Indabush said:Kind of curious, what do you tighten on a cub with a torque wrench besides assembling the engine or the spark plugs and prop bolts?
mikeo said:I have a 3/8" Snap-on electric torque wrench you can set it to foot lbs inch lbs newton meters ect. Had it for 7 or eight years they ( snap on) calibrate it every year for free you get what you pay for.
Or you can buy a torque tester, I got mine used from a friend for aboutcubdriver2 said:Go get your buddies certified Snap on wrench and put a 8 point socket on yours that will fit his square drive and set both wrenches at the same value and see if they click at the same time, thats what I do when my Snap on guy stops and I grab one of his new ones to check mine about once a year.
Fortysix12 said:I find the 1/4 in drive Inch pound wrench is the most usefull around an airplane. I think mine is made by Pronto? A good one is expensive over a 100 I would bet but there's always Harbor Frieght. Snap on tend to be convenient if they come to your house but it will run 25 percent more or higher nothing beats there ratchet screw driver.
behindpropellers said:...
Harbor Freight and a precision tool? Not in my tool box.
Harbor Freight torque wrenches are for people working on go carts, not airplanes.
