Results 1 to 17 of 17
Thread: Tailwheel Chain - Quick Links
    Darrel Starr's Avatar
    Plymouth, MN
    2,524
    After watching the AK Bushwheel video about correctly setting rudder/tailwheel chain length, I decided to use the quick links as shown in the video. Steve Pierce mentioned in one of the previous threads that I should use quick links with a cotter hole added. He buys from Maule Air. Wup at AK Bushwheels also had drilled links for sale. I also went to the local hardware store and found plain SS quick links made in China with a load rating on the tag that said 220 lb (not clear if this was a working load or breaking strength). My IA felt that I should use quick links with a load rating that was qualified by an international rating organization.
    So I ordered some quick links from both Maule and AK Bushwheels. I was happy to see that these companies buy from the world premier manufacturer of quick links, Peguet Maillon Rapide, a French company. The links are all stamped with the company name.
    This company makes quick links for mountain climbing, parachuting, motorized gliding, marine & agriculture. Their web site contains all of the qualification information to assure that high standards of material, manufacturing and quality control are maintained. There web site is : http://www.peguet.fr/gb/peguet-entreprise.html
    So that is what I learned, buy either from AK Bushwheels or Maule but avoid the hardware store lookalikes.
    Apr 2007
    Kingsburg, CA
    1,256
    Darrel,
    We put a set of these links on a Champ. They were from Maule. Never had any problems with them. we keyed them up and all was well. I would use them again.
    Kevin
    7,384
    What do they do? Will they keep the spring from jumping out of the hole when the tailwheel shimmies?
    Plymouth, MN
    2,524
    Kevin, thanks for the info.
    Bob, the quick links replace the "paper clip" links that attach the chain to the tailwheel steering arms. They would not help in a shimmy. My experience with the paper clips is not so good. They eat into the steering arm and wear enough to cause some concern -- I saw that on my Cessna 120.
    Darrel
    Sep 2006
    Maynard,MA
    1,238
    I have the Maule links and like them.More area through the eye.
    zane
    Guest
    Maillon Rapide makes a variety of screw links like that in various shapes and sizes... we used to use them for leave-behind anchors in rock climbing. Cheap and strong.
    7,384
    Thanks Darrel - I have noticed wear in both the rudder horn and the tailwheel ears, but not enough to really worry about. After 48 years of mostly touch and goes I will watch more carefully - and have another rudder ready to go with steel bushings in the arm.
    I get shimmy about once every three years, and when I am too lazy to re-bush the tailwheel inevitably a spring jumps out - often to be found on our very busy runway (well, once). I have them captured with a highly suspect system, so at least they will follow me home after jumping out.
    Apr 2007
    Kingsburg, CA
    1,256
    I have had one of those paperclip type clips spread apart on me. I had good rudder authority on one direction but the other direction I had to use brake to make it effective. When we got out, I checked the springs. One of the clips was elongated and spread out. To this day, I can't explain how that could have happened since they are a pain to get the chain on. The better set up is the link that is cotter-keyed closed.
    RCharles's Avatar
    Jan 2004
    Atlanta, Ga
    255
    Chain links
    Have had the spring jump out of the paperclip type but cured this potential by safety wiring all the all the joined pieces . Works good .
    How much tension should there be on the springs ...at rest . This is probably personal preference but what is recommended . ...Thanks much .....RC
    20,658
    I use just a little tension on a Scott/AKB 3200.
    cruiser's Avatar
    South Glens Falls, NY
    1,492
    http://www.youtube.com/watch?v=QtokU8mIDQk&NR=1 Another version with a little more/different detail I found on youtube. I've got to stop spending so much time on youtube! Jim
    Tim's Avatar
    Petersburgh, NY
    3,540
    Jim, you flying yet?
    cruiser's Avatar
    1,492
    Yes, actually I circled your place a week ago or so and didn't see any action. No header tank leaks, I am good to go! Jim
    Jan 2017
    King Salmon, AK
    70
    Anyone have a recent source of getting one of these links?
    daedgerton's Avatar
    Jul 2015
    Arlington, VA
    210
    They don't have the hole but they work:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    JWE's Avatar
    Jan 2018
    NC
    133
    Adamgrenda,
    Call Maule and tell them what you need. I ordered some a few weeks ago.
    Call (229) 985-2045
    Jan 2017
    King Salmon, AK
    70
    Quote Originally Posted by JWE View Post
    Adamgrenda,
    Call (229) 985-2045
    called and order thanks a bunch.
  1. ECI oil filter adapter quick drain, quick ?
    By 68D in forum Modifications
    Last Post: 03-18-2008, 05:48 PM
  2. Broken tailwheel spring links???
    Last Post: 12-30-2005, 02:31 PM
