Thanks Thanks:  0
Results 1 to 13 of 13
Thread: Belly pod for a wide body
    cgoldy's Avatar
    Apr 2009
    Moogerah Queensland Australia
    460
    Has anyone any advice on fitting a belly pod to a wide body?
    Should I weld on new mounting tabs further inboard for it?
    Should I build support for the outer rim or is the fabric going to give it enough suport.
    Or Should I just look for an extra wide Pod?
    Do they even exist?
    mike mcs repair's Avatar
    11,773
    I think we just made longer straps.... all the angles are the same... was a few years ago... but I think it was a non-issue...
    they just sit against the fabric anyway....
    Jan 2005
    wasilla ak.
    342
    Keep your fingers crossed i heard a pod for a standard cub will be available soon which rides on the longreons not the fabric all the way back. Good news is It will not be certified. Larger doors for moose quarters and a fair bit lighter. Front end was designed for better airflow in slipstream. I will see if i can dig up some autocad drawings of the pod. They do exist. It should fit a widebody a little better. Also a underseat storage which will not crack out when overloaded and someone sitting in the rear seat.
    11,773
    Quote Originally Posted by gander
    ... Front end was designed for better airflow in slipstream. ......
    I always wondered why they bothered curving the pod in front being its already in dirty air mostly from gear/cabane vee, will there be any real gain???
    I could see it being worth the effort on a spring gear plane.....
    DW's Avatar
    Dec 2002
    pacific northwest
    2,067
    I've heard a lot of guys say they fly a little faster with the pod then without, I can't tell any differance with mine, I know it doesn't slow it down any.
    DW
    Jan 2005
    wasilla ak.
    342
    Not much effort involved if it is being done on a computer ran threw a cad generated wind tunnel and cnc cut. any improvement is worth the effort.
    May 2006
    Chugiak, AK
    207
    I picked up 5 mph cruise when I installed my firman pod.
    John Pex
    72A
    Chugiak
    AK
    WhiskeyMike's Avatar
    West Boxford MA
    975
    belly pod
    What about the Airglas LT32? I'm getting ready to install one on my 160 Cub. No speed loss? Not much weight added? Box with tank inside doesn't weight much anyways.
    Grant's Avatar
    At Work.....
    1,932
    I need to install pod tabs on a new fuselage. I dont have the pod yet. Looking for a reference distance from the rear gear fitting.
    Thanks!
    May 2014
    Buena Vista, CO
    192
    Quote Originally Posted by Grant View Post
    Thanks!
    Heya Grant - Did you order a pod yet? If you are widebody and experimental, there is a gentleman local to me that builds both fiberglass as well as CF pods off a plug he made. Fuel cells, etc available and I think he has one fiberglass pod available right now. PM me if you want his contact info.
    -dave
    2,514
    Call Gabe at Airframes Ak he usually has that stuff memorized, if not he has a fuselage sitting next to him he can measure. DENNY
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    747
    39.75" From rear gear fitting to the tab. It's basically backed up against the cluster at that location. Lots of wiggle room though, the strap doesn't have to be perfectly located.
    Grant's Avatar
    At Work.....
    1,932
    Quote Originally Posted by Crash, Jr. View Post
    Thanks Crash! Just ordered a slug of stuff from Court...(Including the tabs)
    Likes Crash, Jr. liked this post
  1. Wide body cub
    By ag-pilot in forum Cafe Supercub
    Last Post: 08-25-2015, 11:10 AM
  2. Wide Body
    By Henry Baker in forum Cafe Supercub
    Last Post: 03-29-2004, 05:42 PM
  3. Wide Body Cub
    By Frank T in forum Modifications
    Last Post: 08-08-2003, 07:09 AM
