Thanks Thanks:  0
Likes Likes:  0
Results 1 to 13 of 13
Thread: F M engine oil filter adapter on a o 200
    Mar 2009
    timmins ONT
    29
    i installed a fm engine oil filter adapter on a Continental o 200 and my oil pressure is a 100 psi on start up 600 rpm at - 1 celcius 15w50 oil
    check with another gauge
    check oil pressure release valve
    remove oil screen
    remove oil cooler
    and still high oil pressure . after engine oil tempature goes to 100 + the oil pressure drops in the normal range
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    Got a FM on my 0-200 and never seen over 45 cold and 40 hot. Is it a new engine.
    20,199
    I've installed a lot of them with no problems.
    May 2006
    Simi Valley, CA
    153
    Wrong filter?
    DaveG
    Mar 2009
    timmins ONT
    29
    the filter is a tempest p/n AA48108
    my engine has 900 hours
    May 2006
    Simi Valley, CA
    153
    Just looking at ACS catalog and I would guess it should be a 48110
    DaveG
    Mar 2009
    timmins ONT
    29
    I went to check out some oil filters at a aviation place and the CH48110 is a male end on the oil filter. I need a female on the filter for the FM adapter.
    I would like to know the differents between the Tempest AA48108 and the Champion CH48108-1 is there a differents for oil pressure release valve?
    10,314
    Did you try another 108 filter, I think there is a check valve in the filter to stop the oil from running back into the engine after shutdown and it might be sticking shut untill the oil warms up freeing it, try another filter.
    11
    Just got Tempest TAF-L filter to put on C90 on 1957 PA18. Finally have gotten tired of pulling screen at every annual. Went to just bolt up and surprise cylinder baffle in way so needs to be modified. Has anyone else had to do this and if so any pictures to see what it should kinda look like. I have been searching the form and see number of people put them on different aircraft but no real info on doing it or issues they ran into to complete the install.
    39-J3's Avatar
    Sep 2008
    Maine
    560
    I have the TAF oil filter STC on my 0-200 powered PA-11. I have owned the cub for about four months now. Over the past few weeks my oil pressure has been dropping off, at Idle it went down to 0 pounds of pressure,,, not good. I changed the oil and filter this past weekend and no change. I pulled the pressure relief valve to see if it was clean and working properly. It looked good. I then figured I would check to see if the screen was still in ( as I thought with a spin on oil filter the screen would have been removed) It was plugged solid with carbon build up and other crud. I bet it hasn't been removed since the engine was overhauled 700 hrs ago. My question is,, Should the screen be left in or removed? From what I have read from F&M, it can be left in but must be written in the log books that is still installed and removed at every oil change. Doesn't that defeat the ease and purpose of having the spin on oil filter?
    Larry.
    2,536
    https://www.tempestplus.com/Portals/...structions.pdf
    Says remove screen now. May have changed from the F&M days. Mine was left in under the old instructions.
    fancypants's Avatar
    Jan 2011
    IL
    385
    I removed the screen when I installed my spin-on filter. This very helpful walk-through shows that there is nothing important between the oil screen and the aftermarket oil filter. http://150cessna.tripod.com/oilflow.html
    So I guess the only reason you would leave the screen in is if you like to wear a belt along with your suspenders, and want to practice safety wiring in tight quarters every 25 hours.
    39-J3's Avatar
    Sep 2008
    Maine
    560
    So now Iím curious. As most know I have been having big problems with my 0-200 puking tons of oil. A quart an hour. We did a top overhaul, new crank seal and even put an oil separator on. Still puked oil.
    Now Iím wondering if the completely plugged oil screen would creat crankcase pressure causing the oil to blow out the vent tube?
    Itís going to be a week or so before I get back to the airport for a flight and find out.
    Larry.
  1. ECI oil filter adapter
    By mikombs in forum Modifications
    Last Post: 08-26-2005, 07:40 PM
  2. B@C Oil Filter Adapter
    By Propeye in forum Experimental Cubs
    Last Post: 06-11-2004, 11:46 PM
  3. BC oil filter adapter
    By PA12driver in forum Tips and Tricks
    Last Post: 06-24-2002, 08:38 AM
