Page 16 of 16 FirstFirst ... 6141516
Results 601 to 617 of 617
Thread: tools, jigs, fixtures, and other neat stuff
  1. #601
    3,256
    Hunting season. Something(s) will appear!
    Thanks STaylor2 thanked for this post
  2. #602
    jimboflying's Avatar
    May 2005
    479
  3. #603
    10,083
    this one is about car work, but could easily apply to making airplane metal work, simply, he explains things well... only watched a couple of his channels videos so far, but hope the rest are this informative...
  4. #604
    4,317
    Anyone tried super glue-baking soda repairs for composites?
    https://m.youtube.com/watch?v=KU2qph...ature=youtu.be
  5. #605
    RVBottomly's Avatar
    Sep 2017
    436
    I haven't used superglue, but I did mix some baking soda with epoxy to make it fire-resistant. Initial tests looked promising.
  6. #606
    marcusofcotton's Avatar
    May 2009
    Cotton, MN
    342
    Years ago used for minor prop nicks (following manufacturer recommendations), worked well and lasted. A little permanent marker to improve color matching.
    Practicing open cockpit extremism
  7. #607
    4,317
    How was it to sand flush?
    Interesting technique!
  8. #608
    10,083
  9. #609
    May 2009
    Cotton, MN
    342
    Iirc ( it's been awhile) I think I used a file on it. I don't recall there being any significant difficulty to it.
    Thanks gdafoe thanked for this post
  10. #610
    4,317
    I need to learn how to fix chips in my CF prop. Whirl Wind told me to fill the chips with gelled superglue and touch up the paint. No mention of sanding but I can't imagine how to get a good result without. Warp Speed says to use 5 minute JB Weld. Interesting stuff.
  11. #611
    18,324
    Found this windshield wiper arm puller at a tool vendor at Sun & Fun. Works great with a longer round head scew installed for pulling those stuck fuel valve handles.
  12. #612
    Dec 2004
    Inkom, Idaho
    1,246
    A tool, sort of, the BalanceMaster I have 13 hours on now is a no brainier re: prop Nick's/ balancing are concerned. Well worth the 10 Oz's weight, Rotax app.
  13. #613
    May 2005
    479
    I have tried some Cherry Q self plugging 1/8 inch rivets but am having problems with the stem pulling all of the way through leaving an open hole. What am I doing wrong?
  14. #614
    18,324
    Quote Originally Posted by jimboflying View Post
    Not sure what you are doing but I got these from Wicks years ago as self sealing for oiling tubes. Do t know the part number but can send you some.
  15. #615
    10,083
    Hole in rivet gun is too big
  16. #616
    May 2005
    479
    I bought the actual cherry tool and it helped reduce the problem. Go figure.
  17. #617
    May 2005
    479
    I am building some flaps which required longer cuts than my shear would make. I took the sheet metal and sandwiched it between two layers of my MDF bench top and screwed them together pinching the sheet tightly. I then scored the sheet multiple times with the tool previously suggested by someone here using the mdf edge as a guide. It took about 10-12 passes to separate the piece but it worked like a champ.IMG_2462.JPGIMG_2464.JPG
    You can also use that clamping technique to create bend lines as needed.
    Likes Skywalker, Steve Pierce liked this post
  1. Neat Super Cub Stuff on eBay Today
    By Steve Pierce in forum Cafe Supercub
    Last Post: 04-17-2005, 10:25 AM
  2. fuselage jigs
    By Arturo in forum Tips and Tricks
    Last Post: 08-04-2003, 10:47 AM
Tags for this Thread
