Results 1 to 8 of 8
Thread: Fuel tank leak right tank
    Jul 2009
    racine,wi
    684
    Noticed fuel leak just behind filler neck. it's a stock 1976
    pa 18 with 6000hrs and have had no problems with tanks
    can't see the crack,it's under some kind of sealant the
    factory must have put on.
    must I take the tank out or is there some kind of epoxey
    or sealant I can try?
    If I have to take it out who do I send it to in the midwest?
    How's easyest way to take it out?
    mike mcs repair's Avatar
    11,773
    Call atlees. They make a replacement neck that rivets on and then has sealer
    Jul 2009
    racine,wi
    684
    Do you think the neck is welded or spot spot welded and sealent
    to the tank
    11,773
    Quote Originally Posted by RAC cubs
    to the tank
    most original aluminum necks are welded inside tank before halves of tank were welded together.. and that weld cracks, common problem(also now the water will run down neck and into tank there)... then someone put goop to try to seal it up on yours i assume...
    that's why atlees custom made this stainless repair piece/kit....
    11,773
    Filler Neck Repair Kit
    P/N 3140-60R - $87.50
    http://www.fadodge.com/Piper%20fuel%20system.html
    20,643
    I thought the original was a steel neck that is soldered into the aluminum tank. People tend to let the fuel nozzle pry against the filler neck and they start leaking. I would clean it and inspect real good and you might be able to simply apply some PRC fuel tank sealant around the neck.
    11,070
    Quote Originally Posted by Steve Pierce
    Solder? into Aluminum? More likely a threaded aluminum boss welded to the tank with a steel filler neck screwed into it.
    11,773
    I thought the original was a steel neck that is soldered into the aluminum tank. .........
    could be.... i just remember the cause as it failing inside, then water also running in there...
  1. Contact, Air Force Jet and Army Tank, the tank won
    By AlaskaAV in forum Alaska Av Memories
    Last Post: 07-26-2004, 06:17 PM
  2. Header Tank leak
    By Staggerwingse17b in forum Super Cub Sick Bay
    Last Post: 02-29-2004, 07:59 AM
