Page 20 of 22 FirstFirst ... 101819202122 LastLast
Results 761 to 800 of 841
Thread: tools, jigs, fixtures, and other neat stuff
  1. #761
    jimboflying's Avatar
    May 2005
    627
    The center section is longer than the side plates to enable clamping the workpiece in the vise and to hold the whole device in the vise.
    Likes moneyburner, gahi, SuperClub liked this post
  2. #762
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,128
    I’ve been changing the cylinders on a O-320 ,parallel valves. Wondering what other guys use to compress the springs and installing the rocker arm s and shaft. Mine is a bit clumsy, but works , just like something nicer.
  3. #763
    Apr 2009
    AK
    272
    Just bleed the lifters down (you’re checking dry lash anyway after changing cylinders, right?), and you don’t need to compress the valve springs to install rockers... that being said, I’d be interested in people’s valve spring compressors, have seen various versions and made one or two...
    Likes gahi liked this post
  4. #764
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,128
    More than one way to skin most cats,lol. One other way is check the dry lash , then remove the push rod( cover not installed yet) , oil the lifter assembly, install the push rod cover then push rod and then install the rocker arms and shaft. The valve spring need to be depressed slightly to smoothly install the oiled shaft. Kinda repeats some steps but when you crank the engine for the first time things are oiled and ready to rock(pun). I enjoy making little tools for jobs like this, Mike at MCS has to have a few. This isn’t meant as a jab, again different methods.
  5. #765
    Apr 2009
    AK
    272
    Just spin the prop by hand for a few seconds and build oil pressure after installing the rockers- you’ll be able to feel/see when the lash is taken up- sounds like your method works too; lots more than one right way to do most things...
  6. #766
    3,869
    Not home-made tooling, but old school & vintage :
    Cam Tool Inc bead breaker for removing tires.
    Easy to improvise something similar based on how this works.
    Likes RVBottomly, algonquin liked this post
  7. #767
    Jan 2017
    Utah/Alaska
    371
    I just love this little digital level, it works great for checking travel on ailerons, flaps and elevators, $29 on amazon and fits in my tool box easy. Tim
    Likes algonquin, richts liked this post
  8. #768
    JimParker256's Avatar
    Aug 2015
    Farmersville, TX
    493
    I purchased a similar digital level, but in a more "elongated" (6") form that would allow me to attach it to the prop with a couple of elastic bands so I can set the pitch on my ground-adjustable prop, without needing a third hand, or performing unnatural acts. Added bonus that it comes with a pair of "bubble levels" built in so you can check the calibration easily in both the horizontal and vertical axes.
    Jim Parker
    2007 Rans S-6ES
    Thanks Skywalker thanked for this post
  9. #769
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,128
    Same for me, works great on my Wirlwind prop.
  10. #770
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,101
    I had a used spinner backing plate that was already drilled for nutplates, (though they had been removed and used on some other project) and when I went to install the spinner dome (no holes in it) I was faced with having to hit those existing nutplate holes dead nuts, but without being able to simply back drill as stuff was in the way. I tried re indexing the already drilled back plate on the hub dowels, but that didn't work,So I made this tool, which operates on the same principle as a strap hole duplicator. The thick nylon piece went underneath on the inside of the backing plate, and was moved around until the AN-3 clevis pin clicked into the 3/16" nutplate hole, then the aluminum top part, which had a corresponding 3/16" hole (both drilled on the drill press,only after the "tool" was assembled to insure automatic lining up) served as a guide to let me drill partially through the spinner, then the tool was removed and the drilling was completed. All this while the dome was precisely located (don't want another wobbler) and while clamped to the back plate with edge clamps. Everything fit up perfect, no wallowed out holes at all.
    Likes 180Marty, Mr. Ed, marcusofcotton liked this post
  11. #771
    Meanwhile,...
    5,505
  12. #772
    cubdrvr's Avatar
    Jan 2002
    1,344
    Neat stuff on this thread ! I'm not a tool guy but made this some time ago with a saw,screwdriver and a couple dozen screws.
    Fits in my A model and gives 75" of sleeping room.
    ........also works as a camping table when removed.
  13. #773
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,101
    Is that 3 legs I see, or is the 4 th hidden? If 3, a nice bit of weight saving/design work, (bet it doesn't wobble) if 4 never mind, good concept either way. I had a sleeping deck (72", flat and level) in my first RANS S-7, and it's ply deck was handy for evening out rough ground. It's the minor details that make camping out tolerable.
  14. #774
    Jan 2017
    Utah/Alaska
    371
    Just got these for removing roll pins. Work awesome!
ID:	54914   Click image for larger version.
  15. #775
    11,161
    Quote Originally Posted by astjp2 View Post
    https://www.ebay.com/itm/Spring-Tool....m46890.l49292
    Likes akavidflyer liked this post
  16. #776
    Jan 2017
    Utah/Alaska
    371
    Amazon was 27 overnight delivery
  17. #777
    May 2005
    627
    I made some dies for creating an offset in sheet metal. The top die needs to have a recess the thickness of the metal offset. The bottom one needs a recess the thickness of the metal plus the amount of offset desired. The bolts are used to keep the dies in alignment and thread into the bottom die. A heavy hammer can be used as a persuader or you could also use a hydraulic press for the forming pressure.
ID:	59283Click image for larger version.
    Likes RVBottomly, Nolan, tedwaltman1, brown bear liked this post
  18. #778
    RVBottomly's Avatar
    Sep 2017
    1,349
    Quote Originally Posted by jimboflying View Post
    Nice idea! Just last week I was trying to do something like that with a brake. It was tedious and sloppy.
    Likes Nolan liked this post
  19. #779
    21,783
    Make shims a bit thicker than the joggle, tape them to either side of the material to be joggled and use the shoe of the brake like a press to bend the sandwich of shims and material.
  20. #780
    Aug 2016
    River Falls, WI
    38
    Thanks for the Tip Steve!
  21. #781
    May 2014
    884
    I’ve been fooling around with a bead roller lately.
    think you can get similar results:
    if I’m interpreting your photos correctly.
    Likes Steve Pierce, tedwaltman1 liked this post
  22. #782
    21,783
    Lots of ways to skin a cat. Never enough cool tools.
    Likes jrussl, tedwaltman1 liked this post
  23. #783
    May 2005
    627
    Bead rollers are great. I had problems making really straight lines and was limited by the offsets of the rollers available.
  24. #784
    May 2014
    884
    The fancier ($$) rollers have good guides which really help with straight lines, power feed helps a lot too.
    for the offset I’m doing in the photo above I made a guide out of an aluminum disc and stacked washers behind die for spacing. Im currently doing a kydex interior, the roller really ads a nice finishing touch to panels.
  25. #785
    May 2014
    884
    GettingClick image for larger version.
ID:	59309Click image for larger version.
ID:	59310 a little rednek here.
    but made a guide for wider stuff, guide clamps on and adjusts with vice grips, works pretty well.
  26. #786
    May 2005
    627
    Great idea on the fence. I will try it.
  27. #787
    11,161
    Now this is a vice. Was putting glass in a big Kamatsu dozer at a local farm shop when I saw this, pedestal is floor mounted to a 4'x4' x 3/4" thick steel plate. My XXL glove for comparison
  28. #788
    White City, Oregon
    978
    A couple months ago bought this…
    It’s a Laser cutter, etcher all around cool machine that is primarily being used for doing this..
    Marking part numbers, serial numbers and other bits of info on our STC products.. The above pictures are remote drain lever arms for our remote drain gascolators bowls..
    I also picked up a Creality Ender 3 3D printer for making jigs to use in the laser.. here is one for one of our gascolator covers..
    Although we got it for our products, I can’t help but play with it on my off time and make things for family like the following..
    Made this for my wife, she loves elephants..
    Made this for my dragon loving nephew..
    Working on this shelf for my daughters gem stones..
    My son printed this..
    To use in the hot Rod dash here..
    Angled the gauges for better viewing..
    Speaking of hot Rod ..
    In the shop doing an electrical system..
    Brian
  29. #789
    21,783
    No more numb hands from the vibrating scribe? Nice.
  30. #790
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,101
    A remote control oil cooler shutter gizmo I made up, using Anti Splat Aero's shutter, $150.00 or so for everything, it all comes off for summer. :https://youtu.be/MZWr2MhLfEc
  31. #791
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,101
    Turns out, these remote units are common and inexpensive enough to be linked to the micro (what they call them) linear actuators on Amazon, that's how they came to my attention. I tapped into the plane's e system forward of the firewall, right close to where the control unit (about the size of a pack of gum, with high quality WX proof disconnects on both ends) is zip tied.
    My mind is spinning for other uses for these things. First, my crane has 2 lube points in the boom, only accessible is you extend EXACTLY the right amount of boom, usually it takes two people, and yelling back and forth, or if me alone lots of climbing up the ladder, then back down and up into the crane cab, a PITA. I am going to make a simple clamp on device using these two items, so I can retract or extend the boom while on the ladder, using the remote. If I get real crazy.... I can think of lots of other uses for around the compound, the crane, and the plane, but will hold off until I see how reliable they are. They seem almost too good to be true.
  32. #792
    RVBottomly's Avatar
    Sep 2017
    1,349
    How much force do they put out?
  33. #793
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,101
    14.4 pounds of push/pull.
  34. #794
    gpepperd's Avatar
    Aug 2005
    Wasilla, Alaska
    235
    What is the range of the Bluetooth controller? Thinking movable trim tab on the elevator.
    Good judgment comes from experience, and a lot of
    that comes from bad judgment. will rodgers
    "Anyone who would give up liberty for safety deserves neither" Ben Franklin
  35. #795
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,101
    I stepped off what seemed to about 70-80', and I have a good eye being the crane biz, and it still worked. If I didn't already have a hard wired Ray Allen electric pitch tab, I'd consider it's use for that to be....worth looking into.
    I ordered another today, for my crane lube scheme, and as that need is infrequent, I will use the same actuator and remote to mod my tail hook release on my ski ramp. More to follow.
  36. #796
    11,980
    Can't you just mount a mirror on your crane boom which you can see from the Cab? Maybe paint a couple of stripes on it for alignment purposes?
  37. #797
    Dec 2017
    NE
    76
    Can you post post a link to the model you used? I watched your video and searched but didn’t come up with what you used. Thanks
  38. #798
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,101
    The holes are too small and too far (70+') for the mirror trick. 4 sections of the telescoping boom have to line up, for the grease gun's needle tip to fit.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    https://www.amazon.com/dp/B07X3Z68GV...roduct_details
    Thanks Supercubrancher thanked for this post
    Likes jrussl liked this post
  39. #799
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    2,101
    More fun with the little micro linear actuators and their (optional) remote control.
    This is my tail hook release, used on my staging area to hold back the S-7 while I do a partial runup, on the skis, and right at the edge of my sloped "runway". It started out being ON the tail, then last year I had the idea of using the Hydro Swing door truss as a hardpoint and with a pulley and some paracord leading up to the cockpit, I could release it and fly off, leaving most of the hardware on the ground except for a 8' length of rope which I remove on the first landing, or not, doesn't hurt anything and maybe adds a bit of yaw stability!
    Now, no more open window and paracord, (or worries about maybe the paracord fouling on the tail rigging...) just another key fob remote and click, it releases. I had wondered if the frequency would be the same or different then the one I'm using for my oil cooler shutter, turns out they are different so one doesn't interfere with the other.
    Likes RVBottomly, silflexer liked this post
  40. #800
    Jan 2017
    Utah/Alaska
    371
    Good screws for the engine compartment adel clamps, not cheap but a super time saver because they have a reduced head size. Mostly need #10 and use mostly 5/8” long or longer with ms21042-L3 nuts.
    https://www.aircraftspruce.com/catal...es/nas1801.php
  1. Neat Super Cub Stuff on eBay Today
    By Steve Pierce in forum Cafe Supercub
    Last Post: 04-17-2005, 10:25 AM
  2. fuselage jigs
    By Arturo in forum Tips and Tricks
    Last Post: 08-04-2003, 10:47 AM
Tags for this Thread
