Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 601 to 640 of 720
Thread: tools, jigs, fixtures, and other neat stuff
  1. #601
    3,568
    Hunting season. Something(s) will appear!
    Thanks STaylor2 thanked for this post
  2. #602
    jimboflying's Avatar
    May 2005
    526
    I have found this Mag drill to be very handy Click image for larger version.
  3. #603
    11,010
    this one is about car work, but could easily apply to making airplane metal work, simply, he explains things well... only watched a couple of his channels videos so far, but hope the rest are this informative...
  4. #604
    5,129
    Anyone tried super glue-baking soda repairs for composites?
    https://m.youtube.com/watch?v=KU2qph...ature=youtu.be
  5. #605
    RVBottomly's Avatar
    Sep 2017
    787
    I haven't used superglue, but I did mix some baking soda with epoxy to make it fire-resistant. Initial tests looked promising.
  6. #606
    marcusofcotton's Avatar
    May 2009
    Cotton, MN
    350
    Years ago used for minor prop nicks (following manufacturer recommendations), worked well and lasted. A little permanent marker to improve color matching.
  7. #607
    5,129
    How was it to sand flush?
    Interesting technique!
  8. #608
    11,010
  9. #609
    May 2009
    Cotton, MN
    350
    Iirc ( it's been awhile) I think I used a file on it. I don't recall there being any significant difficulty to it.
    Thanks gdafoe thanked for this post
  10. #610
    5,129
    I need to learn how to fix chips in my CF prop. Whirl Wind told me to fill the chips with gelled superglue and touch up the paint. No mention of sanding but I can't imagine how to get a good result without. Warp Speed says to use 5 minute JB Weld. Interesting stuff.
  11. #611
    19,512
    Found this windshield wiper arm puller at a tool vendor at Sun & Fun. Works great with a longer round head scew installed for pulling those stuck fuel valve handles.
  12. #612
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,578
    A tool, sort of, the BalanceMaster I have 13 hours on now is a no brainier re: prop Nick's/ balancing are concerned. Well worth the 10 Oz's weight, Rotax app.
  13. #613
    May 2005
    526
    I have tried some Cherry Q self plugging 1/8 inch rivets but am having problems with the stem pulling all of the way through leaving an open hole. What am I doing wrong?
  14. #614
    19,512
    Quote Originally Posted by jimboflying View Post
    Not sure what you are doing but I got these from Wicks years ago as self sealing for oiling tubes. Do t know the part number but can send you some.
  15. #615
    11,010
    Hole in rivet gun is too big
  16. #616
    May 2005
    526
    I bought the actual cherry tool and it helped reduce the problem. Go figure.
  17. #617
    May 2005
    526
    I am building some flaps which required longer cuts than my shear would make. I took the sheet metal and sandwiched it between two layers of my MDF bench top and screwed them together pinching the sheet tightly. I then scored the sheet multiple times with the tool previously suggested by someone here using the mdf edge as a guide. It took about 10-12 passes to separate the piece but it worked like a champ.Click image for larger version.
ID:	43428Click image for larger version.
    You can also use that clamping technique to create bend lines as needed.
    I also made some supports to help with the finishing.Click image for larger version.
    Thanks RVBottomly, stknrddr thanked for this post
    Likes Skywalker, Steve Pierce, Bill Rusk liked this post
  18. #618
    May 2005
    526
    I have had trouble welding small tubesClick image for larger version.
ID:	43689 to something without causing Click image for larger version.
ID:	43688 distortion. I needed to make some flap pulley attach points that I could pass a bolt through. So I placed an aluminum rod through the small tube and clamped the base to a larger aluminum rod to act as chill blocks. The process worked well without distortion and after tig welding the rod just slipped out.
    Thanks RVBottomly, marcusofcotton thanked for this post
  19. #619
    May 2005
    526
    I wanted to test the Airspeed indicator line for leaks. I attached a thin latex pouch to the pitot tube and pressurized it with a syringe and silicone tube. If the latex bag went limp it indicted a leak. It can also be used the other direction to test the ASI.
ID:	44804Click image for larger version.
  20. #620
    Jan 2017
    Utah/Alaska
    143
    I quit using the Imperial valves and now I build these for the taylorcraft:
    Its a 50,000 cycle valve with Teflon seals, no more seeps and sticking valves. I have the option of FPTxFPT and MPTxFPT, they have a 5/16" ID for a 1/4" valve. Can be used under the owner produced parts and built under a commercial spec that is allowed to be used in antique aircraft.
  21. #621
    May 2005
    526
    The wife said I had to process the apple harvest before I could go fly so I automated it a little.
    Likes mike mcs repair, 62E liked this post
  22. #622
    moneyburner's Avatar
    Mar 2003
    Western Washington
    974
    I've had one of those for decades; it's original purpose is to pull battery terminals.
    Quidquid Latine dictum sit, altum videtur
  23. #623
    Jonnyo's Avatar
    May 2014
    Fairbanks, Ak
    141
    well, It's a work in progress.... but I like it....
    I was gonna make some new steel rolling dies like shown in post #67 in the kydex thread
    EDIT: replaced link with better one
    http://www.supercub.org/forum/showth...l=1#post503509
    well, it seems I cleaned the 2 1/2" bar stock to some hidden corner of my shop
    so plan 'B'.... got looking at those washers from post 67 in other thread... and it hit me...
    instead of making MANY single use die sets, why not make a bunch of thin pieces from washers and PVC pipe... and then stack them on roller however to make unlimited patterns.....
    (think old erector set...)
    so This is mostly a tool so I put it in this thread...
    you can probably make one with a drill press and a file if you dont have a lathe...
    Wow ! Another great post from years ago by MCS Repair. Wish I had time to read all of them. I made up some homemade dies to go into my 24" Roper Whitney bead roller and had a great time kicking out some interior panels. Thanks for the inspiration Mike !
    Jonny o
    Likes mike mcs repair, moneyburner liked this post
  24. #624
    11,010
    Quote Originally Posted by Jonnyo View Post
    Jonny o
    I miss playing with Kydex!!
    last 2 projects, came with prefabbed interiors(carbon fiber then aluminum).....
    someone get me to play with making them a Kydex interior!!! love playing with it!!
  25. #625
    May 2005
    526
    I have found this variable finger tip control to be very helpful for out of position welding on my fuselage.
    Likes dgapilot, 180Marty liked this post
  26. #626
    11,010
  27. #627
    Vermont
    310
    I wondered what happened to the Backyard Flyer. It had a wing structure that required aluminum welding, so not really a homebuilt design, but it performed well with a generator vtwin. Gene Smith (grandpa) came up with an incredibly simple way to arrange the base of the control stick, I had to stare for a minute just to see how so few parts could result in a two axis stick. We lost a real original thinker.
    What's a go-around?
    Likes mike mcs repair, Jonnyo liked this post
  28. #628
    19,512
    I sent that video to my Dad. We use to watch Gene to touch and goes at the ultralight strip at Oshkosh for hours. He was always having a lot of fun. Some of our favorite memories of Oshkosh.
  29. #629
    Vermont
    310
    A recent thread revealed some old jeepers on the forum, so here goes. There's been an old jeep with my homebrew 3pt hitch sitting between the hangar and strip here for about 20 years. I left it there to remind me when I get too clever sometimes. The mower deck was meant to turn backwards for a Kubota, so I just mowed in reverse, as old jeep ptos go in reverse with the transmission. I had the strip about half done during a dry summer when the cloud of chaff I was backing thru plugged the radiator and the engine expired with a cracked head. I used the starter to get it off the runway and there it has sat. Removing a jeep head with the studs packed with rust dust is not fun. This week I dragged it in and hooked up the head to a $150 Harbor Freight winch, clamped to a pipe spanning 3 rafters. Picked the front of the jeep off the floor and started whomping with a maul. Quick and straightforward method. Picture shows my new deck, it turns the right way.
ID:	45638   Click image for larger version.
    What's a go-around?
  30. #630
    11,010
    Best $217 I spent on a tool from amazon
    comparison review video of them.....
  31. #631
    11,010
    Few more pictures starting to use it. And had to let girlfriend try it with her beads. Think Iíll need a second one.
    Andonstar 5 inch Screen 1080P... https://www.amazon.com/dp/B076XYRCYM...p_mob_ap_share
ID:	45840Click image for larger version.
ID:	45841Click image for larger version.
ID:	45842Click image for larger version.
ID:	45843Click image for larger version.
ID:	45844Click image for larger version.
  32. #632
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    15,033
    About 20 years ago, my dad took an old handheld video camera and an old commodore monitor I gave him and made a device like that so my mom could continue readings with her macular degeneration. It had a wood and metal pipe stand you could move up and down. It was great for getting a close look at things and cost almost nothing, but it did take up a lot more space!
    Likes Steve Pierce, mike mcs repair liked this post
  33. #633
    Mar 2016
    1,430
    The scanner or the girlfriend?
  34. #634
    Nov 2019
    27
    Anybody have any insight on frame jig table that I can turn into a wing fan table?
  35. #635
    Mar 2016
    1,430
    What is a wing fan?
  36. #636
    nd
    3,529
    im guessing he meant fab. adam a close to level floor and 2 purpose duty saw horses work just fine. built mine on sawhorses and a table never even entered my mind. just wanted to add i just screwed a piece of plywood to the back of one of them for the washout, after things were to the set together point.
  37. #637
    Mar 2016
    1,430
    Logical, I have used the term wing build table so I did not catch the needed correction.
    Table I have used for many years, two sheets of ĺ MDF over good 16' 1x6 framework with a skin of thin ply on the bottom. The framework was three 1 by's.
    One edge of the table had some overhang, the other was flush to allow simple attachment of jigs.
    The table was hinged on it's legs so you can tip it up to be vertical when needed.
    I will be building a new one soon and might go with 1x8s.
    Image quality is not great here since these are Polaroid shots from decades ago.
ID:	45968 Click image for larger version.
ID:	45969 Click image for larger version.
    Likes moneyburner liked this post
  38. #638
    Nov 2019
    27
    Sorry fab table is correct. Autocorrect got me. I was thinking about the saw horse plan so I’m glad I’m not crazy on that one.
  39. #639
    Cub junkie's Avatar
    My Moms basement
    2,104
    Here is my version of a long flat table. I build 'em with a pair of those built up floor beams and use particle board top which I can change out easily and cheap. At least two reasons I do it this way, 1. There is no such thing as flat plywood 2.There is no such thing as straight dimensional lumber. All opinion of course.
ID:	45981   Click image for larger version.
    Likes Skywalker, mike mcs repair liked this post
  40. #640
    Nov 2019
    27
    Cub junkie,
    i agree with your statement of there isn’t any wood that is flat or true. My other plan was to build a 36” wide x 20’ steel table on casters and be able to square and shim everything to be as level as the shop floor. When it go to wing building I could cut ply wood to lay on top.
  1. Neat Super Cub Stuff on eBay Today
    By Steve Pierce in forum Cafe Supercub
    Last Post: 04-17-2005, 10:25 AM
  2. fuselage jigs
    By Arturo in forum Tips and Tricks
    Last Post: 08-04-2003, 10:47 AM
Tags for this Thread
