i was flying home from the cabin last night and was about 15 minutes out from home base when the prop started surging from 2400rpm to 2500 and back. after a minute or two of that it settled back down to 2400 and so i continued on. just when i got over the middle of knik arm(of course) a vibration set in, probably not that marked but since the tide was out and i was over mudflats it seemed worse. by taking the power down to 22 squared the vibration went away and i flew the remaining 2 minutes back to fire lake with a little more pucker factor than i like. after landing when i pulled the power the rpms went down to 300 RPM which is lower than normal. the prop/engine also didnt sound "right", had a very tinny sound. i have a 6cyl egt/cht gauge and throughout all this the egt and cht's didnt move. i also have an ei fuel flow gauge and when the prop was surging the fuel flow went up and down as you would expect. the cessna oil temp and pressure gauges also were in their normal position and didnt change. after tying up to the dock i didnt see any oil leaks immediately visible on the prop and the engine oil level was unchanged. i have a call in to my mechanic this AM but thought i would throw this out there to see if this rings a bell for anyone. i am assuming the problem is in the prop but if i have learned anything from owning planes it is that the problem is usually the most expensive possibility. on the bright side the silver fishing on lake creek is great right now, my wife and i limited out fri,sat and sun and we didnt even get out there until 7pm friday.
