BENEFACTOR
I have a vibration in my Pacer that I can't identify. Seems to be smoother at a higher rpm but it also seems to come and go in the same flight. My trip to New Holstein it was very evident. I found out when I got home I had a cracked cylinder. Pulled all 4 and replaced with some 700 hr. Millineums I had after going through them. I swapped the prop with Cathy's Tri-Pacer which is the smae prop and pitch, stayed the same. I duct tapped everything that felt it could possibly be loose on the airframe and no change. I feel it in my feet more than anything. I have been over the engine mount, baffles, etc. with no luck. My next step is to pull her firewall forward off and install on mine and see what happens.
