Page 20 of 20 FirstFirst ... 10181920
Results 761 to 776 of 776
Thread: tools, jigs, fixtures, and other neat stuff
  1. #761
    jimboflying's Avatar
    May 2005
    585
    The center section is longer than the side plates to enable clamping the workpiece in the vise and to hold the whole device in the vise.
    Likes moneyburner, gahi, SuperClub liked this post
  2. #762
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,081
    I’ve been changing the cylinders on a O-320 ,parallel valves. Wondering what other guys use to compress the springs and installing the rocker arm s and shaft. Mine is a bit clumsy, but works , just like something nicer.
  3. #763
    Apr 2009
    AK
    190
    Just bleed the lifters down (you’re checking dry lash anyway after changing cylinders, right?), and you don’t need to compress the valve springs to install rockers... that being said, I’d be interested in people’s valve spring compressors, have seen various versions and made one or two...
    Likes gahi liked this post
  4. #764
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,081
    More than one way to skin most cats,lol. One other way is check the dry lash , then remove the push rod( cover not installed yet) , oil the lifter assembly, install the push rod cover then push rod and then install the rocker arms and shaft. The valve spring need to be depressed slightly to smoothly install the oiled shaft. Kinda repeats some steps but when you crank the engine for the first time things are oiled and ready to rock(pun). I enjoy making little tools for jobs like this, Mike at MCS has to have a few. This isn’t meant as a jab, again different methods.
  5. #765
    Apr 2009
    AK
    190
    Just spin the prop by hand for a few seconds and build oil pressure after installing the rockers- you’ll be able to feel/see when the lash is taken up- sounds like your method works too; lots more than one right way to do most things...
  6. #766
    3,492
    Not home-made tooling, but old school & vintage :
    Cam Tool Inc bead breaker for removing tires.
    Easy to improvise something similar based on how this works.
    Likes RVBottomly, algonquin liked this post
  7. #767
    Jan 2017
    Utah/Alaska
    263
    I just love this little digital level, it works great for checking travel on ailerons, flaps and elevators, $29 on amazon and fits in my tool box easy. Tim
    Likes algonquin, richts liked this post
  8. #768
    JimParker256's Avatar
    Aug 2015
    Farmersville, TX
    457
    I purchased a similar digital level, but in a more "elongated" (6") form that would allow me to attach it to the prop with a couple of elastic bands so I can set the pitch on my ground-adjustable prop, without needing a third hand, or performing unnatural acts. Added bonus that it comes with a pair of "bubble levels" built in so you can check the calibration easily in both the horizontal and vertical axes.
    Jim Parker
    2007 Rans S-6ES
    Thanks Skywalker thanked for this post
  9. #769
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,081
    Same for me, works great on my Wirlwind prop.
  10. #770
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,841
    I had a used spinner backing plate that was already drilled for nutplates, (though they had been removed and used on some other project) and when I went to install the spinner dome (no holes in it) I was faced with having to hit those existing nutplate holes dead nuts, but without being able to simply back drill as stuff was in the way. I tried re indexing the already drilled back plate on the hub dowels, but that didn't work,So I made this tool, which operates on the same principle as a strap hole duplicator. The thick nylon piece went underneath on the inside of the backing plate, and was moved around until the AN-3 clevis pin clicked into the 3/16" nutplate hole, then the aluminum top part, which had a corresponding 3/16" hole (both drilled on the drill press,only after the "tool" was assembled to insure automatic lining up) served as a guide to let me drill partially through the spinner, then the tool was removed and the drilling was completed. All this while the dome was precisely located (don't want another wobbler) and while clamped to the back plate with edge clamps. Everything fit up perfect, no wallowed out holes at all.
    Likes 180Marty, Mr. Ed, marcusofcotton liked this post
  11. #771
    Meanwhile,...
    5,394
  12. #772
    cubdrvr's Avatar
    Jan 2002
    1,215
    Neat stuff on this thread ! I'm not a tool guy but made this some time ago with a saw,screwdriver and a couple dozen screws.
    Fits in my A model and gives 75" of sleeping room.
    ........also works as a camping table when removed.
  13. #773
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,841
    Is that 3 legs I see, or is the 4 th hidden? If 3, a nice bit of weight saving/design work, (bet it doesn't wobble) if 4 never mind, good concept either way. I had a sleeping deck (72", flat and level) in my first RANS S-7, and it's ply deck was handy for evening out rough ground. It's the minor details that make camping out tolerable.
  14. #774
    Jan 2017
    Utah/Alaska
    263
    Just got these for removing roll pins. Work awesome!
ID:	54914   Click image for larger version.
    Likes akavidflyer, Steve Pierce liked this post
  15. #775
    10,561
    Quote Originally Posted by astjp2 View Post
    https://www.ebay.com/itm/Spring-Tool....m46890.l49292
    Likes akavidflyer liked this post
  16. #776
    Jan 2017
    Utah/Alaska
    263
    Amazon was 27 overnight delivery
  1. Neat Super Cub Stuff on eBay Today
    By Steve Pierce in forum Cafe Supercub
    Last Post: 04-17-2005, 10:25 AM
  2. fuselage jigs
    By Arturo in forum Tips and Tricks
    Last Post: 08-04-2003, 10:47 AM
Tags for this Thread
