I have a PA-18-180 with stock wings. I flew the plane for 400 hours without VGs on Edo 200 floats, 31” bushwheels, and skis (Aero 3000, and Landes LW 2500). I then added Micro Aero VGs and have flown the plane another 300 hours. Here are my observations about the VGs.
PA-18-180, stock wings, without VGs:
Power off, full-flap stall – With the stick full-aft, the plane gently buffets with a gentle porpoising motion as the plane gains and loses a touch of speed in and out of the stall. The plane is controllable moving the stick right and left. Not particularly scary. I don’t spend much time in this configuration, so I don’t place much emphasis on flight characteristics here. However, this is where most people will expound on the gentleness of their aircraft in the stall. I test flew a Sportsman 2+2 at the factory, and the test pilot told me that the plane would just “mush” in the stall while remaining totally controllable. He meant specifically the power off stall and did not demonstrate the characteristics of the airplane in the power-on stall. He wouldn’t allow me to perform nor would he perform power-on stalls. I’m guessing if they did this, they wouldn’t be able to tell me that their plane did not break in the stall.
Power on, full-flap, constant altitude stall – While increasing angle of attack and adding power to maintain altitude, my plane would stall in a nose-high attitude with the stick about three quarters aft and power around 2200 RPM. The break was crisp and abrupt with minimal to no buffet prior to the stall. Of course, I know the stall is approaching, but when it goes, it goes. Flying, flying, flying, ….not flying.
Full power, clean configuration (an oxymoron I know) or with 20 degrees flaps, departure stall – The stall is pronounced with a crisp break like in the previous example.
After Micro Aero VG installation:
Power off, full-flap stall – With the stick full aft, the plane is truly controllable with the classic “mush” feel. Rate of descent is constant with no pitch oscillations. As mentioned earlier, since I don’t spend much time in this configuration, the stall behavior is not as important to me.
Power on, full-flap, constant altitude stall – This is where I do spend time (not the exact condition, but similar - more of a classic approach stall), especially when spot landing a very short strip. At altitude, as the stall develops, the first thing I notice is that my stick begins to move fore and aft (not sure of the actual deflection, but definitely noticeable). This precedes the buffet, which is significant compared with my experience without VGs when the airplane will break without much warning. With VGs, the airplane is clearly communicating with me that the stall is developing and gives me ample warning to adjust pitch or power or both to prevent further development. If I continue to increase angle of attack, the plane will definitely break, but not as crisply as without VGs. The stick continues to move (a poor-mans stick shaker) and the plane buffets as the nose drops.
Full power, clean or with 20 degrees flaps, departure stall – The stick is back, but not fully aft at the stall. As the stall begins, the stick begins to gently oscillate fore and aft as it would in the previous configuration, except that the stick movement occurs a bit later into the stall and doesn’t provide as much warning. However, the buffeting and stick shaking as the stall develops is ample warning to change angle of attack. The break is not crisp, but rather buffety (I know it’s not a word, but you get the idea)
My conclusion after installing Micro Aero VGs is that I am happy with my decision. Since most airplanes have benign stall characteristics during the power-off stall with or without VGs, I don’t give much credence to claims of benign stalls if there is no mention of stall performance with significant power. With VGs, my airplane talks to me and gives me ample time to make a power or AOA adjustment to reverse the stall development. Prior to VGs, my plane would enter a stall abruptly without much warning (at high power settings). For me, the value of VG’s is not flying 3 mph (or whatever the claim is) slower, and I don’t fly into shorter gnarlier areas because I fly slower. It’s more that when I’m flying on the ragged edge, I can detect a problem instead of wondering if I’m too close to the break to be comfortable. And in case you are curious, I have never had the plane buffet on me during normal operations except on occasion during a maximum performance takeoff when I lift off with a pull of full flaps and enter ground effect. For a brief moment here, I occasionally sense the plane on the edge until I accelerate and reduce the AOA.
