it will fit
    Binty's Avatar
    Jan 2005
    372
    Quote Originally Posted by Bill Rusk View Post
    Fascinating film! I never thought it would make a magnitude 9 difference?!! I think iv just discovered why my Climb performance has been KILLED after installing 29" ABWs
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,395
    Quote Originally Posted by SD cubman View Post
    About 18 years ago I found some PVC airfoil shaped snap together fairings that were being pushed to the hang glider and ultralight boys for drag reduction. As it was designed for 3/32 cable, and that's what my Rans S-7 at the time used for tail bracing, it seemed like a natural to try it. After carefully fitting it, doing a real good job and liking how it could swivel a bit to find its best AOA, I test flew it. As I got above 50 mph, severe flutter started in, I could feel it in the stick. I looked back there and the cables were a blur. They came off for good a minute later, too bad as for sure reducing drag anytime I can is a good thing. Round stainless is what they use now back there, maybe I'll try the hobby shop route and give it another shot.
    10,580
    ..As I got above 50 mph, severe flutter started in, I could feel it in the stick. I looked back there and the cables were a blur. They came off for good a minute later,..
    too neutral of a AOA position?, hunting????
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,395
    Yes, something like that I guess. It just freaked me out so off they came. SD Cubman has me getting fired up about the idea again though! Just because there is no airspeed noticeable difference doesn't mean it isn't worth it. I like the "stick it out the car window or bed of the pickup while going 80 mph" concept of drag or lack of affirmation. I first did that 30+ years ago (40 mph) with a round piece of tube that we used for the kingpost on hang gliders and it damn near ripped my arm out of the socket. After slipping a soft foam airfoil fairing over it someone was making back then, the difference was dramatic. More recenty I did the same thing when I converted the RANS to Cub style gear, trying to decide whether to fair and cover it (note, not just cover, but also fair the TE) and again, the difference was dramatic.
    I am a few days away from taking the 29" Airstreaks off and putting the 8:00's on (the biggest that work with my Datum retract skis) and usually I make a flight just to see if there is any difference in speed with the small tires. None at all, yeah right, I wish!
    9,555
    courierguy, What mike says above coupled with the tension of the cables could have been the trouble. Try again with the cables tightened a bit more and use some RTV at the upper end to increase the resistance of the fairings to flutter.
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,395
    Yeah, I was just thinking the same thing.....I will pursue it again. This time with the K & S stuff. Thanks Larry.
    Just did a search for K & S, I guess I don't understand how they size it. They don't specify what the I.D. is, they do call out various sizes but it's not clear if that's the overall size, I.D., or whatever. It's cheap enough, that's good. I'll run down to an local hoby shop and get educated.
    BTW, I got a bit over 2 hrs. dead stick ridge soaring this year, several 10 or 15 minute flights, one an hour, so I appreciate any drag reduction probably more then most.
    9,898
    I still have original streamlined wires on my J4 tail, just like the flying wires on a biplane they need to be a few degrees off center to keep them loaded so they don't flutter
  1. Tail brace wires
    By Ron B. in forum Tips and Tricks
    Last Post: 06-21-2009, 08:53 PM
  2. Tail brace wires
    By high country air in forum Tips and Tricks
    Last Post: 05-28-2009, 12:51 PM
