Results 1 to 15 of 15
Thread: Landing Gear and Landing Gear Fittings.
    20,753
    Well my in-laws were in Kentucky last night meandering there way back to Texas with Bill Tracy's Super Cub so I have been getting my parts list together and researching a bit. I remember DW installing these heavy duty front gear fittings from Airframes Alaska but I don't remember any details. Does anyone know what makes them better. Will call when AK wakes up but thought someone here might know. http://www.airframesalaska.com/landinggear.htm
    I have also been researching 3" extended gear. Pricing for landing gear, lower struts and cabane are as follows:
    Cub Crafters $1710.68
    Airframes $1366.00
    Atlee Dodge $1425.00
    I have been told not to mix and match different manufacturers components. Seems there have been some alignment issues with certain combinations. I see where Cub Crafters has an axle machined out of solid piece of 4130. Any other preferences, advantages or dislikes?
    http://www.cubcrafters.com/services/...nded-gear.aspx
    May 2009
    Sheridan WY
    135
    Back Country Super Cubs
    Complete set is $1440.40
    20,753
    Is this certified and how do I contact them?
    May 2009
    Sheridan WY
    135
    www.supercub.com
    Not sure if it is certified. They should be there in another 30 minutes if not already.
    mike mcs repair's Avatar
    11,773
    Re: Landing Gear and Landing Gear Fittings.
    Quote Originally Posted by Steve Pierce
    looks to be much thicker metal for the part with the cabane ears on them
    20,753
    Quote Originally Posted by greenhorn
    www.supercub.com
    Got to be certified for this Super Cub.
    20,753
    Quote Originally Posted by mike mcs repair
    That is what I was thinking. I know DW ordered these and installed on his frame when he was here last Feb.
    May 2009
    Sheridan WY
    135
    Like i said i am not sure if they are or not. Worth an email anyway info@supercub.com. the guys name is Wayne Axelson
    20,753
    That is what used to be Turbine Cubs of Wyoming. They are experimental as far as I know. Appreciate the heads up.
    May 2009
    Sheridan WY
    135
    yes that is correct they are formerly TCOW
    StewartB
    Guest
    My 12 started life on Airframes 3" extended Cub gear and Atlee Dodge 3" extended PA-12 shock struts (Airframes did not offer 12 struts). The combo worked perfectly. When I acquired my FliLite skis the fittings wouldn't fit on the Airframes gear so I had FAD make me a set of 3" extended gear with integrated ski fittings. I re-used the same shock struts and that combination also works perfectly. I've heard from others that the two brands of gear require the same brand of shock struts to attain proper gear geometry. That has not been true on my plane. In any event, don't forget you'll need new struts with 3" extended gear.
    Stewart
    Sep 2007
    Medaryville Indiana
    305
    What would the advantage be to 3" extended gear if 31" Bushwheels were going to be installed?
    Mick Capouch
    PA-18 150 N6TD
    btracy's Avatar
    Apr 2004
    Ohio
    1,007
    I have been back and forth on the idea of standard gear verses extended gear. I am staying with the 26 good years though.
    20,753
    Quote Originally Posted by btracy
    FdxLou's Avatar
    Apr 2004
    1,867
    For one thing, the 31" ABW's will absorb a whole lot more loads on the airframe than the hard as nails biased ply blimp tires.
    I have had both. No comparison when it comes to protecting your airframe.
    Lou
  1. Do landing gear attach fittings need gussets?
    By Dan2+2 in forum Experimental Cubs
    Last Post: 03-11-2013, 06:43 AM
  2. J-3 landing gear/strut attach fittings
    By jeff olson in forum Cafe Supercub
    Last Post: 09-26-2005, 07:57 PM
