Results 1 to 37 of 37
Thread: New aeromatic propeller on MY 0 200
    Mar 2009
    timmins ONT
    29
    I bought a new AEROMATIC prop for my zenith 701 /750 with a continental O 200
    It took some time to set the prop but it is worth it
    Airspeed was 80 mph at 2500 rpm
    New airspeed 95 +++ at 2500 rpm [cruise]
    takeoffs are unbelievable 2700 rpm 40 mph 1000 +++ fpm
    IT'S TRUE IT LIKE BOLTING A SECOND ENGINE UNBELIEVABLE
    [img][/img]
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,426
    I want one. Actually, I want two.
    One for a 180 HP Lycoming and one for a 340 HP Continental.
    Jan 2008
    3gv
    387
    dynoluc,
    did your new prop come from tarver propellers in nevada?
    www.aeromatic.com
    gary
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    Been waiting for a report on one. How do you think it would work on a PA!! on floats.
    Jan 2008
    3gv
    387
    roger,
    i've had an aeromatic on my pa18-95 for about a year now and it is a good compromise for having a takeoff prop and cruise prop combined automatically into one. if getting off short on floats is your only concern i would suggest that a fixed takeoff prop would be best because the leading edge is thinner and may bite a little better for takeoff, however, if you have a ways to go and want good takeoff and cruise then the aeromatic is best.
    gary
    3,228
    Re: New aeromatic propeller on MY 0 200
    Quote Originally Posted by dynoluc
    I bought a new AEROMATIC prop .........
    How much?
    Jan 2008
    3gv
    387
    hotrod,
    a new fixed pitch cruise prop=2500
    a new fixed pitch climb prop=2500
    a new aeromatic(cruise&climb)=5000
    www.aeromatic.com
    NC
    1,048
    Aeromatic Prop...
    Dave Calkins,
    The Aeromatic prop cannot be used on either the 0-320 or 0-360 Lycomings. It is spelled out on Tarver's web site. The reason is the probability of lag bolt failures. Aeromatics work wonders for the small continentals, however. I had one years ago on a C-90 powered Clip Wing Cub, and it was like having two engines in that cub.
    Mike
    Jul 2002
    Anchorage, Alaska
    5,426
    Re: Aeromatic Prop...
    Quote Originally Posted by CptKelly
    Dave Calkins,
    Mike
    Mike, I was aware that they're not suitable to anything more than an O-235. I was speaking facetiously. The Aeromatic technology would be great as a lightweight alternative to some Hartzell or McCauley constant speed prop.
    DAVE
    3,228
    I didn't look closely enough at the Tarver site to realize that they're only good for up to O-235. They used to hang them on 200 horse Rangers as I recall. I've also heard of a Ranger throwing a blade, and shaking the engine right off the mount in a matter of seconds.
    I'm more inclined toward a controllable prop. I guess MT has one, but they're pretty spendy. and I'm not sure of what they're approved on anyway. The other controllable are the old ones such as the beech Roby, etc. Never seemed to catch on so maybe that kinda sez something about their suitability.
    Eric
    May 2004
    Sweeny, Texas
    1,454
    The two props I am looking at are the Aeromatic and the Sensenich composite propeller C08-1E. I fly the PA11 with a souped up 0-200 on floats for 4 months each summer and then fly back to Texas for the rest of the year. I am now using a 76AK2-40 and my cruse speed on wheels is about 85. That is a long haul fromn Canada to Texas at that speed. Also I only turn 2500 Static with that prop. Would like to turn 2700 Static.
    Any Ideas which one might do the best for me.
    Mar 2009
    timmins ONT
    29
    aeromatic
    The aromatic prop IS best of both world climb and cruise speed
    more video to come
    http://www.youtube.com/watch?v=q3yySVw7hIc
    Mar 2009
    timmins ONT
    29
    aeromatic
    MY new prop came from tarver propellers in nevada
    I wanted a MT prop but at 11,800.00 us it was out of the budjet
    the arematic was half $$$$
    The aromatic is very simple
    Mar 2009
    timmins ONT
    29
    aeromatic
    May 2004
    Sweeny, Texas
    1,454
    How was the setup on the aeromatic. Did it take much trial and error work.
    Jan 2008
    3gv
    387
    roger,
    it took just a tad over 1.5 hr. to remove fixed prop, install new aeromatic, do a static rpm check and adjust the hub shims to get the correct static rpm's, go do a run around the patch, adjust the arm weights to get the correct rpm setting and go fly around the patch to see if rpm is set correctly. nice thing about the prop is you can change the arm weights in 5 min. to change your rpm setting for different altitudes, eg. at my altitude of 1000 ft. during the summer i add or subtract weight to get 2625 rpm but as the weather in late fall cools i have to adjust the arm weights or the rpm will increase to 2680+ which i don't want. likewise, if i move to denver at 5000 ft. elevation i can adjust the arm weight to give me 2625 rpm there also.
    by the way this tarver aeromatic is on my pa18-95 and for this engine it is a great mod.
    gary
    May 2004
    Sweeny, Texas
    1,454
    Talked with the guy at Tarver and am going to go with the Aeromatic. I am now running a 76AK2-40. Don't know if I should order 74" or 76" blades for it. My engine is putting out about 120HP and want good performance on floats. Anyone got any feelings on which might be best on the Aeromatic on Floats.
    What are you running Gary and what engine is it on.
    Jan 2008
    3gv
    387
    roger,
    i am running a 73" prop on my c90-12 engine because my type certificate only allows 73" on koppers aeromatic(now it's tarver).
    i would speak further with old kent tarver because he possesses a great deal of knowledge on these props.
    gary
    May 2004
    Sweeny, Texas
    1,454
    Ordering mine tomorrow. What is your red line and did he give you a red line for the prop.
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    424
    Prop
    Hi Roger would you not think that a longer prop would be better , all borer props are usually longer than a standard prop !
    I would take the longer one
    My plane is still not ready
    Gerry
    May 2004
    Sweeny, Texas
    1,454
    That was my feeling also. Attached is a e-mail to Tarver and his reply.
    I am not a Prop Engr, so hate to screw up something that someone more knowledgeable than me has designed.
    ----- Original Message -----
    To: info@aeromatic.com
    Sent: Wednesday, November 25, 2009 7:35 PM
    Subject: Prop for my PA11
    Enjoyed talking with you about a prop for my PA11. I will be ordering it next week, but still trying to decide if I would be better off with 74" or 76" blades.
    I have a souped up 0-200 continental that is developing between 115 and 120 HP. I have the engine balanced the same as the ones used in the cafe races and it is very smooth and I have run is for a couple of hours at 3500 RPM
    I am now using a 76AK2-40 Sensenich and my static RPM is just under 2500 RPM
    At WOT, level flight, I can reach 3,000 RPM but normally cruse at about 2400 RPM which gives me a speed of about 83 mph.
    I spend 5 month each summer in Canada on floats, but it would sure be nice to have a faster cruse as the flight back and forth to Texas gets long.
    I have been playing with the tip speed calculator on P Ponk Web Site http://www.pponk.com/HTML%20PAGES/propcalc.html and if I stay with 2750 as red line, it looks like 76" might be better, but I know there is more to it than that. I have flown in Super Cubs using the Bore 80" props and they really pull.
    Roger
    Just a few problems I see with the tip calculator. You have to add the forward speed of the airplane to the tip speed. The calculator sayd that a 74" prop doing 2800 rpm, the tip speed is 616.4 mph and that equals mach .86 at 0 deg. At 100 deg 616.4 mph equals .78 mach.
    Add cruise speed of 100 mph to the 616.4 = 716.4 mph which = approx mach .94.
    Density altitude is used to calculate mach number and DA not only takes into account temperature but also the specific weight of air at the altitude of operation. The thickness of the blade at the tip also affects what tip speed you can go. A real thin blade can go closer to mach 1 without mach buffet than a thicker one. The effeciency curve is not linear. You could have air going over mach 1 when the tip speed is less than mach 1.
    At the flight levels that we fly at, usually vfom 0 to 10K' the temp from summer flying to winter flying is far greater difference than the elaps rate of temp due to altitude change. Where I am I could be flying in the winter at 0 degrees and as high as 110 deg in summer. That's a big difference, 110 deg. The temp gradent from 0 to 10,000' on a given standard day is only 35.7 deg.
    So you can see that there is more to it that the calculator deals with.
    Happy Thanksgiving.
    Kent
    May 2004
    Sweeny, Texas
    1,454
    Gerrry, Do you think you will have it by next spring. You might forget how to fly by the time it is done.
    Jan 2008
    3gv
    387
    roger,
    book redline is 2625 rpm for 5 min. there after 2425 rpm max for my c90-12f engine.
    gary
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    424
    planes
    Roger Get Kevin on board also he needs one for his Champ!!!!
    Hoping to have the plane for Xmas , will keep you posted, interior is almost complete then we have a bit of work on the trailing edge wing skins and then paint
    May 2004
    Sweeny, Texas
    1,454
    Just talked to Kent Tarver and he is starting a 76" for my PA11 With a 0-200. Will use it on both floats and wheels. Going to set it up for 2750 RPM Max
    Jan 2008
    3gv
    387
    roger,
    the ONLY downside to my f200-73 prop. was the extra 9 lbs. of wt.
    congrats
    gary
    10,300
    When I got my pa11, C90,0200 cam and timing, it had been on floats for quite some time, it had a C150 climb prop MC DCM 69x48 on it, the floats were sold before I got it, that prop would turn 2675 on a 80* day and 2750+ in the winter, I tried a few different, longer, flatter props but never found one that would take off and climb as short as that little stick up front, it got sent out for overhaul and came back at 67" and worked even better, it even cruised at around 88 mph @ 2400 rpm. I loved that prop, and it never worked the engine that hard on the hottest day it never went over 180*
    Sep 2002
    1,621
    ........Just a few problems I see with the tip calculator. You have to add the forward speed of the airplane to the tip speed. The calculator sayd that a 74" prop doing 2800 rpm, the tip speed is 616.4 mph and that equals mach .86 at 0 deg. At 100 deg 616.4 mph equals .78 mach.
    The statement above is incorrect. With a tip speed of 616.4 mph due to rpm and an airspeed of 100 mph, the tipspeed becomes
    (616.4^2 + 100^2)^0.5 = 624.44 mph, not 716.4 mph
    I do agree that the tip calculator has problems.
    JimC
    Sep 2002
    1,621
    Roger, on your hopped up O-200, how did that Tarver compare vs the 76AK-2 40?
    May 2004
    Sweeny, Texas
    1,454
    Never put it on. It is still laying in the shop. Planning on putting it on my son's plane in a week or two.
    3,228
    FWIW recently I heard a rumor about Tarver losing his production certificate or something.
    Checked the aeromatic.com website and found this posted:
    "Until further notice, the FAA has put me out of business for certifiec propeller work."
    Aug 2017
    2
    Hello my name is Sam & I have a PA-12 with an aeromatic prop & i am looking to put one on my PA-11 also. If you have a few minutes I would like to speak to you on the phone because I have a couple of questions I would like to ask you.
    My number is 530-624-0072.
    Thanks Sam.
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,672
    There would be a pretty good market for the experimental crowd, or am I missing something? Maybe even better, more sales, then for the certified planes? Selling to both markets makes the most sense. A Rotax version would sell like hotcakes, and I'd be first in line.
    RVBottomly's Avatar
    Sep 2017
    900
    Looks that is what they are doing:
    "Notice
    We are servicing home built aircraft only."
    http://www.aeromatic.com/
    Also, looks like they have them working on O320 abd O360 engines.
    http://www.aeromatic.com/disclaimer/
    courierguy's Avatar
    Dec 2004
    Inkom, Idaho
    1,672
    Once again, the lightweight Rotax kinda changes things....as in adding 34 pounds to the nose of my S-7 would be a huge weight gain, percentage wise, and all in the wrong place. I sure like the concept though. Oh yeah, and I just remembered, I'm flying under the LSA regs these days, and the Aeromatic may not be compliant with that. My 78" Prince P tip prop works great, and only weighs 8 pounds, (7 lbs 10 ozs. actually, not counting the hub) and has a great side benefit of making a real low toned, pleasing to (my) ear sound. I didn't realize it until watching a video someone shot of me flying, that prop masks the whir of the Rotax and sounds real old timey, almost radial engine like, as my actual prop speed is quite low. Flying low over cattle yesterday (not buzzing them, they were just in my flight path....) none ran, most didn't even look up, 30' above them. Livestock make great audio test beds, horses even better.
    G44's Avatar
    Oct 2011
    SW Michigan
    591
    Eric
    Eric,
    MT 2 blade is approved on your 180. Great prop, I have had 3 different ones on a couple of Husky’s, I really like them and think they are worth the money. Speaking of money, all props are pretty darn expensive when you actually compare them all (new prices).
    Kurt
    Edit. Just realized this was an old thread after I posted.
    3,228
    Quote Originally Posted by G44 View Post
    Eric, MT 2 blade is approved on your 180. Great prop, I have had 3 different ones on a couple of Husky’s, I really like them and think they are worth the money. Speaking of money, all props are pretty darn expensive when you actually compare them all (new prices). Kurt
    Yeah, I started reading at the top, then realized this thread was started 10 years ago.
    Wow how time flies!
    An aeromatic prop mighta been just the thing for the C150/150TD I owned back then,
    my current mount (C180) has an 88" Mac that I'm pretty happy with.
  1. aeromatic prop
    By garyh in forum Super Cub Repair Facilities
    Last Post: 03-29-2013, 05:32 PM
  2. Aeromatic propellor.
    By Chuck E. in forum Cafe Supercub
    Last Post: 01-02-2009, 06:48 PM
  3. Aeromatic Propeller Information
    By Captain Ron in forum Experimental Cubs
    Last Post: 05-25-2004, 05:57 PM
