Page 1 of 2 12 LastLast
Results 1 to 40 of 45
Thread: Extended Leading Edge rib stitching
    9,371
    My leading edge skin is extended 12-1/2" aft of the spar on the top and stops at the spar on the bottom. How is everyone attaching the fabric to the bottom cap of the rib in this area where you can't get a full stitch in place. Do you just run the stitch around the lower cap? or do you glue it in this area and start the stitching at the 12-1/2" location?
    10,421
    Extended leading edge gets drilled for the stiches to go throgh it, drillfrom bottom
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    The way I did mine .....
    Attach the front edge of the extended LE to the normal leading edge (1/2" overlap) then clamp it down to the ribs. Using a square, draw pencil lines that align with both edges of the ribs. Cross mark these lines where the normal rib stitches (spacing) would go. Remove the extended LE from the wing. Using a step drill, drill 3/8" holes (slightly to the outside of the line to leave some material in the center) at the rib stitch cross-marks.
    The 3/8" holes are larger then needed to pass the rib stitch through but being "over-sized" insures that the you can easily pass the needle / stitch through the hole without getting it up against a sharp edge where it could chafe through. Also, about 1/2 the hole will be over the rib so the thread should not be shafed on the inside either.
    Take care,
    Crash
    9,371
    Both interesting ideas. I had not thought of stitching the upper surface over the leading edge. You are correct in making generously sized holes to prevent cutting the stitches. I was going to attach the top fabric the same as if it were a wood skinned wing, glued down to the edge. The concern with the lower surface is to hold it up tight to the rib because of the slight concave curve of the cap strip.
    What do you think of just stitching the lower cap back until you can get a full stitch?
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    You're now in the lifting portion of the wing where the extended LE is being installed. I would NEVER just glue the fabric down. Rib stitch or use big headed rivets or some type of mechanical fastener in this area.
    Setting the spacing and pre-drilling almost makes extended leading edges a "non-issue" when covering the wings. Every set I've ever seen, was done this way.
    Take care,
    Crash
    citabrickr's Avatar
    Sep 2009
    NJ
    30
    Why don't you just stitch around the lower rib cap?
    3,362
    Cuz at high AOA, the fabric will be pulling away from the wing structure on top. Glue MIGHT be fine, but if it's not - - -
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,376
    Quote Originally Posted by Crash
    Take care,
    Crash
    Setting the spacing and pre-drilling almost makes extended leading edges a "non-issue" when covering the wings. Every set I've ever seen, was done this way. DAVE
    gpepperd's Avatar
    Aug 2005
    Wasilla, Alaska
    215
    So has anyone ever tried running a 12" strip of fabric lengthwise down the wing instead of the extended metal? It seems that if the fabric was only glued at each end it would shrink tight in a lengthwise direction with no scallops and support the main covering layer. I was thinking of trying that to save weight and the rib stitch issue.
    Good judgment comes from experience, and a lot of
    that comes from bad judgment. will rodgers
    "Anyone who would give up liberty for safety deserves neither" Ben Franklin
    10,421
    Quote Originally Posted by gpepperd
    don't think that would work without a strong strip at back edge of fabric strip...
    you could do some serious lightning holes in ext LE maybe, I have seen .016, but you must use angles under it....
    if you shrink fabric right you will not have much scallops at all...
    for top of wing you shrink in strips long ways of wing starting from center of wing & at high part of rib curve, out both ways, and then move an inch or two and do another stripe, tring to finish that forward curved area where scallops form before going near rear part of wing.... and at end do whole wing.... never front to back or you guarantee HUGE scallops
    not sure if this shows well, but this is without extended LE, shrunk right to avoid scallops
    18,757
    The medium fabric being produced right now is a few ounces shy of the previous heavy fabric. It pulls tight with out much scalloping. I actually thought the scallops helped slow flight. I thought that is why the wood spar J3 with the 3/4 wrap leading edges flew better than the aluminum spars with full wrap leading edges.
    Likes flywhatever liked this post
    JayH's Avatar
    Mar 2005
    NE Iowa
    269
    I stitched around the whole rib up to the aft edge of the extended leading edge skin. Then I went around just the bottom rib cap to the spar. On top, I used fabric rivets through the extended portion of the leading edge skin up to the spar. I have photos somewhere.
    J
    Aug 2002
    AK
    258
    We use to put extended leading edge on almost every set of wings we built. If we didn't we would "pinch an inch". After gluing fabric on the leading edge of the top of the wing, we would gather, with clothes pins, an inch or more of fabric in two places length ways about 12" aft of the front spar. This would gather more length ways strands of fabric and when shrunk like Mike said it would make the fabric extremely tight over the area of the ribs that are most prone to scallop. I know the extended leading edge works, but on my wings that i am building now i think i will forgo the weight and "pinch an inch".
    Jul 2002
    Anchorage, Alaska
    5,376
    Quote Originally Posted by Fabman
    How does it work? I mean what does it do?
    Aug 2002
    AK
    258
    Works to keep the fabric from scalloping.
    StewartB
    Guest
    So it the advantage of reducing/eliminating scallop based on performance or cosmetics? I remember disagreement about any benefit and have never heard anything conclusive to support extending the edges or even in attempting to eliminate scallop.
    Is the FAA allowing you to extend? Three years ago I was told not to even think about it. The FAA would not even consider allowing it without engineering.
    Stewart
    Nov 2002
    Charlotte, NC
    1,859
    We went through all this before and it was someone like Crash or Jerry Burr that originally linked us to this 1927 NACA report that says the scalloping of the fabric has no effect on the amount of lift produced by a wing.
    http://ntrs.nasa.gov/archive/nasa/ca...1993087647.pdf
    John Scott
    Aug 2002
    AK
    258
    I guess that's where I am at. I know the extended leading edge, if done right, works to eliminate scalloping. Whether or not this is a performance advantage, I'm not sure. I know it adds weight and the frost builds heavier on it then just the fabric.
    StewartB
    Guest
    I've read the 1927 report. I still can't help but wonder how it applies to modern 2000# Cubs with long props, VGs, synthetic fabric covers, and all the other things that have changed in the last 83 years. I know some really good Cub pilots who believe extending the edges improves performance. I mean guys who push performance to limits beyond my own. I've also read rebuttals. In the end I have more information about the topic yet I'm no closer to answering the question about whether there's a benefit. The good news for me is that in my use I'll never recognize such a benefit. That doesn't ease my curiosity.
    Stewart
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    I remember talking to Dan of Dan's Aircraft repair (Anchorage AK). They used to put them on almost every Cub they rebuilt when the FAA allowed it.
    He told me about Cubs they had recovered and the only mod was to extend the leading edges. The owners came back and said "wow, it feels like you installed a STOL kit or something". These were long time owners / Bush operators with thousands of hours in the same plane.
    One day I was at the airport talking with a Cub pilot and commented on how nice the fabric job looked on a Cub. He said "ya it looks great but now it flys like crap, there's too much scallop between the ribs and it won't slow fly like it used to".
    We've also seen pictures posted of Cubs in flight with the fabric on top of the wing billowed WAY up between the ribs. This has got to make for a very fat, slow flying wing.
    So what is the correct fabric tension between the ribs? Extended leading edges removes that question for the most part.
    I also feel they help improve cruise speed. Before, this Cub with big tires, Borer prop., etc. would curise at around 85 mph. Now it cruises at 105 to 110 mph.
    P.S. I weighed them before installation and they weighed 3 lbs.
    Take care,
    Crash
    9,819
    I think Paul Babcock at one of the LHV wing rebuild seminars mentioned something about a metal spared wing has a little bit more lift than a wood spared wing because the leading edge on a metal spared wing goes all the way to the spar, and a wood wings LE is shorter and leaves a 4 or 5 inch gap in front of the spar that is scalloped all the time and decreases lift.??
    behindpropellers's Avatar
    NE Ohio
    6,697
    Interesting to get two opposite views:
    Quote Originally Posted by cubdriver2
    Quote Originally Posted by Steve Pierce
    9,819
    But are we talking about 2 different area's, one is in front of the spar, and one is aft.
    NE Ohio
    6,697
    Glenn-
    You and Steve are talking about wood spar wings and how the leading edge on the bottom of he wing does not go all of the way to the spar. IE 3/4 wrap.
    Bill Rusk's Avatar
    5,236
    From a previous thread....
    Extended Leading Edge skin(ELES)
    I spoke with John Roncz, probably the leading airfoil engineer in the US. He is the one who has designed all of Rutans airfoils and others like john Sharp's Nemesis (dominated Formula 1 for many years). The guy is no yahoo, he knows airfoils and aerodynamics. I asked him about the Extended LE skin (ELES). After a long dissertation on the 35B airfoil origins etc his response was that he did not know of any wind tunnel tests, so take it with a grain of salt, but based on what he knew about airfoil performance, he did not think it would have any positive affect. At high AOA the air is only attached at the LE edge of the wing forward of the front spar. Thus any airfoil deformation aft of the forward spar is in dirty air and basically has no affect.
    All that said, the ELES, remains an unknown because we have no wind tunnel testing, and furthermore we must add the VG's to the equation.
    It does add rigidity, and strength, to the wing. Makes it easies to clean the frost off, and minimizes the scalloping. But it adds weight, 4 to 6 pounds.
    Steve Tubbs, Jerry Burr and John Roncz all have expressed reservations as to its effectiveness at high AOA.
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,349
    Quote Originally Posted by behindpropellers
    Glenn-
    Steve may be talking about J3's with wood spars, NOT J5's. The J3 wood spar used the short LE, (like a PA18 outboard skin), full span. I've heard the same thing as Steve from the old timers that made a living dusting with J3's. The argument has been made before....
    It seems the only reason the metal spars had the skin extended back to them was to keep the spar from twisting. That makes sense. If you really think bending some tin farther back will make it fly better....have at it.
    NE Ohio
    6,697
    Quote Originally Posted by SuperCub MD
    Glenn-
    It seems the only reason the metal spars had the skin extended back to them was to keep the spar from twisting. That makes sense. If you really thing bending some tin farther back will make it fly better....have at it.
    Well obviously I was wrong here, I have not taken apart a wood spar J-3 wing and thought it was similar to a J-5 wing. Regardless, they both have exactly opposite ideas on the subject, which was the main point.
    Alaska/NE Washington
    364
    I believe it is difficult to compare the effectiveness of extended leading edges between an old fabric job and a new fabric job, on the same cub, with the extended edges. A cub with new fabric properly applied flies differently than it did with old fabric. I have talked with accomplished cub fliers and there is not a consensus on whether the edges are an improvement or not. What I have seen is the dents, between the ribs, in the trailing edges of these edges from snow loads, as the fabric is attached to the to the edges during the recovering process. I have seen some edges that were braked on the trailing edge and some that were not. I do think that the scalloping when kept to a minimum probably has not effect on the flight characteristics. Too much scalloping may lead to ballooning, which is a performance killer.
    9,819
    Sorry Tim, I didn't read the second half of SP post " sorry Steve " Tim that pix is of your J5 wing, same LE as my J4, LE goes from top of spar to a couple inches short of the bottom spar, the J3 wood spared wing the LE stops short of both the top and the bottom of the front spar, what I was referring to was that the gap between the shorter J3 LE and the spar is always scalloped and is not as good as a full LE like on a metal spared wing at producing lift or the scalloped one kills it. so if your wrong it's because I may have lead you astray not on purpose of course
    NE Ohio
    6,697
    No....I was mistaken..... I thought the J-3 wood spar wing LE was the same as a J-5. Got to learn something today, I'm sure somebody else did too.
    Regardless...you and Steve can figure it out. I should go home and blow the dust off of the J-5.
    9,819
    It might have nothing to do with the LE scallop as to if a wood spared J3 was sweeter to fly then a metaled spared one, it might be because the wood winged J3 was lighter, not sure, I've only flown a dozen or so Cubs from 37 hp to a 180 hp CC and I think the less then 550lb, 37 hp E2 flew the sweetest of them all. Am I allowed to say that on SC.org
    18,757
    The best flying J3 I flew was a 1938 with a 65 Lycoming solo. Add the passenger and it was the scariest. I'm gonna stick with light and stock on my own SC wings.
    3,362
    Some time ago, maybe a year or two, somebody here posted a link to an engineering report of wind tunnel testing of scalloped vs non-scalloped wings. I wish I could find it again. My recollection of the conclusion is that the scallops had minimal to no effect on stall AOA, or lift or drag as a function of AOA. I remember that conclusion because I was a little bit surprised. I THINK it was another thread on extended leading edge skins.
    9,371
    This topic has gone way beyond my original question, however, it has answered another question which I have had. Why extend the leading edges? & why do some folks see performance improvements and some are disappointed? My guess is that the first person who installed extended leading edges did it to correct the effects of loose fabric. The technique used to iron the fabric controls whether it sags or scallops, aft of the LE. I have found that if you iron between the ribs first, the fabric will shrink in the shortest direction first, chordwise. You will get a scallop or depression, that cannot be raised, similar to a dope job on cotton or linen. If you iron on top of the ribs first, the fabric will shrink spanwise first with the ribs preventing the scallop by holding the loose material up. Once the fabric is tightened over the ribs it defines the shape so that when you shrink between the ribs the fabric comes up to near the level of the rib cap.
    I had a low fabric wing airplane, Cessna T-50, that you could see the fabric rise up between the ribs. It didn't raise very much, maybe an 1/8". The change in airfoil was minimal.
    As far as increased stiffness of the wing is concerned, why? Why would you want the wing stiffer? Have there ever been any structural problems related to the wing stiffness on the cub? Have you ever seen an airliner wing in rough air? It moves up and down many feet. Something could break if it were too stiff.
    I do not see any advantage to an extended leading edge other than someplace to set down the gas can. My wings came with it so I am using it. If they didn't I would not have put it on.
    Nov 2002
    Charlotte, NC
    1,859
    Quote Originally Posted by 12 Geezer
    See my post about 1/2 way down the first page.
    John Scott
    10,421
    Quote Originally Posted by skywagon8a
    .. it has answered another question which I have had. Why extend the leading edges? .....
    one other huge benefit is if you have beat up old ribs with repair patches on them, the extended LE and a little silicone under it where needed makes the wing look smooth and like new......
    StewartB
    Guest
    Had I been allowed to extend my leading edge metal I'd have done so simply for improved durability when removing snow. I could have been more aggressive (less timid?) when sweeping the wings. That's a practical advantage in my world.
    SB
    3,362
    Quote Originally Posted by Longwinglover
    John Scott
    Thank you John. That's the one. Dunno how I missed that, but I sure did.
    Looking at the curves on the last page of the report, it appears the scalloped wing might have a gentler stall - at least the lift curve is continuous through a larger AOA for the fabric wing, though maybe the veneer wing wasn't tested at those higher AOA'S. Anyway, that data does support the idea that the scalloping of the fabric doesn't matter a whole lot. The drag coefficient on the scalloped is a little higher at moderate angles of attack, like in climb, but not much.
    Interesting topic - -
    9,371
    John Scott
    Variable camber. Fat wing for takeoff and climb. Thin wing for high speed cruise.
    Oct 2011
    77
    This is good stuff...I'm currently building up an old cub and researching the nuances of extending the leading edge skins...going back to these old posts is part of the education. Thank you for your input and the article...
    Quote Originally Posted by Longwinglover View Post
    John Scott
    Thanks windy thanked for this post
  1. Extended leading edge
    By Frenchy in forum Experimental Cubs
    Last Post: 02-25-2006, 10:16 PM
  2. VG's on leading edge cuff
    By 750XL in forum Modifications
    Last Post: 08-26-2005, 07:30 PM
