jnorris said:
N3243A said:
What modelIf it's a "J" the old saying is "walk away" or "J stands for Junk". Later models like the R are better engines.
Don't be bad-mouthin' the -J engine! There are lots of -J engines (including mine) flying along with no problems at all. There's nothing wrong with a -J. It will only give you problems if you mistreat it.
And by the way, the saying was "if it's an "A" walk away", and even that is a wife's tail. The A engines aren't as bad as the "stories" make them out to be.
I don't mind sitting behind a J. In my honest / humble opinion, the only things "wrong"
with the O-470J are:
It has 2-bolt exhaust flanges at the cylinder heads instead of the 4-bolt flanges
found on later engines. This is easily rectified by having thicker (1/4 inch)flanges
welded onto the stacks... (I've done this on my O-470J). The 2-bolt flanges tend
to warp and you can get leakage at the port (bad thing if you let it go un-checked...).
The J has "lightweight" (parallel valve) cylinder heads when compared to the later
K, L, R etc. engines. This is "rectified" by being "nice" to your cylinders! (watch CHT /
EGT temps carefully, operate in "conservative" mode (run a bit more fuel through the
engine, don't operate lean of peak, etc.), Be mindful of shock-cooling, ensure the baffling
is in good condition, and never take off with your cowl flaps closed.... 8^)
If it still has the 3-ring pistons, oil consumption can be "elevated" when compared to
later engines. Maybe I'm lucky, and I don't know if I have 3-ring pistons or 4-ring pistons,
but mine goes 20+ hours before I have to add a quart of oil (I think it leaks more than
it burns!).
The good thing about an O-470J is, depending upon which piece of
documentation you believe, the J engine is between 25lbs and 35lbs
lighter than any of the later engines. Light = good (and fast). Lighter
is also better when you're trying to take off and land in short distances...
My '54 weighs 1580lbs with the back seat out (that's actually weighed,
with a decent paint job & "fluffy" interior) and it goes 142mph down low
(@ 22 squared) and 162mph up high (2200rpm @ max manifold
pressure). The only mod on the airframe is the Metco horner-style wing
tips.
